楼主: qqq363080202
STC8G1K08 ADC模拟量问题求救
发表于 2024-8-9 09:02:13 | 显示全部楼层
大*** 发表于 2024-8-8 19:33
上图中修正,部分内容
感谢大哥
  • 打卡总天数:745
  • 最近打卡:2026-03-23 00:00:20
发表于 2024-8-9 09:27:31 来自手机 | 显示全部楼层
taihang 发表于 2024-8-8 19:00
P3口直接10进制啊,没认真看还不知道干嘛。
  • 打卡等级:常住居民I
  • 打卡总天数:77
  • 最近打卡:2025-02-19 19:46:19
发表于 2024-8-9 10:07:31 | 显示全部楼层
系统自动转换,此程序经实测通过。
  • 打卡总天数:568
  • 最近打卡:2026-03-23 06:06:36
发表于 2024-8-9 18:59:27 | 显示全部楼层
应该的,坛友不客气
发表于 2024-8-11 09:20:05 | 显示全部楼层
#include "STC8G.H"
#include "system.h"
#include "seg8display.h"
#include "STC8G_10AD.h"
#define     MAIN_Fosc       11059200UL  //¶¨ÒåÖ÷ʱÖÓ
#define Timer0_Reload   (MAIN_Fosc / 1000)      //Timer 0 ÖÐ¶ÏÆµÂÊ, 1000´Î/Ãë
u8 t0_ct;
int vcc,vcc_1;
bit AD_change_bit,key_1_bit;
sbit        LED_8 = P3^7;
sbit        LED_7 = P3^6;
sbit        LED_6 = P3^5;
sbit        LED_5 = P3^4;
sbit                          LED_4 = P3^3;
sbit                          LED_3 = P3^2;
sbit                          LED_2 = P3^1;
sbit                          LED_1 = P3^0;
sbit        key_1 = P1^7;
void IO_init_config(void);
                P0M1 = 0x00;
                P0M0 = 0x00;;   //P0ÉèÖÃΪ׼˫Ïò¿Ú
                P1M1 = 0x00;
                P1M0 = 0x00;;   //P1ÉèÖÃΪ׼˫Ïò¿Ú
                P2M1 = 0x00;
                P2M0 = 0x00;;   //P2ÉèÖÃΪ׼˫Ïò¿Ú
                P3M1 = 0x00;
                P3M0 = 0x00;;   //P3ÉèÖÃΪ׼˫Ïò¿Ú
                P4M1 = 0x00;
                P4M0 = 0x00;;   //P4ÉèÖÃΪ׼˫Ïò¿Ú
                P5M1 = 0x00;
                P5M0 = 0x00;;   //P5ÉèÖÃΪ׼˫Ïò¿Ú
void timer0_int (void) interrupt 1  //¶¨Ê±ÖжϷ½Ê½//
        Display_seg(); //1MSɨÃè
        if(++t0_ct >= 100)  //0.1SÉÁ˸һ´Î
        {        t0_ct = 0;        AD_change_bit = 1;}
//8888888888888888888888888888888888888888888888888888888888888888888888888888888//
void main()//Ö÷³ÌÐò
{        IO_init_config();STC8G_ADC_Iint();
    TR0 = 0;    //Í£Ö¹¼ÆÊý
    ET0 = 1;    //ÔÊÐíÖжÏ
    TMOD &= ~0x03;
    TMOD |= 0;  //¹¤×÷ģʽ, 0: 16λ×Ô¶¯ÖØ×°,
    TMOD &= ~0x04;  //¶¨Ê±
    INTCLKO &= ~0x01;  //²»Êä³öʱÖÓ
    AUXR &= ~0x80;  //12T mode
    TH0 = (u8)((65536UL - Timer0_Reload/12) / 256);
    TL0 = (u8)((65536UL - Timer0_Reload/12) % 256);
    TR0 = 1;
        {//AD_change_bit ½Óͨһ´Î¾ÍÑ­»··¢ËÍÒ»´ÎÊý¾Ýµ½ÊýÂë¹Ü,¼ä¸ôʱ¼äÓÉtimer0_int¾ö¶¨//
                 if (key_1 == 0)     {if (key_1_bit == 1)  {key_1_bit = 0;  } else  {key_1_bit = 1; }   while(key_1 == 0); }//µ¥°´¼üÇл»on¡¢off//
                 if  (key_1_bit)   { AD_change_bit = 0;    Display_Buff();     vcc_1=(ADC_RES<<8)|ADC_RESL;    vcc = vcc_1*4;}//ÏÔʾģʽ1
                 else{Display_Buffee();vcc_1=(ADC_RES<<8)|ADC_RESL;    vcc = vcc_1*4;}                                        //ÏÔʾģʽ2
                 if       (vcc > 800){LED_8 = 0; LED_7 = 0; LED_6 = 0; LED_5 = 0; LED_4 = 0; LED_3 = 0; LED_2 = 0; LED_1 = 0; }//¸ù¾Ýµçѹ´óСµãÁÁ²»Í¬LED
     else if (vcc > 700){LED_8 = 1; LED_7 = 0; LED_6 = 0; LED_5 = 0; LED_4 = 0; LED_3 = 0; LED_2 = 0; LED_1 = 0; }
     else if (vcc > 600){LED_8 = 1; LED_7 = 1; LED_6 = 0; LED_5 = 0; LED_4 = 0; LED_3 = 0; LED_2 = 0; LED_1 = 0; }
     else if (vcc > 500){LED_8 = 1; LED_7 = 1; LED_6 = 1; LED_5 = 0; LED_4 = 0; LED_3 = 0; LED_2 = 0; LED_1 = 0; }
     else if (vcc > 400){LED_8 = 1; LED_7 = 1; LED_6 = 1; LED_5 = 1; LED_4 = 0; LED_3 = 0; LED_2 = 0; LED_1 = 0; }
           else if (vcc > 300){LED_8 = 1; LED_7 = 1; LED_6 = 1; LED_5 = 1; LED_4 = 1; LED_3 = 0; LED_2 = 0; LED_1 = 0; }
                 else if (vcc > 200){LED_8 = 1; LED_7 = 1; LED_6 = 1; LED_5 = 1; LED_4 = 1; LED_3 = 1; LED_2 = 0; LED_1 = 0; }
           else if (vcc > 100){LED_8 = 1; LED_7 = 1; LED_6 = 1; LED_5 = 1; LED_4 = 1; LED_3 = 1; LED_2 = 1; LED_1 = 0; }
                 else if (vcc > 000){LED_8 = 1; LED_7 = 1; LED_6 = 1; LED_5 = 1; LED_4 = 1; LED_3 = 1; LED_2 = 1; LED_1 = 1; }
这是其中一部分程序
最终在STC找了个ADC数码管显示模拟量的 修改了下可以符合我的要求
  • 打卡总天数:272
  • 最近打卡:2026-03-23 07:57:52
发表于 2025-9-28 20:01:19 | 显示全部楼层
哈哈 祝你成功
  • 打卡总天数:131
  • 最近打卡:2026-03-23 01:12:59
发表于 2026-1-26 06:38:38 | 显示全部楼层
大佬们很热心啊。
GMT+8, 2026-3-23 23:13 , Processed in 0.109451 second(s), 77 queries .
