楼主: challis
从零开始做一个数码管时钟-开天斧,程序开源 | 已完结
  • 打卡总天数:255
  • 最近打卡:2025-10-23 08:38:14
发表于 2024-1-30 09:04:51 | 显示全部楼层
LED代码查询软件
LED代码查询V1.1.exe
570.5 KB, 下载次数: 141
  • 打卡总天数:12
  • 最近打卡:2025-10-04 11:54:26
发表于 2024-1-30 11:07:25 | 显示全部楼层
chal*** published on 2024-1-26 11:01
Well, I used 3.7v voltage and tried it. I felt that the digital tube would not burn out, so I didn’t add a resistor. Do I need to add a resistor in this case? ...
I don’t quite understand why there is a significant difference in display brightness. If anyone knows, please tell me. Thank you!
Yes, as above, if you do not want varying brightness you will need 8 x segment resistors. ( R4 - R10 below)
With modern bright displays, you can even try 1k or 2k2
NMOS ports drive mA better than PMOS, so the best published circuits are like this :
  • 打卡总天数:678
  • 最近打卡:2025-11-01 06:39:16
发表于 2024-1-30 12:48:34 | 显示全部楼层
chal*** 发表于 2024-1-30 00:30
Proteus项目只是为了展示接线用的,按照对应管脚进行接线后,只要是STC8H8K64U的芯片应该都能正常运行的 ...
感谢回复,学习了
  • 打卡总天数:560
  • 最近打卡:2025-10-31 11:57:16
发表于 2024-1-30 15:34:47 | 显示全部楼层
感谢楼主,我自己也想做个电子表项目玩一玩,正好学习。
  • 打卡总天数:255
发表于 2024-1-31 12:58:23 | 显示全部楼层
jm*** 发表于 2024-1-30 11:07
Yes, as above, if you do not want varying brightness you will need 8 x segment resistors. ( R4 - R1 ...
got it,tyvm!
Its better that I use Pull-up resistor to power up my segment.
But the biggest question is that I have not enough resistances and triodes! :P
  • 打卡总天数:646
  • 最近打卡:2025-11-01 08:29:32
打工人
发表于 2024-2-2 16:26:30 | 显示全部楼层
做的挺好。很详细,学习了。
打工人
  • 打卡等级:常住居民I
  • 打卡总天数:77
  • 最近打卡:2025-08-12 06:14:48
发表于 2024-2-27 07:38:23 | 显示全部楼层
终于找到合适我学习的帖子啦,感谢楼主分享。
  • 打卡总天数:225
  • 最近打卡:2025-11-01 08:22:10
792
发表于 2024-2-27 09:11:01 | 显示全部楼层
第一次进来,为这 滴水穿石 的精神喝彩,移到 作品展示 版块
  • 打卡总天数:581
  • 最近打卡:2025-11-01 06:45:14
发表于 2024-2-28 20:26:47 来自手机 | 显示全部楼层
简单的调时按键代码还好点一旦参与到像寄存器我就迷糊了,3231的调时按键代码到现在也不会写…
  • 打卡总天数:451
  • 最近打卡:2025-11-01 08:12:42
发表于 2024-3-13 21:02:02 | 显示全部楼层
经常看看,偶尔玩玩——不过都是简单的,难的我也不会呀
GMT+8, 2025-11-1 13:13 , Processed in 0.144595 second(s), 121 queries .
