查看: 2150|回复: 12
AI8H1K08 自己定义的内部时钟源测试一直不准
  • 打卡总天数:15
  • 最近打卡:2025-03-26 09:09:59
发表于 2024-9-26 16:05:51 | 显示全部楼层 |阅读模式
想请假下,为什么我自己定义的内部时钟源24M 一直不准
#include "STC8Hxxx.h"       //包含此头文件后,不需要再包含"reg51.h"头文件
#include "test.h"
程序使用
AIN1-P1.1
AIN2-P1.2
BIN1-P1.5
BIN2-P3.4
驱动步进电机
sfr     VRTRIM  =   0xA6;
#define CKSEL           (*(unsigned char volatile xdata *)0xfe00)
#define CKDIV           (*(unsigned char volatile xdata *)0xfe01)
#define IRC24MCR        (*(unsigned char volatile xdata *)0xfe02)
#define XOSCCR          (*(unsigned char volatile xdata *)0xfe03)
#define IRC32KCR        (*(unsigned char volatile xdata *)0xfe04)
#define USBCHIPID
#define CPUIDBASE   0xfde0
#define T22M_ADDR   (*(unsigned char volatile xdata *)(CPUIDBASE + 0x0b))   //22.1184MHz
#define T24M_ADDR   (*(unsigned char volatile xdata *)(CPUIDBASE + 0x0c))   //24MHz
#ifdef  USBCHIPID
#define T27M_ADDR   (*(unsigned char volatile xdata *)(CPUIDBASE + 0x0d))   //27MHz
#define T30M_ADDR   (*(unsigned char volatile xdata *)(CPUIDBASE + 0x0e))   //30MHz
#define T33M_ADDR   (*(unsigned char volatile xdata *)(CPUIDBASE + 0x0f))   //33.1776MHz
#define T35M_ADDR   (*(unsigned char volatile xdata *)(CPUIDBASE + 0x10))   //35MHz
#define T36M_ADDR   (*(unsigned char volatile xdata *)(CPUIDBASE + 0x11))   //36.864MHz
#define T40M_ADDR   (*(unsigned char volatile xdata *)(CPUIDBASE + 0x12))   //40MHz
#define T44M_ADDR   (*(unsigned char volatile xdata *)(CPUIDBASE + 0x13))   //44.2368MHz
#define T48M_ADDR   (*(unsigned char volatile xdata *)(CPUIDBASE + 0x14))   //48MHz
#else
#define T20M_ADDR   (*(unsigned char volatile xdata *)(CPUIDBASE + 0x0d))   //20MHz
#define T27M_ADDR   (*(unsigned char volatile xdata *)(CPUIDBASE + 0x0e))   //27MHz
#define T30M_ADDR   (*(unsigned char volatile xdata *)(CPUIDBASE + 0x0f))   //30MHz
#define T33M_ADDR   (*(unsigned char volatile xdata *)(CPUIDBASE + 0x10))   //33.1776MHz
#define T35M_ADDR   (*(unsigned char volatile xdata *)(CPUIDBASE + 0x11))   //35MHz
#define T36M_ADDR   (*(unsigned char volatile xdata *)(CPUIDBASE + 0x12))   //36.864MHz
#define T40M_ADDR   (*(unsigned char volatile xdata *)(CPUIDBASE + 0x13))   //40MHz
#define T45M_ADDR   (*(unsigned char volatile xdata *)(CPUIDBASE + 0x14))   //45MHz
#endif
#define VRT6M_ADDR  (*(unsigned char volatile xdata *)(CPUIDBASE + 0x15))   //VRTRIM_6M
#define VRT10M_ADDR (*(unsigned char volatile xdata *)(CPUIDBASE + 0x16))   //VRTRIM_10M
#define VRT27M_ADDR (*(unsigned char volatile xdata *)(CPUIDBASE + 0x17))   //VRTRIM_27M
#define VRT44M_ADDR (*(unsigned char volatile xdata *)(CPUIDBASE + 0x18))   //VRTRIM_44M
// 函数: void delay_ms(u8 ms)
// 描述: 延时函数。
// 版本: VER1.0
// 日期: 2021-3-9
// 备注:
void delay_ms(unsigned int ms)
     unsigned int i;
     do{
          i = MAIN_Fosc / 10000;
          while(--i);   //10T per loop
     }while(--ms);
void Delay1ms(void)        //@24.000MHz
        unsigned char data i, j;
        i = 24;
        j = 85;
        do
                while (--j);
        } while (--i);
void Delay10ms(void)        //@24.000MHz
        i = 234;
        j = 115;
        do
                while (--j);
        } while (--i);
        P_SW2 = 0x80;
        CKSEL = 0x00;                               //选择内部IRC ( 默认 )
        P_SW2 = 0x00;
   P0M0 = 0x00;P0M1 = 0x00;P1M0 = 0x00;P1M1 = 0x00;P2M0 = 0x00;P2M1 = 0x00;P3M0 = 0x00;P3M1 = 0x00;P4M0 = 0x00;P4M1 = 0x00;P5M0 = 0x00;P5M1 = 0x00;
    //选择24MHz
    CLKDIV = 0x04;
    IRTRIM = T24M_ADDR;
    VRTRIM = VRT27M_ADDR;
    IRCBAND &= ~0x03;
        IRCBAND |= 0x02;
        CLKDIV = 0x00;
          delay_ms(1);
          delay_ms(1);
          Delay1ms();
          Delay1ms();
  • 打卡总天数:724
  • 最近打卡:2026-03-18 07:56:47
发表于 2024-9-26 16:25:25 | 显示全部楼层
内部预置频率应该是准确的
使用AIapp-ISP-v6.94R生成延时函数,优化级别默认
  • 打卡总天数:15
发表于 2024-9-26 16:45:28 | 显示全部楼层
Debu*** 发表于 2024-9-26 16:25
内部预置频率应该是准确的
不好意思,我使用的是STC8H1K08,然后选用内部时钟源24M,我也用ISP的函数了,仍然不准,延时1ms,实测有7MS
  • 打卡总天数:746
  • 最近打卡:2026-03-24 00:01:22
发表于 2024-9-26 22:38:38 来自手机 | 显示全部楼层
huatlwangl 发表于 2024-9-26 16:45
不好意思,我使用的是STC8H1K08,然后选用内部时钟源24M,我也用ISP的函数了,仍然不准,延时1ms,实测有 ...
可以写入频率过段时间在读取寄存器查看是否写入成功。
  • 打卡总天数:15
发表于 2024-9-27 08:40:05 | 显示全部楼层
您好,读取什么寄存器
  • 打卡总天数:646
  • 最近打卡:2026-03-24 08:59:20
发表于 2024-9-27 09:07:26 | 显示全部楼层
STC8H1K08没有CHIPID寄存器,时钟参数需要从Flash空间读取:
并且烧录时需要勾选“在程序区的结束处添加重要测试参数”选项:
程序可参考规格书这个例子:
  • 打卡总天数:15
发表于 2024-9-27 09:24:08 | 显示全部楼层
大佬您好,我刚接触这个芯片,我按照您说的做了,遇到以下问题:
1.提示没有VRTRIM这个变量的定义,我自己参考CHIPID添加了这一句话sfr VRTRIM = 0xA6;
2.这是我的烧录界面。
3.下载后仍然不准和以前一样。
请问您是什么原因
  • 打卡总天数:646
发表于 2024-9-27 09:40:21 | 显示全部楼层
照搬ISP软件里的这个例子试试,这个例子也是使用STC8H1K08芯片的参数,设置24M的IRC频率:
此外可以设置主时钟分频输出功能,用示波器测量对应脚位,判断主时钟是否已经调到程序设置的频率:
  • 打卡总天数:646
发表于 2024-9-27 09:43:29 | 显示全部楼层
如果没有特殊需求的话,只要烧录时硬件选项设置好芯片运行时需要的IRC频率,
上电后硬件会自动将主频调整到指定的频率,完全不需要使用程序设置频率:
  • 打卡总天数:15
发表于 2024-9-27 09:47:11 | 显示全部楼层
上电后硬件会自动将主频调整到 ...
您的意思是说,我程序里完全不用管,什么都可以不写,只是下载程序的时候在这里选择,写入24M就可以了吗?但是我这里选择了 也不对
GMT+8, 2026-3-24 19:27 , Processed in 0.149349 second(s), 86 queries .
