- #ifndef STC8_H
- #define STC8_H
- #include <STC8G.H>
- #endif
- #include<intrins.h>
- #include "Timer0.h"
- //以12MHZ烧录
- void Delay3000ms(void) //@11.0592MHz
- unsigned char data i, j, k;
- _nop_();
- i = 169;
- j = 80;
- k = 87;
- do
- do
- while (--k);
- } while (--j);
- } while (--i);
- void main()
- P5M0 |= 0x10; P5M1 &= ~0x10;
- Timer0_Init();
- P54 = 0;
- while(1)
- SendCode(0xfc,0xAf);//1111 1100 0110 1001
- Delay3000ms();
- #ifndef STC8_H
- #define STC8_H
- #endif
- bit OP=0; //红外发射管的亮灭控制位
- unsigned int count =0; //载波发射时间
- unsigned int Lcount =0; //发射载波后,等待的时间
- void Timer0_Init(void) //26微秒@12.000MHz
- AUXR &= 0x7F; //定时器时钟12T模式
- TMOD &= 0xF0; //设置定时器模式
- TL0 = 0xE6; //设置定时初始值
- TH0 = 0xFF; //设置定时初始值
- TF0 = 0; //清除TF0标志
- TR0 = 1; //定时器0开始计时
- ET0 = 1;
- EA = 1;
- void SendSingleCode(unsigned char _code)
- while (Lcount>0);//直到当前不在发射数据
- switch (_code)
- case 0://560/26=21.6,560/26=21.6
- count = 22;
- Lcount = 22;
- break;
- case 1://560/26=21.6,1690/26=65
- count = 22;
- Lcount = 65;
- break;
- case 2://引导码 9000/26=346,4500/26=173
- count = 346;
- Lcount = 173;
- break;
- case 3://重复码 9000/26=346,2250/26=86.5
- count = 346;
- Lcount = 87;
- break;
- case 4://最后一位时,需要给个短暂的高电平,让接收端识别出最后一位的时间
- count = 10;
- break;
- case 5://最后保持一定时间的低电平,用于重复码过短的问题
- Lcount = 3800;
- break;
- void SendStart()
- SendSingleCode(2);
- void SendRepeat()
- SendSingleCode(3);
- SendSingleCode(4);//短暂的高电平
- SendSingleCode(5);//长时间的低电平
- <font color="#ff8c00">void test()
- SendStart();
- SendSingleCode(0);
- SendSingleCode(1);
- }</font>
- <font color="#ff0000">void SendCode(unsigned char _address,unsigned char _command)//地址码,命令码
- unsigned char temp ,i;
- SendStart();
- for (i = 0; i < 8; i++)
- temp = _address>>i;
- temp &= 0x01;
- SendSingleCode(temp);
- temp &= 0x01;
- temp = ~temp;
- temp = _command>>i;
- temp &= 0x01;
- temp &= 0x01;
- temp = ~temp;
- }</font>
- void timeint(void) interrupt 1
- if (count>0) //如果是待发送的有效数据flag=1,就在此产生载波(亮灭交变)
- OP=~OP;
- count--;
- else
- OP = 0; //发送低电平
- if (Lcount>0)
- Lcount--;
- P54 = OP; //往发射模块的 IO口发送出去
复制代码 问题挺奇怪的,看我代码标红的部分,我用了4个for循环分别发送地址码,地址反码,命令码,命令反码
发送的地址码和命令码分别是0xfc,0xAf
但是接收端只能收到16位数据,正常应该是32位啊,而且正好是反码没有
我又写了个test(),一位一位的发,不用for循环,又正常了
所以我想知道是不是什么导致for循环出问题了
