楼主: 大明狐
字库生成 / 图片取模, 视频教程来了 !AiCube-ISP-V6.96L 取模工具体验 NICE !
发表于 2024-2-24 11:49:54 | 显示全部楼层
测试了字库生成工具,
原来用的是PCtoLCD生成的,使用STC的字库生成工具,没有成功,
索性把同一个字所有的扫描模式都生成出来
居然没有一个能显示成功的,下图是两个软件的配置,是哪里不对了?
显示代码:
  1. unsigned char code hanzi[]=
  2. {
  3. .........
  4. 0xFD,0x01,0xFD,0x25,0x25,0xFD,0x25,0x25,0xFD,0x01,0xFD,0x00,0x07,0x04,0x05,0x05,
  5. 0x05,0x05,0x05,0x05,0x05,0x04,0x0F,0x00, /*'画',23*/
  6. 0x00,0xF0,0x10,0x10,0x10,0x1F,0x12,0x12,0x12,0xF2,0x02,0x00,0x08,0x05,0x01,0x05,
  7. 0x09,0x01,0x05,0x09,0x01,0x05,0x08,0x00, /*'点',24*/
  8. 0x00,0x0F,0xFF,0x00,0x00,0x00,0x4F,0xE4,0x92,0x49,0x24,0xFE,0x49,0x24,0x92,0x49,
  9. 0x24,0xFE,0x40,0x04,0x00,0x7F,0xF0,0x00, /*'画',25*/
  10. 0x00,0x0F,0xFF,0x00,0x00,0x00,0x7F,0x24,0x92,0x49,0x27,0xF2,0x49,0x24,0x92,0x49,
  11. 0x27,0xF2,0x00,0x20,0x02,0xFF,0xE0,0x00, /*'画',26*/
  12. 0x00,0x07,0xFF,0x40,0x04,0x00,0x4F,0xE4,0x92,0x49,0x24,0x92,0x4F,0xE4,0x92,0x49,
  13. 0x24,0xFE,0x00,0x00,0x00,0xFF,0xF0,0x00, /*'画',27*/
  14. 0x00,0x0F,0xFE,0x00,0x20,0x02,0x7F,0x24,0x92,0x49,0x24,0x92,0x7F,0x24,0x92,0x49,
  15. 0x27,0xF2,0x00,0x00,0x00,0xFF,0xF0,0x00, /*'画',28*/
  16. 0x00,0xFF,0x00,0x00,0x4F,0x49,0x49,0x4F,0x49,0x49,0x49,0x4F,0x40,0x40,0x7F,0x00,
  17. 0x0F,0x00,0xE2,0x2E,0x22,0x2E,0x00,0xF0, /*'画',29*/
  18. 0x00,0xFF,0x00,0x00,0x7F,0x49,0x49,0x7F,0x49,0x49,0x49,0x7F,0x00,0x00,0xFF,0x00,
  19. 0x0F,0x00,0x22,0x22,0x22,0x22,0x22,0xE0, /*'画',30*/
  20. 0x00,0x7F,0x40,0x40,0x4F,0x49,0x49,0x49,0x4F,0x49,0x49,0x4F,0x00,0x00,0xFF,0x00,
  21. 0x0F,0x00,0xE2,0x22,0xE2,0x2E,0x00,0xF0, /*'画',31*/
  22. 0x00,0xFF,0x00,0x00,0x7F,0x49,0x49,0x49,0x7F,0x49,0x49,0x7F,0x00,0x00,0xFF,0x00,
  23. 0x0E,0x22,0x22,0x22,0x22,0x22,0x00,0xF0, /*'画',32*/
  24. 0x40,0x4F,0x40,0x40,0x4F,0x49,0x49,0x4F,0x49,0x49,0x4F,0x40,0x00,0xFE,0x02,0x02,
  25. 0xF2,0x12,0x12,0xF2,0x12,0x12,0xF2,0x02, /*'画',33*/
  26. 0x40,0x4F,0x49,0x49,0x4F,0x49,0x49,0x4F,0x40,0x40,0x4F,0x40,0x02,0xF2,0x12,0x12,
  27. 0xF2,0x12,0x12,0xF2,0x02,0x02,0xFE,0x00, /*'画',34*/
  28. 0x00,0x7F,0x40,0x40,0x4F,0x48,0x48,0x4F,0x48,0x48,0x4F,0x40,0x02,0xF2,0x02,0x02,
  29. 0xF2,0x92,0x92,0xF2,0x92,0x92,0xF2,0x02, /*'画',35*/
  30. 0x40,0x4F,0x48,0x48,0x4F,0x48,0x48,0x4F,0x40,0x40,0x7F,0x00,0x02,0xF2,0x92,0x92,
  31. 0xF2,0x92,0x92,0xF2,0x02,0x02,0xF2,0x02, /*'画',36*/
  32. 0x40,0x00,0x4F,0xFE,0x40,0x02,0x40,0x02,0x4F,0xF2,0x49,0x12,0x49,0x12,0x4F,0xF2,
  33. 0x49,0x12,0x49,0x12,0x4F,0xF2,0x40,0x02, /*'画',37*/
  34. 0x40,0x02,0x4F,0xF2,0x49,0x12,0x49,0x12,0x4F,0xF2,0x49,0x12,0x49,0x12,0x4F,0xF2,
  35. 0x40,0x02,0x40,0x02,0x4F,0xFE,0x40,0x00, /*'画',38*/
  36. 0x00,0x02,0x7F,0xF2,0x40,0x02,0x40,0x02,0x4F,0xF2,0x48,0x92,0x48,0x92,0x4F,0xF2,
  37. 0x48,0x92,0x48,0x92,0x4F,0xF2,0x40,0x02, /*'画',39*/
  38. 0x40,0x02,0x4F,0xF2,0x48,0x92,0x48,0x92,0x4F,0xF2,0x48,0x92,0x48,0x92,0x4F,0xF2,
  39. 0x40,0x02,0x40,0x02,0x7F,0xF2,0x00,0x02, /*'画',40*/
  40.
  41. };
  42. //========================================================================
  43. // 函数: void LCD_DataWrite(unsigned int Data)
  44. // 描述: 写一个字节的显示数据至LCD中的显示缓冲RAM当中
  45. // 参数: Data 写入的数据
  46. //========================================================================
  47. void LCD_DataWrite(unsigned char Dat)//,_Fill_Dot_LCD
  48. {
  49. unsigned char Num;
  50. LCD_CS = 0;
  51. LCD_A0 = 1;
  52. for(Num=0;Num<8;Num++)
  53. {
  54.   if((Dat&0x80) == 0)
  55.   LCD_SDI = 0;
  56.   else LCD_SDI = 1;
  57.   Dat = Dat << 1;
  58.   LCD_CLK = 0;
  59.   LCD_CLK = 1;
  60. }
  61. LCD_CS = 1;
  62. }
  63. //---------------------------------------------
  64. //LCD_set_XY: 设置LCD坐标函数
  65. //输入参数:X:0-83  Y:0-5
  66. //编写日期:20080918
  67. //---------------------------------------------
  68. void LCD_setXY(unsigned char X, unsigned char Y)
  69. {
  70.         unsigned char gao,di;
  71.         LCD_RegWrite(0xB0 | Y); //页
  72.         X = X + 4;                 //液晶是0-131的,我们只用到0-127,所以当倒序的方法时(131-0),实际上是127-0,
  73.         gao = X & 0xf0;
  74.         gao = gao >> 4;
  75.         di = X & 0x0f;
  76.         LCD_RegWrite(0x10 | gao);  //set Column address MSB
  77.     LCD_RegWrite(0x00 | di);  //set column address LSB
  78. }
  79. /*---------------------------------------------
  80. LCD_write_hanzi: 显示12(宽)*16(高)点阵列汉字等半角类
  81. 输入参数:c:显示的字符;
  82. -----------------------------------------------*/
  83. void LCD_write_hanzi(unsigned char row, unsigned char page,unsigned char c) //row:列 page:页 dd:字符
  84. {
  85.         unsigned char i;
  86.
  87.         LCD_setXY(row*6, page);// 列,页
  88.         for(i=0; i<12;i++)
  89.         {
  90.                  LCD_DataWrite(hanzi[c*24+i]);
  91.         }
  92.
  93.     LCD_setXY(row*6, page+1);// 列,页
  94.         for(i=12; i<24;i++)
  95.         {
  96.                  LCD_DataWrite(hanzi[c*24+i]);
  97.         }
  98. }
12864.c
31.92 KB, 下载次数: 281
最好能看一下您的屏幕驱动里的显示汉字的代码,看下是什么读取顺序 就目前描述推测,发现几个问题: 第一,“画”字上8个像素下两行颠倒 第二,“画”字上下两行里的像素点上下颠倒 这两个现象大概跟文字显  详情 回复 发表于 2024-2-24 13:28
 楼主| 发表于 2024-2-24 13:28:01 | 显示全部楼层
wppp*** 发表于 2024-2-24 11:49
测试了字库生成工具,
索性把同一个字所有的 ...
就目前描述推测,发现几个问题:
第一,“画”字上8个像素下两行颠倒
这两个现象大概跟文字显示代码里的读取顺序有关
以及那个“低位在前”,
PCtoLCD里的是“取模走向”,就是从每一竖列的低位开始取,从上向下;
STC的工具里是“存储顺序”,也就是数据保存的时候,8位二进制数里,
从左到右是先高位还是先低位。取模走向是“从上向下”跟PCtoLCD一样。
所以STC里的“存储顺序”应该选“高位在前”。
第三,“画”字不完整
看不到PCtoLCD主界面的字宽设置,推测应该也是12
STC的这里应该是还不完善,没有像图片取模里那样可以动态调整调整字模尺寸的功能,
生成的字模,只能是宽高一样的,所以把点阵宽度改成12之后,相当于只取出了前12列
而在PCtoLCD里可以通过设置字符宽度,把文字挤成12宽,从而可以取出完整的字模
通过以上推断,模拟了一下显示12×16字符的代码,用PCtoLCD确实可以正确显示出完整的文字
或者缩小字体大小,让文字完整
所以,可以建议一下STC能不能加上 文字尺寸 也能调整的功能
1 喜欢他/她就送朵鲜花吧,赠人玫瑰,手有余香!
发表于 2024-2-25 09:14:53 | 显示全部楼层
就目前描述推测,发现几个问题:
感谢你的分析,我把代码片断和代码文件已经贴上来了。
代码看到了,的确是列行式顺着读取的。看里面的字模,是字体大小9的吧,12×12的,也挺好看。 那么原因就是上面说的那几个原因了,一个是高位在前还是低位在前的问题,另一个是没有像PCtoLCD那样能挤压字体尺寸的功  详情 回复 发表于 2024-2-25 19:14
 楼主| 发表于 2024-2-25 19:14:49 | 显示全部楼层
代码看到了,的确是列行式顺着读取的。
另一个是没有像PCtoLCD那样能挤压字体尺寸的功能。
发表于 2024-2-26 09:17:52 | 显示全部楼层
原来是高位在前   和 PCtoLCD  中的低位在前相对应。
在STC中使用高位在前,就正常显示了。感谢楼上解惑!
对,一个是取模走向的顺序,一个是存储顺序,正好是相反的  发表于 2024-2-26 09:22
发表于 2024-2-29 22:31:20 | 显示全部楼层
下面是我们荣誉版主再次体验 STC-ISP V6.93 版的
【字库生成】文字取模工具的补充文字说明和补充视频
【新提醒】体验一下STC-ISP V6.93 版的【字库生成】文字取模 工具的新增功能 - 问题反馈:ISP软件/头文件/单片机数据手册规格书等 - 国芯论坛-STC全球32位8051爱好者互助交流社区 - STC全球32位8051爱好者互助交流社区 (stcaimcu.com)
STC-ISP V6.93 来了
Ver6.93 (2024-2-29)
  1. 解决主窗口串口号和串口助手串口号相冲突时
     ISP下载会失败的问题
  2. 字库生成工具新增如下新功能
     (增加前置索引数据格式)
     (增加滤重复字符功能)
     (增加自动排序功能)
     (增加通过移动文字输入框中的光标动态显示效果)
     (增加自定义字体宽度和高度功能)
     (增加预览全部功能)
     (增加手工模式,可自行设计和修改点阵)
     (增加自定义输出数据格式功能)
上面是新版本软件针对字库工具,新增的功能
stc-isp-15xx-v6.93.zip
6.11 MB, 下载次数: 886
发表于 2024-3-1 09:10:04 | 显示全部楼层
字模小软件,俺也刚刚完成。不过功能不多,目前只有16*16、32*32和64*64
帮我们多提提建议,【继续远航】  详情 回复 发表于 2024-3-1 10:16
经常看看,偶尔玩玩——不过都是简单的,难的我也不会呀
发表于 2024-3-1 10:16:22 | 显示全部楼层
帮我们多提提建议,【继续远航】
发表于 2024-3-3 06:40:21 | 显示全部楼层
发表于 2024-3-3 09:05:07 | 显示全部楼层
STC-ISP越来越好用,越来越方便了
GMT+8, 2026-11-8 02:49 , Processed in 0.078372 second(s), 85 queries .
