- 打卡等级:以坛为家I
- 打卡总天数:206
- 最近打卡:2025-10-13 01:10:06
- 积分
- 19710
发表于 2023-4-3 23:04:08
显示全部楼层
我不是研发十多年,已多年装不懂技术了,只是凭感觉帮你找些专业对口的资料
下面是 STC8H实验箱上的 LCD1602的演示程序
/* --- Fax: 86-0513-55012956,55012947,55012969 ------------------------*/
/* --- Web: www.STCMCU.com --------------------------------------------*/
/* --- Web: www.STCMCUDATA.com ---------------------------------------*/
/* --- QQ: 800003751 -------------------------------------------------*/
驱动LCD1602字符屏.
显示效果为: LCD显示时间.
第一行显示 ---Clock demo---
第二行显示 12-00-00
下载时, 选择时钟 24MHz (用户可自行修改频率).
#include "reg51.h" //包含此头文件后,里面声明的寄存器不需要再手动输入,避免重复定义
#define MAIN_Fosc 24000000L //定义主时钟
typedef unsigned char u8;
typedef unsigned int u16;
typedef unsigned long u32;
//手动输入声明"reg51.h"头文件里面没有定义的寄存器
sfr TH2 = 0xD6;
sfr TL2 = 0xD7;
sfr IE2 = 0xAF;
sfr INT_CLKO = 0x8F;
sfr AUXR = 0x8E;
sfr AUXR1 = 0xA2;
sfr P_SW1 = 0xA2;
sfr P_SW2 = 0xBA;
sfr S2CON = 0x9A;
sfr S2BUF = 0x9B;
sfr P4 = 0xC0;
sfr P5 = 0xC8;
sfr P6 = 0xE8;
sfr P7 = 0xF8;
sfr P1M1 = 0x91; //PxM1.n,PxM0.n =00--->Standard, 01--->push-pull
sfr P1M0 = 0x92; // =10--->pure input, 11--->open drain
sfr P0M1 = 0x93;
sfr P0M0 = 0x94;
sfr P2M1 = 0x95;
sfr P2M0 = 0x96;
sfr P3M1 = 0xB1;
sfr P3M0 = 0xB2;
sfr P4M1 = 0xB3;
sfr P4M0 = 0xB4;
sfr P5M1 = 0xC9;
sfr P5M0 = 0xCA;
sfr P6M1 = 0xCB;
sfr P6M0 = 0xCC;
sfr P7M1 = 0xE1;
sfr P7M0 = 0xE2;
sbit P00 = P0^0;
sbit P01 = P0^1;
sbit P02 = P0^2;
sbit P03 = P0^3;
sbit P04 = P0^4;
sbit P05 = P0^5;
sbit P06 = P0^6;
sbit P07 = P0^7;
sbit P10 = P1^0;
sbit P11 = P1^1;
sbit P12 = P1^2;
sbit P13 = P1^3;
sbit P14 = P1^4;
sbit P15 = P1^5;
sbit P16 = P1^6;
sbit P17 = P1^7;
sbit P20 = P2^0;
sbit P21 = P2^1;
sbit P22 = P2^2;
sbit P23 = P2^3;
sbit P24 = P2^4;
sbit P25 = P2^5;
sbit P26 = P2^6;
sbit P27 = P2^7;
sbit P30 = P3^0;
sbit P31 = P3^1;
sbit P32 = P3^2;
sbit P33 = P3^3;
sbit P34 = P3^4;
sbit P35 = P3^5;
sbit P36 = P3^6;
sbit P37 = P3^7;
sbit P40 = P4^0;
sbit P41 = P4^1;
sbit P42 = P4^2;
sbit P43 = P4^3;
sbit P44 = P4^4;
sbit P45 = P4^5;
sbit P46 = P4^6;
sbit P47 = P4^7;
sbit P50 = P5^0;
sbit P51 = P5^1;
sbit P52 = P5^2;
sbit P53 = P5^3;
sbit P54 = P5^4;
sbit P55 = P5^5;
sbit P56 = P5^6;
sbit P57 = P5^7;
/************* Pin define *****************************************************/
sbit LCD_B7 = P6^7; //D7 -- Pin 14 LED- -- Pin 16
sbit LCD_B6 = P6^6; //D6 -- Pin 13 LED+ -- Pin 15
sbit LCD_B5 = P6^5; //D5 -- Pin 12 Vo -- Pin 3
sbit LCD_B4 = P6^4; //D4 -- Pin 11 VDD -- Pin 2
sbit LCD_B3 = P6^3; //D3 -- Pin 10 VSS -- Pin 1
sbit LCD_B2 = P6^2; //D2 -- Pin 9
sbit LCD_B1 = P6^1; //D1 -- Pin 8
sbit LCD_B0 = P6^0; //D0 -- Pin 7
sbit LCD_ENA = P4^2; //Pin 6
sbit LCD_RW = P4^4; //Pin 5 //LCD_RS R/W DB7--DB0 FOUNCTION
sbit LCD_RS = P4^5; //Pin 4 // 0 0 INPUT write the command to LCD model
// 0 1 OUTPUT read BF and AC pointer from LCD model
// 1 0 INPUT write the data to LCD model
// 1 1 OUTPUT read the data from LCD model
u8 hour,minute,second;
void RTC(void);
void ClearLine(u8 row);
void Initialize_LCD(void);
void PutString(u8 row, u8 column, u8 *puts);
void DisplayRTC(void);
void delay_ms(u16 ms);
void WriteChar(u8 row, u8 column, u8 dat);
Initialize_LCD();
ClearLine(0);
ClearLine(1);
PutString(0,0,"---Clock demo---");
hour = 12; //初始化时间值
minute = 0;
second = 0;
DisplayRTC();
delay_ms(1000);
RTC();
DisplayRTC();
// 函数: void delay_ms(u16 ms)
// 描述: 延时函数。
// 参数: ms,要延时的ms数, 这里只支持1~65535ms. 自动适应主时钟.
// 版本: VER1.0
// 日期: 2013-4-1
// 备注:
u16 i;
do{
i = MAIN_Fosc / 10000;
while(--i); //10T per loop
}while(--ms);
// 函数: void DisplayRTC(void)
// 描述: 显示时钟函数
// 参数: none.
// 版本: VER1.0
// 日期: 2013-4-1
// 备注:
if(hour >= 10) WriteChar(1,4,hour / 10 + '0');
else WriteChar(1,4,' ');
WriteChar(1,5,hour % 10 +'0');
WriteChar(1,6,'-');
WriteChar(1,7,minute / 10+'0');
WriteChar(1,8,minute % 10+'0');
WriteChar(1,9,'-');
WriteChar(1,10,second / 10 +'0');
WriteChar(1,11,second % 10 +'0');
// 函数: void RTC(void)
// 描述: RTC演示函数
// 参数: none.
// 版本: VER1.0
// 日期: 2013-4-1
// 备注:
void RTC(void)
if(++second >= 60)
second = 0;
if(++minute >= 60)
minute = 0;
if(++hour >= 24) hour = 0;
/************* LCD1602相关程序 *****************************************************/
//8位数据访问方式 LCD1602 标准程序 梁工编写 2014-2-21
#define LineLength 16 //16x2
total 2 lines, 16x2= 32
first line address: 0~15
second line address: 64~79
#define C_CLEAR 0x01 //clear LCD
#define C_HOME 0x02 //cursor go home
#define C_CUR_L 0x04 //cursor shift left after input
#define C_RIGHT 0x05 //picture shift right after input
#define C_CUR_R 0x06 //cursor shift right after input
#define C_LEFT 0x07 //picture shift left after input
#define C_OFF 0x08 //turn off LCD
#define C_ON 0x0C //turn on LCD
#define C_FLASH 0x0D //turn on LCD, flash
#define C_CURSOR 0x0E //turn on LCD and cursor
#define C_FLASH_ALL 0x0F //turn on LCD and cursor, flash
#define C_CURSOR_LEFT 0x10 //single cursor shift left
#define C_CURSOR_RIGHT 0x10 //single cursor shift right
#define C_PICTURE_LEFT 0x10 //single picture shift left
#define C_PICTURE_RIGHT 0x10 //single picture shift right
#define C_BIT8 0x30 //set the data is 8 bits
#define C_BIT4 0x20 //set the data is 4 bits
#define C_L1DOT7 0x30 //8 bits,one line 5*7 dots
#define C_L1DOT10 0x34 //8 bits,one line 5*10 dots
#define C_L2DOT7 0x38 //8 bits,tow lines 5*7 dots
#define C_4bitL2DOT7 0x28 //4 bits,tow lines 5*7 dots
#define C_CGADDRESS0 0x40 //CGRAM address0 (addr=40H+x)
#define C_DDADDRESS0 0x80 //DDRAM address0 (addr=80H+x)
#define LCD_BusData(dat) P6 = dat
void LCD_DelayNop(void)
_nop_();_nop_();_nop_();
// 函数: void CheckBusy(void)
// 描述: 检测忙函数
// 参数: none.
// 版本: VER1.0
// 日期: 2013-4-1
// 备注:
u16 i;
for(i=0; i<5000; i++) {if(!LCD_B7) break;} //check the LCD busy or not. With time out
// while(LCD_B7); //check the LCD busy or not. Without time out
// 函数: void IniSendCMD(u8 cmd)
// 描述: 初始化写命令(不检测忙)
// 参数: cmd: 要写的命令.
// 版本: VER1.0
// 日期: 2013-4-1
// 备注:
LCD_RW = 0;
LCD_BusData(cmd);
LCD_DelayNop();
LCD_ENA = 1;
LCD_DelayNop();
LCD_ENA = 0;
LCD_BusData(0xff);
// 函数: void Write_CMD(u8 cmd)
// 描述: 写命令(检测忙)
// 参数: cmd: 要写的命令.
// 版本: VER1.0
// 日期: 2013-4-1
// 备注:
LCD_RS = 0;
LCD_RW = 1;
LCD_BusData(0xff);
LCD_DelayNop();
LCD_ENA = 1;
CheckBusy(); //check the LCD busy or not.
LCD_ENA = 0;
LCD_RW = 0;
LCD_BusData(cmd);
LCD_DelayNop();
LCD_ENA = 1;
LCD_DelayNop();
LCD_ENA = 0;
LCD_BusData(0xff);
// 函数: void Write_DIS_Data(u8 dat)
// 描述: 写显示数据(检测忙)
// 参数: dat: 要写的数据.
// 版本: VER1.0
// 日期: 2013-4-1
// 备注:
LCD_RS = 0;
LCD_RW = 1;
LCD_BusData(0xff);
LCD_DelayNop();
LCD_ENA = 1;
LCD_ENA = 0;
LCD_RW = 0;
LCD_RS = 1;
LCD_BusData(dat);
LCD_DelayNop();
LCD_ENA = 1;
LCD_DelayNop();
LCD_ENA = 0;
LCD_BusData(0xff);
// 函数: void Initialize_LCD(void)
// 描述: 初始化函数
// 参数: none.
// 版本: VER1.0
// 日期: 2013-4-1
// 备注:
LCD_ENA = 0;
LCD_RS = 0;
LCD_RW = 0;
delay_ms(100);
IniSendCMD(C_BIT8); //set the data is 8 bits
delay_ms(10);
Write_CMD(C_L2DOT7); //tow lines 5*7 dots
delay_ms(6);
Write_CMD(C_CLEAR); //clear LCD RAM
Write_CMD(C_CUR_R); //Curror Shift Right
Write_CMD(C_ON); //turn on LCD
// 函数: void ClearLine(u8 row)
// 描述: 清除1行
// 参数: row: 行(0或1)
// 版本: VER1.0
// 日期: 2013-4-1
// 备注:
u8 i;
Write_CMD(((row & 1) << 6) | 0x80);
for(i=0; i<LineLength; i++) Write_DIS_Data(' ');
// 函数: void WriteChar(u8 row, u8 column, u8 dat)
// 描述: 指定行、列和字符, 写一个字符
// 参数: row: 行(0或1), column: 第几个字符(0~15), dat: 要写的字符.
// 版本: VER1.0
// 日期: 2013-4-1
// 备注:
Write_CMD((((row & 1) << 6) + column) | 0x80);
Write_DIS_Data(dat);
// 函数: void PutString(u8 row, u8 column, u8 *puts)
// 描述: 写一个字符串,指定行、列和字符串首地址
// 参数: row: 行(0或1), column: 第几个字符(0~15), puts: 要写的字符串指针.
// 版本: VER1.0
// 日期: 2013-4-1
// 备注:
for ( ; *puts != 0; puts++) //遇到停止符0结束
Write_DIS_Data(*puts);
if(++column >= LineLength) break;
//******************** LCD20 Module END ***************************
