楼主: 大锤子
寻找SDCC技术交流组织
发表于 2024-9-4 19:26:24 | 显示全部楼层
sdcc 是没有overlay功能的 翻遍了官网也没找到这功能
所以项目大一点就得用 --mode-large --stack-auto 这样
不然内部内存总是不够得
说起来你可能不信 他就是一个变量占一个内存 占完就编译不过 不存在keil那种local变量只要没有调用关系就可以共享的
 楼主| 发表于 2024-9-5 10:57:37 | 显示全部楼层
所以项目大一点就得用 --mode-large --stack-auto 这 ...
应该有吧, 看啥sdcc的用户手册3.7
3.7 Overlaying
For non-reentrant functions SDCC will try to reduce internal ram space usage by overlaying parameters and local
variables of a function (if possible). Parameters and local variables of a function will be allocated to an overlayable
segment if the function has no other function calls and the function is non-reentrant and the memory model is small.
If an explicit intrinsic named address space is specified for a local variable, it will NOT be overlaid.
Note that the compiler (not the linkage editor) makes the decision for overlaying the data items. Functions that
are called from an interrupt service routine should be preceded by a #pragma nooverlay if they are not reentrant. !
Also note that the compiler does not do any processing of inline assembler code, so the compiler might incorrectly
assign local variables and parameters of a function into the overlay segment if the inline assembler code calls
other c-functions that might use the overlay. In that case the #pragma nooverlay should be used.
Parameters and local variables of functions that contain 16 or 32 bit multiplication or division will NOT be
overlaid since these are implemented using external functions, e.g.:
#pragma save
#pragma nooverlay
void set_error(unsigned char errcd)
P3 = errcd;
#pragma restore
void some_isr () __interrupt (2)
set_error(10);
In the above example the parameter errcd for the function set_error would be assigned to the overlayable segment
if the #pragma nooverlay was not present, this could cause unpredictable runtime behaviour when called from an
interrupt service routine. The #pragma nooverlay ensures that the parameters and local variables for the function
are NOT overlaid.
不争是争
发表于 2024-9-5 18:20:54 | 显示全部楼层
3.7 Overlaying
For non-reentrant functions SDCC will try to redu ...
这段我看了啊 只有leaf function会overlay
“if the function has no other function calls ”
 楼主| 发表于 2024-9-5 22:39:35 | 显示全部楼层
哦, 也没啥问题吧。 现在的单片机速度和存储都够用了。 我目前也没有接触过大到不够用的情况。 而且一般直接设置成large模式。 在使用rtos的时候也需要使用auto-stack
不争是争
发表于 2024-9-6 10:26:26 | 显示全部楼层
大*** 发表于 2024-9-5 22:39
哦, 也没啥问题吧。 现在的单片机速度和存储都够用了。 我目前也没有接触过大到不够用的情况。 而且一般 ...
large有个问题就是:当函数太复杂时会生成sloc临时变量,然而sloc是必须分配在在内部内存的,所以工程大了large也会导致无法编译
不需要太大工程rom用到20k的时候就会出现这问题  sdcc太拉跨了 忍不住吐槽一下
 楼主| 发表于 2024-9-6 10:43:26 | 显示全部楼层
magic*** 发表于 2024-9-6 10:26
large有个问题就是:当函数太复杂时会生成sloc临时变量,然而sloc是必须分配在在内部内存的,所以工程大了 ...
大佬研究这么深入,
不争是争
发表于 2024-9-6 21:57:33 | 显示全部楼层
看来sdcc只能玩玩啊,大项目还用不了
GMT+8, 2026-11-8 01:17 , Processed in 0.070281 second(s), 67 queries .
