楼主: liuzonggong
用220V直接给单片机供电。
 火 [复制链接]
发表于 2024-9-8 14:08:39 | 显示全部楼层
liuzon*** 发表于 2024-9-8 12:16
又想了一个办法如图:R1:1K,碳膜,1/2W,0.007元;R2:碳膜,63K,2W,0.035元;Q1,13001,7W,0.035元;5. ...
What current does your MCU need ?
63K, 2W is excessive, it can be higher than 63k - check your HFE and MCU Idd
It is ok to operate Zener lower than 5mA, the voltage droop is predictable.
13001 needs care with heat, the cheapest ones are 300-600mW MAX
At your 331V, you have about 330mW/mA, so your MCU must draw 1mA or below, unless for a very short time.
发表于 2024-9-8 14:21:58 | 显示全部楼层
想法奇特
发表于 2024-9-8 14:36:58 | 显示全部楼层
这样应该不可靠
发表于 2024-9-8 15:13:03 | 显示全部楼层
liuzon*** 发表于 2024-9-7 15:13
三块?整机成本要求要低,你这启动一下子占了一半。
 楼主| 发表于 2024-9-8 15:51:33 | 显示全部楼层
63K, 2W is excessive, it can be higher than 63k - check your HF ...
My MCU need about 10mA,for the  orther applications that I have not thought about . I think that ,20mA may be work. for that , i designed this circuit diagram.
 楼主| 发表于 2024-9-8 16:06:08 | 显示全部楼层
翻车了,13001的耗散功率到不了7W,大于7W的一块多。不行了。
发表于 2024-9-8 17:09:16 | 显示全部楼层
2W的金属膜电阻 100K的,RMB0.1,
1N4007二极管 RMB0.02,
一个5.1V稳压管 RMB0.1,
一个100uF电容,RMB0.1,
总成本 RMB0.32
睁开眼睛做场梦~~~
发表于 2024-9-8 17:38:53 | 显示全部楼层
不推荐使用2-3元/个的低价ACDC 模块,质量不太好容易坏。不需要隔离且电流不大可以用电容降压全波整流。
 楼主| 发表于 2024-9-8 18:32:48 | 显示全部楼层
晓*** 发表于 2024-9-8 17:09
2W的金属膜电阻 100K的,0.1,4007二极管 0.02,一个5.1V稳压管 0.1,一个100uF电容,0.1  总成本0.32
用100K,才3毫安,单片机启动不了,用20毫安电流的话,电阻必须分开才行要不就要用个大的水泥电阻,一个电阻涵盖所有成本了。
啥单片机需要20mA才能启动嘛  详情 回复 发表于 2024-9-8 21:28
 楼主| 发表于 2024-9-8 18:33:39 | 显示全部楼层
jxday*** 发表于 2024-9-8 17:38
不推荐使用2-3元/个的低价ACDC 模块,质量不太好容易坏。不需要隔离且电流不大可以用电容降压全波整流。 ...
贵了些,想控制在几毛钱。
GMT+8, 2026-11-9 23:10 , Processed in 0.078525 second(s), 101 queries .
