查看: 1138|回复: 5
8H1K17 RST 设置为普通IO 不能正常工作
  • 打卡总天数:4
  • 最近打卡:2026-03-07 08:29:17
发表于 2025-3-10 13:31:14 | 显示全部楼层 |阅读模式
8H1K17 RST 设置为普通IO  在while 前不能正常控制  IO电平翻转。 while 循环中,可以控制。代码如下:
void GIPO_Config(void)
        BUZZ = 1;
        Relay = 0;
        P1M0 = 0xc0; P1M1 = 0x00;
    P1PU = 0xc0;
//        P1M0 = 0xe4; P1M1 = 0x00;
//  P1PU = 0xe4;
        P3M0 = 0x70; P3M1 = 0x00;
    P3PU = 0x00;
        P5M0 = 0x10; P5M1 = 0xef;
    P5PU = 0x00;
void Timer0_init(void)
        AUXR |= 0x80;                        //定时器时钟1T模式
        TMOD &= 0xF0;                        //设置定时器模式
//        TL0 = 0xCD;                                //设置定时初始值  1ms
//        TH0 = 0xD4;                                //设置定时初始值
        TL0 = 0x9A;                                //设置定时初始值  2ms
        TH0 = 0xA9;                                //设置定时初始值
        TF0 = 0;                                //清除TF0标志
        TR0 = 1;                                //定时器0开始计时
    ET0 = 1;                //使能定时器中断
//    EA = 1;
void System_init(void)
        GIPO_Config();
        RC52X_Init();
        RC52X_Reset();
        Timer0_init();
//        INT1_Init();
#ifdef Dubeg
        UartInit();
#endif
//        INT2_Init();
#ifndef Dubeg
        WDT_CONTR = 0x24;                           //使能看门狗,溢出时间约为1s
#endif
unsigned char IapRead(unsigned int addr)
    unsigned char dat;
    IAP_CONTR = 0x80;                           //使能IAP
    IAP_TPS = 12;                               //设置等待参数11.0592MHz
    IAP_CMD = 1;                                //设置IAP读命令
    IAP_ADDRL = addr;                           //设置IAP低地址
    IAP_ADDRH = addr >> 8;                      //设置IAP高地址
        F0 = EA;
    IAP_TRIG = 0x5a;                            //写触发命令(0x5a)
    IAP_TRIG = 0xa5;                            //写触发命令(0xa5)
        EA = F0;
    dat = IAP_DATA;                             //读IAP数据
    IapIdle();                                  //关闭IAP功能
    return dat;
u8  Read_EquipmentAddr(u8 * tempValue)
        //u8 tempValue[4];
        tempValue[0] = IapRead( UserID_address + 0);
        tempValue[1] = IapRead( UserID_address + 1);
        tempValue[2] = IapRead( UserID_address + 2);
        tempValue[3] = IapRead( UserID_address + 3);
        return 0;
        //u8 temp[4];
        System_init();
        Read_EquipmentAddr(UserID);
        SetUserID_state = 0;
//#ifndef Dubeg
//        WDT_CONTR = 0x34;                       //清看门狗,否则系统复位
//#endif
        //Uart2SendStr("Uart Test !\r\n");
#ifdef Dubeg
        Uart2SendStr(UserID,4);
#endif
        BUZZ = 0;
        delay_ms(200);
        BUZZ = 1;
        delay_ms(500);
        BUZZ = 0;
        delay_ms(200);
        BUZZ = 1;
#ifndef Dubeg
#endif
                Comm_Event_Proc();
                if(BUZZ_state == 1)
                        BUZZ = 0;
                        delay_ms(250);
                        BUZZ = 1;
                        delay_ms(500);
#ifndef Dubeg
#endif
                        BUZZ = 0;
                        delay_ms(250);
                        BUZZ = 1;
                        delay_ms(500);
#ifndef Dubeg
#endif
                        BUZZ = 0;
                        delay_ms(250);
                        BUZZ = 1;
                        BUZZ_state = 0;
#ifndef Dubeg
#endif
发表于 2025-3-10 13:33:00 | 显示全部楼层
在STC8H1K17微控制器中,RST引脚默认作为复位引脚使用。若要将其配置为普通IO引脚,需确保在初始化阶段正确设置相关寄存器。根据您提供的代码,P1M0和P1M1寄存器用于配置P1端口的模式,P1PU用于配置上拉电阻。然而,RST引脚的特殊功能可能未完全解除,导致在`while`循环前无法正常控制IO电平翻转。<br><br>建议在`GIPO_Config`函数中,明确将RST引脚配置为普通IO模式,并确保在系统初始化时完成此设置。同时,检查是否有其他寄存器或硬件配置影响了RST引脚的行为。例如,确认`RSTCFG`寄存器中RST引脚的功能选择位已正确配置为普通IO模式。此外,确保在`while`循环前有足够的延时,以等待引脚状态稳定。<br><br>[本文内容由国芯人工智能辅助生成,仅供参考]
  • 打卡总天数:729
  • 最近打卡:2026-07-10 16:55:21
发表于 2025-3-10 14:23:00 | 显示全部楼层
检查RSTCFG寄存器和IO模式
有问题的时候直接设置寄存器,#ifdef和看门狗都不要用,先排除一下这些问题,问题解决了再逐一还原
  • 打卡总天数:895
  • 最近打卡:2026-07-21 08:17:05
发表于 2025-3-11 16:00:29 | 显示全部楼层
楼主的情况应该是ISP软件中禁用RST复位功能,代码中没有操作过RSTCFG寄存器使能P54的RST功能。
同时,楼主的代码中也没看到控制P54电平翻转的代码呀
  • 打卡总天数:4
发表于 2025-3-17 09:16:42 | 显示全部楼层
Debu*** 发表于 2025-3-10 14:23
检查RSTCFG寄存器和IO模式
有问题的时候直接设置寄存器,#ifdef和看门狗都不要用,先排除一下这些问题,问 ...
需要在代码中设置 RSTCFG  将RST 设置成普通IO
  • 打卡总天数:4
发表于 2025-3-17 09:17:16 | 显示全部楼层
同时,楼主 ...
GMT+8, 2026-7-23 18:28 , Processed in 0.097081 second(s), 67 queries .
