查看: 1897|回复: 14
Ai8G1K08 16PIN 的pwm输出管脚怎么指定
  • 打卡总天数:2
  • 最近打卡:2025-07-31 09:51:22
发表于 2025-7-30 15:47:50 | 显示全部楼层 |阅读模式
第一次使用这个芯片,在官方例程已经手册当中没有找到关于pwm输出到哪个管脚的设置寄存器,图片中手册的位置应该是增强型的pwm,但是我用这款应该不支持,那普通的3个通道的pwm在手册哪里?这个手册风格一时没有习惯过来
  • 打卡总天数:2
发表于 2025-7-30 16:00:43 | 显示全部楼层
#include "reg51.h"
#define CYCLE       0x1000
sfr     P_SW1   =   0xa2;
sfr     P_SW2   =   0xba;
sfr     PWMSET      =   0xF1;
sfr     PWMCFG01    =   0xF6;
sfr     PWMCFG23    =   0xF7;
sfr     PWMCFG45    =   0xFE;
#define PWM0C       (*(unsigned int  volatile xdata *)0xFF00)
#define PWM0CH      (*(unsigned char volatile xdata *)0xFF00)
#define PWM0CL      (*(unsigned char volatile xdata *)0xFF01)
#define PWM0CKS     (*(unsigned char volatile xdata *)0xFF02)
#define PWM0TADC    (*(unsigned int  volatile xdata *)0xFF03)
#define PWM0TADCH   (*(unsigned char volatile xdata *)0xFF03)
#define PWM0TADCL   (*(unsigned char volatile xdata *)0xFF04)
#define PWM0IF      (*(unsigned char volatile xdata *)0xFF05)
#define PWM0FDCR    (*(unsigned char volatile xdata *)0xFF06)
#define PWM00T1     (*(unsigned int  volatile xdata *)0xFF10)
#define PWM00T1H    (*(unsigned char volatile xdata *)0xFF10)
#define PWM00T1L    (*(unsigned char volatile xdata *)0xFF11)
#define PWM00T2H    (*(unsigned char volatile xdata *)0xFF12)
#define PWM00T2     (*(unsigned int  volatile xdata *)0xFF12)
#define PWM00T2L    (*(unsigned char volatile xdata *)0xFF13)
#define PWM00CR     (*(unsigned char volatile xdata *)0xFF14)
#define PWM00HLD    (*(unsigned char volatile xdata *)0xFF15)
sfr     P0M1    =   0x93;
sfr     P0M0    =   0x94;
sfr     P1M1    =   0x91;
sfr     P1M0    =   0x92;
sfr     P2M1    =   0x95;
sfr     P2M0    =   0x96;
sfr     P3M1    =   0xb1;
sfr     P3M0    =   0xb2;
sfr     P4M1    =   0xb3;
sfr     P4M0    =   0xb4;
sfr     P5M1    =   0xc9;
sfr     P5M0    =   0xca;
void PWM0_Isr() interrupt 22
    static bit dir = 1;
    static int val = 0;
    if (PWMCFG01 & 0x08)
        PWMCFG01 &= ~0x08;                      //清中断标志
        if (dir)
            val++;
            if (val >= CYCLE) dir = 0;
            val--;
            if (val <= 1) dir = 1;
        _push_(P_SW2);
        P_SW2 |= 0x80;
        PWM00T2 = val;
        _pop_(P_SW2);
    P0M0 = 0x00;
    P0M1 = 0x00;
    P1M0 = 0x00;
    P1M1 = 0x00;
    P2M0 = 0x00;
    P2M1 = 0x00;
    P3M0 = 0x00;
    P3M1 = 0x00;
    P4M0 = 0x00;
    P4M1 = 0x00;
    P5M0 = 0x00;
    P5M1 = 0x00;
    PWMSET = 0x01;                              //使能PWM0模块(必须先使能模块后面的设置才有效)
    //P_SW1 = 0x80;
    PWM0CKS = 0x00;                             // PWM0时钟为系统时钟
    PWM0C = CYCLE;                              //设置PWM0周期
    PWM00T1= 0x0000;
    PWM00T2= 0x0001;
    PWM00CR= 0x80;                              //使能PWM00输出
    P_SW1 = 0x00;
    PWMCFG01 = 0x0c;                            //启动PWM0模块并使能PWM0中断
    while (1);
上面的代码是我从官方例程改过的,但是也没实现预期的效果,就是不能进入中断,官方例程也不靠谱??
  • 打卡总天数:190
  • 最近打卡:2026-07-03 17:15:08
发表于 2025-7-30 16:03:14 | 显示全部楼层
深圳国芯人工智能有限公司-工具软件  https://www.stcai.com/gjrj
STC官网:https://www.stcai.com/
QQ:2593903262
微信号:18106296598
  • 打卡总天数:330
  • 最近打卡:2026-07-03 10:05:10
发表于 2025-7-30 16:03:40 | 显示全部楼层
  • 打卡总天数:727
  • 最近打卡:2026-06-26 17:48:25
发表于 2025-7-30 16:05:30 | 显示全部楼层
  • 打卡总天数:2
发表于 2025-7-30 16:08:30 | 显示全部楼层
AI*** 发表于 2025-7-30 16:03
https://www.stcaimcu.com/data/download/Datasheet/STC8H.pdf
官方的hex文件写进去都没办法运行,都不能进入中断,
  • 打卡总天数:2
发表于 2025-7-30 16:10:10 | 显示全部楼层
国芯人*** 发表于 2025-7-30 15:48
关于STC8G1K08 16PIN芯片的PWM输出管脚配置问题,以下是专业说明:
STC8G1K08是STC公司推出的一款基于8051 ...
AI
也是捣乱,你看看你提供的寄存器地址都不对,别捣乱
  • 打卡总天数:2
发表于 2025-7-30 16:11:32 | 显示全部楼层
我用的貌似不是这款
  • 打卡总天数:2
发表于 2025-7-30 16:15:00 | 显示全部楼层
用的芯片是STC8G1K08-38I-SOP16 这个工具上貌似没有针对这的例程呢?
[attachimg]110372[/attachimg] 8G1k08是没有PCA部分(3路PWM的那个)的,所以想用PWM的话,只能用定时器软件模拟生成了 或者可以更换成8g1k08A 这个型号带有ADC和PCA,功能更多一些  详情 回复 发表于 2025-7-30 17:24
  • 打卡总天数:738
  • 最近打卡:2026-07-04 20:08:40
发表于 2025-7-30 17:24:27 | 显示全部楼层
或者可以更换成8g1k08A
GMT+8, 2026-7-5 17:58 , Processed in 0.076614 second(s), 87 queries .
