RMB1.05, 8H2K12U做USB转串口,如何兼容340的通信协议 | 已成功
  • 打卡等级:常住居民I
  • 打卡总天数:78
  • 最近打卡:2026-06-29 10:44:00
发表于 2026-6-3 16:26:08 | 显示全部楼层
erci*** 发表于 2026-6-3 15:06
不存在这样的限制
串口1发送就没问题?是谁给谁发卡死?如何判断的卡死?USB抓包停在哪个阶段?发太快主 ...
测试你的代码用的串口1不会有卡死现象,就把uart文件所有关于串口1的全部换成串口2,发个10来次就卡死,现象为串口工具点都点不动了
/* --- Fax: 86-0513-55012956,55012947,55012969 ------------------------*/
/* --- QQ:  800003751 -------------------------------------------------*/
#include "stc.h"
#include "uart.h"
#include "usb.h"
#include "usb_req_class.h"
BOOL UartBusy;
void uart_init()
        P_SW2 &= ~0x01;                                        //UART2/USART2: RxD2(P1.0), TxD2(P1.1)
        S2CON = (S2CON & 0x3f) | 0x40;
        AUXR |= 0x04;                                        //定时器时钟1T模式
    T2L = BR(115200);
    T2H = BR(115200) >> 8;
    AUXR |= T2R;                    //启动定时器
    IE2 |= ES2;                     //使能串口中断
        S2CON |= S2REN;                                        //允许接收
    LineCoding.dwDTERate = 0x00c20100;  //115200
    LineCoding.bCharFormat = 0;
    LineCoding.bParityType = 0;
    LineCoding.bDataBits = 8;
void UART2_Isr() interrupt UART2_VECTOR
    if (S2CON & 0x02)
        S2CON &= ~0x02;                         //清中断标志
        TxBuffer[TxWptr++] = S2BUF;
    if (S2CON & 0x01)
        S2CON &= ~0x01;                         //清中断标志
        UartBusy = 0;
void uart_set_parity(BYTE parity)
        switch (parity)
        default:
        case NONE_PARITY:
            S2CON = 0x50;
            break;
        case ODD_PARITY:
        case EVEN_PARITY:
        case MARK_PARITY:
            S2CON = 0xd8;
            break;
        case SPACE_PARITY:
            S2CON = 0xd0;
            break;
void uart_set_baud(DWORD baud)
    WORD temp;
        temp = (WORD)BR(baud);
    T2L = temp;
    T2H = temp >> 8;
void uart_polling()
    BYTE dat;
    BYTE cnt;
    if (DeviceState != DEVSTATE_CONFIGURED)  //如果USB配置没有完成,就直接退出
        return;
    if (!UsbInBusy && (TxRptr != TxWptr))
        IE2 &= ~0x80;   //EUSB = 0;
        UsbInBusy = 1;
        usb_write_reg(INDEX, 2);
        cnt = 0;
        while (TxRptr != TxWptr)
            usb_write_reg(FIFO2, TxBuffer[TxRptr++]);
            cnt++;
            if (cnt == EP2IN_SIZE) break;
        usb_write_reg(INCSR1, INIPRDY);
        IE2 |= 0x80;    //EUSB = 1;
    if (!UartBusy && (RxRptr != RxWptr))
        dat = RxBuffer[RxRptr++];
        UartBusy = 1;
        switch (LineCoding.bParityType)
        case NONE_PARITY:
        case SPACE_PARITY:
//            TB8 = 0;
                        S2CON &= ~S2TB8;
            break;
        case ODD_PARITY:
            ACC = dat;
//            TB8 = !P;
                        if(!P)
                                S2CON |= S2TB8;
                                S2CON &= ~S2TB8;
            break;
        case EVEN_PARITY:
            ACC = dat;
//                        TB8 = P;
                        if(P)
                                S2CON |= S2TB8;
                                S2CON &= ~S2TB8;
            break;
        case MARK_PARITY:
//            TB8 = 1;
                        S2CON |= S2TB8;
            break;
        S2BUF = dat;
        while (UartBusy);
    if (UsbOutBusy)
        if ((BYTE)(RxWptr - RxRptr) < (BYTE)(256 - EP2OUT_SIZE))
            UsbOutBusy = 0;
            usb_write_reg(OUTCSR1, 0);
  • 打卡等级:常住居民I
  • 打卡总天数:78
发表于 2026-6-3 16:32:12 | 显示全部楼层
不存在这样的限制
#include "stc.h"
#include "uart.h"
#include "usb.h"
BOOL UartBusy;
void uart_init()
    T2L = BR(115200);
    if (S2CON & 0x02)
    if (S2CON & 0x01)
        UartBusy = 0;
        switch (parity)
        default:
        case NONE_PARITY:
            S2CON = 0x50;
            break;
        case ODD_PARITY:
        case EVEN_PARITY:
        case MARK_PARITY:
            S2CON = 0xd8;
            break;
        case SPACE_PARITY:
            S2CON = 0xd0;
            break;
    WORD temp;
    T2L = temp;
    T2H = temp >> 8;
void uart_polling()
    BYTE dat;
    BYTE cnt;
        return;
        UsbInBusy = 1;
        cnt = 0;
            cnt++;
        UartBusy = 1;
        case NONE_PARITY:
        case SPACE_PARITY:
//            TB8 = 0;
                        S2CON &= ~S2TB8;
            break;
        case ODD_PARITY:
            ACC = dat;
//            TB8 = !P;
                        if(!P)
                                S2CON |= S2TB8;
                                S2CON &= ~S2TB8;
            break;
        case EVEN_PARITY:
            ACC = dat;
//                        TB8 = P;
                        if(P)
                                S2CON |= S2TB8;
                                S2CON &= ~S2TB8;
            break;
        case MARK_PARITY:
//            TB8 = 1;
                        S2CON |= S2TB8;
            break;
        S2BUF = dat;
        while (UartBusy);
    if (UsbOutBusy)
            UsbOutBusy = 0;
  • 打卡总天数:316
  • 最近打卡:2026-07-04 08:25:57
18
发表于 2026-6-6 17:11:39 | 显示全部楼层
erci*** 发表于 2025-5-9 08:47
根据楼上网友的开源USB转串口程序,
使用STC通用USB型MCU做USB转串口,
兼容CH340的通信协议,已测试成功,
大佬,我也想要一个8脚8H2K12U转340协议的,跪求更新一个转串口2的
  • 打卡总天数:316
18
发表于 2026-6-9 08:18:48 | 显示全部楼层
duan*** 发表于 2026-6-3 16:26
测试你的代码用的串口1不会有卡死现象,就把uart文件所有关于串口1的全部换成串口2,发个10来次就卡死,现 ...
你的调好了没
  • 打卡等级:常住居民I
  • 打卡总天数:78
发表于 6 天前 | 显示全部楼层
反正就是会卡死,我对USB不熟,你问问论坛其它高手呗
  • 打卡总天数:316
18
发表于 6 天前 | 显示全部楼层
我对USB也不熟,会卡死,那就不能用
GMT+8, 2026-7-5 14:04 , Processed in 0.073272 second(s), 71 queries .
