楼主: wlb2026
布丁橘长-STC32屠龙刀学习心得
  • 打卡总天数:6
  • 最近打卡:2026-01-15 08:00:16
发表于 2026-1-15 08:15:56 | 显示全部楼层
第19集
本集实现了多功能按键(单击,双击,长安),程序采用了模块化设计,需要新建C文件及相应的H文件,主函数中,需要增加调用新建的H头文件。
unsigned char key_multi(void);   //带有char型返回函数的格式。
static  //为静态变量,只运行一次。
if与else ifd的用法
swith case 用法中,记得一定要加break,不然会一直执行
return  //返回关键字
以下为多功能按键的扫描函数
unsigned char key_multi(void)  //key_return
         unsigned char key_state;
        static unsigned int key_time;
        static unsigned char key_press_nums;
        static unsigned int key_time_double;
        static unsigned char keynum;
        static unsigned char new_keynum;
        unsigned char key_press, key_return;
        key_return = None_click;
        key_delayms(10);
        switch(keyscan())
                case 1:key_press = KEY1;new_keynum = 1;break;
                case 2:key_press = KEY2;new_keynum = 2;break;
                case 3:key_press = KEY3;new_keynum = 3;break;
                case 4:key_press = KEY4;new_keynum = 4;break;
                default:key_press = 1;break;
        if(key_press_nums > 0)
                key_time_double++;
                if(key_time_double >= DOUBLE_KEY_TIME && key_time_double < LONG_KEY_TIME) key_state = KEY_STATE_2;
witch (key_state)
                case KEY_STATE_0:
                        if (!key_press)
                                key_time = 0;
                                key_state = KEY_STATE_1;
                }break;
                case KEY_STATE_1:
                        if (!key_press)
                                key_time++;
                                if(key_time>=SINGLE_KEY_TIME)
                                        key_press_nums++;
                        else key_state = KEY_STATE_0;
                }break;
                case KEY_STATE_2:
                        if(key_press)
                                if(key_time_double < DOUBLE_KEY_TIME ) key_state = KEY_STATE_0;
                                        if(key_press_nums == 1) key_return = Single_click + new_keynum*10;
                                        else if(key_press_nums ==2 && new_keynum == keynum) key_return = Double_click + new_keynum*10;
                                        key_press_nums = 0;
                                        key_time_double = 0;
                                key_time++;
                                if(key_time >= LONG_KEY_TIME)
                                        key_return = Long_click + new_keynum*10;
                                        key_state = KEY_STATE_3;
                }break;
                case KEY_STATE_3:
                        if (key_press)
                                key_press_nums = 0;
                }break;
                default:key_state = KEY_STATE_0;break;
        keynum = new_keynum;
        return key_return;
  • 打卡总天数:6
发表于 2026-1-15 09:03:00 | 显示全部楼层
第20集
这一章节讲的是利用翻转发扫描16个矩阵按键
u8 Matrix_key()
        u8 temp,keyvalue;
        u8 keystate;
        P2 = 0xF0;
        if(P2 != 0xF0 && keystate == 0)
                delayms(5);
                        keystate = 1;
                        temp = P2;
                        switch(temp)
                                case 0xE0:keyvalue = 1;break;
                                case 0xD0:keyvalue = 2;break;
                                case 0xB0:keyvalue = 3;break;
                                case 0x70:keyvalue = 4;break;
                        P2 = 0x0F;
                        if(P2 != 0x0F)
                                temp = P2;
                                switch(temp)
                                        case 0x07:keyvalue += 0;break;
                                        case 0x0B:keyvalue += 4;break;
                                        case 0x0D:keyvalue += 8;break;
                                        case 0x0E:keyvalue += 12;break;
        if(P2 == 0xF0) keystate = 0;
        return keyvalue;
1.让8个i/o口中,4列为高电平,然后读取到低电平端口,说明有按键按下了
2.8个i/o口,高低电平翻转输出,行为低电平,列为高电平,只有就能得出按键按下的是哪个按键了,返回对应的按键值
GMT+8, 2026-5-30 05:42 , Processed in 0.101106 second(s), 46 queries .
