161
1995
2294
Lkck8210 发表于 2024-8-2 15:16 但不会每次开机都换档吧? 有换档才在关机时更新EEProm
Debu*** 发表于 2024-8-2 14:35 没有,这段文字直接翻译成C语言就是代码了
#define EEPROM_SIZE 4096 #define SECTOR_SIZE 512 #define NUM_SECTORS 8 #define DATA_SECTORS (NUM_SECTORS - 1) #define POINTER_SECTOR 0 #define DATA_SECTOR_START 1 #define POINTER_BIT_COUNT 3584 #define DATA_STATE_COUNT 128 #define DATA_STATE_BITS 7 #define DATA_FLAG_BIT 7 typedef struct { int sector; int byte; } Pointer; typedef struct { int valid; int state; } Data; // 声明实际的EEPROM读写函数 unsigned char eeprom_read_byte(unsigned char *addr); void eeprom_write_byte(unsigned char *addr, unsigned char value); // 假设的EEPROM读写函数 unsigned char readEEPROM(int address) { // 使用实际的EEPROM读取函数 return eeprom_read_byte((unsigned char *)address); } void writeEEPROM(int address, unsigned char value) { // 使用实际的EEPROM写入函数 eeprom_write_byte((unsigned char *)address, value); } // 读取指针 Pointer readPointer() { int pointerBitIndex = 0; // 从第0位开始 unsigned char bitMask = 1; int byteIndex = pointerBitIndex / 8; int bitIndex = pointerBitIndex % 8; // 读取位计数器的指针位置 unsigned char pointerByte = readEEPROM(POINTER_SECTOR * SECTOR_SIZE + byteIndex); while ((pointerByte & bitMask) == 0) { // 跳过已用的位 bitMask <<= 1; if (bitMask > 0xFF) { bitMask = 1; byteIndex++; pointerByte = readEEPROM(POINTER_SECTOR * SECTOR_SIZE + byteIndex); } bitIndex++; pointerBitIndex++; } // 计算指针位置 Pointer p = {DATA_SECTOR_START, pointerBitIndex / 8}; return p; } // 写入指针 void writePointer(const Pointer* p) { int byteIndex = p->byte * 8; int bitIndex = byteIndex % 8; unsigned char byte = readEEPROM(POINTER_SECTOR * SECTOR_SIZE + byteIndex / 8); // 设置位 byte &= ~(1 << bitIndex); // 清除位 writeEEPROM(POINTER_SECTOR * SECTOR_SIZE + byteIndex / 8, byte); } // 读取数据 Data readData(const Pointer* p) { unsigned char dataByte = readEEPROM(p->sector * SECTOR_SIZE + p->byte); Data d = { .valid = !(dataByte & (1 << DATA_FLAG_BIT)), .state = dataByte & ((1 << DATA_STATE_BITS) - 1) }; return d; } // 处理数据 void processData(Data* d) { if (!d->valid) { // 处理无效数据 d->state++; if (d->state >= DATA_STATE_COUNT) { d->state = 0; } d->valid = 1; } } // 更新数据 void updateData(const Pointer* p, Data* d) { unsigned char dataByte = d->state | (d->valid ? 0 : (1 << DATA_FLAG_BIT)); writeEEPROM(p->sector * SECTOR_SIZE + p->byte, dataByte); } // 主函数示例 int main() { Pointer p = readPointer(); Data d = readData(&p); processData(&d); updateData(&p, &d); writePointer(&p); // 根据需要重复上述过程 return 0; }复制代码
Lkck*** 发表于 2024-8-2 15:16 但不会每次开机都换档吧? 有换档才在关机时更新EEProm
vb2*** 发表于 2024-8-2 19:59 这个是千问模型给出的答案, 我运行很多错误
Debu*** 发表于 2024-8-2 13:27 STC8H1K08,固定8K CODE,4K EEPROM,8个扇区,4096字节 可以第0扇区作为位计数器,bit有多少个0代表指针指 ...
Debu*** 发表于 2024-8-2 20:31 AI写的不能信,cheat gpt 有空我写一个
vb2*** 发表于 2024-8-2 21:00 哥,我想了一天..您说的是这个意思吗? 按您说的,好像是真的无敌哦...就是代码难倒我了!!!!
wnagming 发表于 2024-8-2 21:19 这是我之前做的磨损均衡代码,做吊顶灯,每次关机记录当前状态,共3种状态:冷光,暖光,均衡。就是普通的 ...
Debu*** 发表于 2024-8-2 21:33 也行,最高位表示是否已使用,已使用就写成0,可以不用一个扇区当计数器了 ...
vb2*** 发表于 2024-8-3 00:14 我试了一晚上了. 好像写之前必须要擦除 不能那样一个字节的写入,然后总体擦除
本版积分规则 发表回复 回帖后跳转到最后一页
GMT+8, 2026-11-7 14:38 , Processed in 0.082997 second(s), 90 queries .
