查看: 3937|回复: 4
STC8H8K64U把电容触摸I2C转成USB信号-多点问题
发表于 2023-2-5 23:06:36 | 显示全部楼层 |阅读模式
各位大佬,用STC8H8K遇到如下问题,有了解的帮忙提供下解决思路,有参考例程的最好了,谢谢!
背景:基于STC8 USB 鼠标例程已经调通触摸屏单点触控,需求是实现触摸屏I2C转USB 多点触控(支持5指或10指)
问题:在单点触控程序基础上主要修改HID Report Descriptor,Win7上USBLyzer上可以收到触摸屏上的坐标数据(上图以2指触控为例),但只能识别一指划线效果,切换到Win11上表现为完全无反应(装USBLyzer后USB无法抓数据,因此未测此时USB数据)
1、         请问这种情况应该如何解决?用的的描述符如下
ConnectionStatus Device connected
CurrentConfiguration 1
Speed Full (12Mbit/s)
Device Address 4
Number Of OpenPipes 4
DeviceDescriptor STC USB Mouse
Offset FieldSize Value Description
0 bLength 112h
1bDescriptorType 1 01h Device
2 bcdUSB 2 0200hUSB Spec 2.0
4 bDeviceClass 100h Class info in Ifc Descriptors
5bDeviceSubClass 1 00h
6bDeviceProtocol 1 00h
7bMaxPacketSize0 1 40h 64 bytes
8 idVendor 2EEEFh
10 idProduct 22828h
12 bcdDevice 20000h 0.00
14 iManufacturer1 01h "STC"
15 iProduct 102h "STC USB Mouse"
16 iSerialNumber1 00h
17bNumConfigurations 1 01h
ConfigurationDescriptor 1 Bus Powered, 100 mA
0 bLength 109h
1bDescriptorType 1 02h Configuration
2 wTotalLength 20049h
4 bNumInterfaces1 02h
5bConfigurationValue 1 01h
6 iConfiguration1 00h
7 bmAttributes 1A0h Bus Powered, Remote Wakeup
4..0: Reserved ...00000
5: Remote Wakeup  ..1..... Yes
6: Self Powered  .0...... No, Bus Powered
7: Reserved (set to one)
(bus-powered for1.0)  1.......
8 bMaxPower 132h 100 mA
InterfaceDescriptor 0/0 HID, 2 Endpoints
0 bLength 109h
1bDescriptorType 1 04h Interface
2 bInterfaceNumber1 00h
3bAlternateSetting 1 00h
4 bNumEndpoints1 02h
5bInterfaceClass 1 03h HID
6bInterfaceSubClass 1 01h Boot Interface
7bInterfaceProtocol 1 02h Mouse
8 iInterface 100h
HID Descriptor
0 bLength 109h
1bDescriptorType 1 21h HID
2 bcdHID 2 0111h1.11
4 bCountryCode 100h
5bNumDescriptors 1 01h
6bDescriptorType 1 22h Report
7wDescriptorLength 2 02DFh 735 bytes
EndpointDescriptor 81 1 In, Interrupt, 5 ms
0 bLength 107h
1bDescriptorType 1 05h Endpoint
2bEndpointAddress 1 81h 1 In
3 bmAttributes 103h Interrupt
1..0: Transfer Type  ......11 Interrupt
7..2: Reserved 000000..
4 wMaxPacketSize2 0040h 64 bytes
6 bInterval 105h 5 ms
EndpointDescriptor 02 2 Out, Interrupt, 8 ms
0 bLength 107h
2bEndpointAddress 1 02h 2 Out
6 bInterval 108h 8 ms
InterfaceDescriptor 1/0 HID, 2 Endpoints
0 bLength 109h
1 bDescriptorType1 04h Interface
2bInterfaceNumber 1 01h
8 iInterface 100h
HID Descriptor
0 bLength 109h
4 bCountryCode 100h
7wDescriptorLength 2 008Eh 142 bytes
EndpointDescriptor 83 3 In, Interrupt, 8 ms
0 bLength 107h
2bEndpointAddress 1 83h 3 In
EndpointDescriptor 04 4 Out, Interrupt, 8 ms
0 bLength 107h
2bEndpointAddress 1 04h 4 Out
Interface 0 HIDReport Descriptor Touch Screen
Item Tag (Value)Raw Data
Usage Page(Digitizer) 05 0D
Usage (TouchScreen) 09 04
Collection(Application) A1 01
    Report ID (1) 85 01
    Usage (Finger) 09 22
    Collection (Logical) A1 02
        Usage (Tip Switch) 09 42
        Logical Minimum (0) 15 00
        Logical Maximum (1) 25 01
        Report Size (1) 75 01
        Report Count (1) 95 01
        Input(Data,Var,Abs,NWrp,Lin,Pref,NNul,Bit) 81 02
        Report Size (7) 75 07
        Usage (Contact Identifier) 09 51
        Usage Page (Generic Desktop) 05 01
        Report Size (16) 75 10
        Unit Exponent (-2) 55 0E
        Unit (Eng Lin: Length (in)) 65 13
        Usage (X) 09 30
        Logical Maximum (1280) 27 00 05 0000
        Physical Minimum (0) 35 00
        Physical Maximum (854) 47 56 03 0000
        Logical Maximum (800) 27 20 03 0000
        Physical Maximum (533) 47 15 02 0000
        Usage (Y) 09 31
        Usage Page (Digitizer) 05 0D
    End Collection C0
        Input (Data,Var,Abs,NWrp,Lin,Pref,NNul,Bit)81 02
        Usage (X) 09 30
        Usage (Y) 09 31
    End Collection C0
        Usage (X) 09 30
        Usage (Y) 09 31
    End Collection C0
        Usage (X) 09 30
        Usage (Y) 09 31
    End Collection C0
        Usage (X) 09 30
        Usage (Y) 09 31
    End Collection C0
        Usage (X) 09 30
        Usage (Y) 09 31
    End Collection C0
        Usage (X) 09 30
        Usage (Y) 09 31
    End Collection C0
        Usage (X) 09 30
        Usage (Y) 09 31
    End Collection C0
        Usage (X) 09 30
        Usage (Y) 09 31
    End Collection C0
        Usage (X) 09 30
        Usage (Y) 09 31
    End Collection C0
    Logical Maximum (268435455) 27 FF FF FF0F
    Report Size (32) 75 20
    Usage (Scan Time) 09 56
    Usage (Contact Count) 09 54
    Logical Maximum (127) 25 7F
    Report Size (8) 75 08
    Report ID (3) 85 03
    Usage (Contact Count Maximum) 09 55
    Usage (Device Identifier) 09 53
    Report Count (2) 95 02
    Logical Maximum (10) 25 0A
    Feature(Data,Var,Abs,NWrp,Lin,Pref,NNul,NVol,Bit) B1 02
    Report ID (68) 85 44
    Usage Page (Vendor-Defined 1) 06 00 FF
    Usage (Vendor-Defined 197) 09 C5
    Logical Maximum (255) 26 FF 00
    Report Count (256) 96 00 01
End CollectionC0
Interface 1 HIDReport Descriptor Vendor-Defined 1
Usage Page(Vendor-Defined 256) 06 FF FF
Usage(Vendor-Defined 1) 09 01
    Usage (Vendor-Defined 2) 09 02
    Usage (Vendor-Defined 3) 09 03
    Report ID (2) 85 02
    Report Count (63) 95 3F
    Usage (Vendor-Defined 4) 09 04
    Usage (Vendor-Defined 5) 09 05
    Output(Data,Var,Abs,NWrp,Lin,Pref,NNul,NVol,Bit) 91 02
    Usage (Vendor-Defined 6) 09 06
    Usage (Vendor-Defined 7) 09 07
    Report ID (241) 85 F1
    Report Count (7) 95 07
    Usage (Vendor-Defined 8) 09 08
    Usage (Vendor-Defined 9) 09 09
    Report ID (242) 85 F2
    Usage (Vendor-Defined 10) 09 0A
    Usage(Vendor-Defined 11) 09 0B
    Report ID (243) 85 F3
    Usage (Vendor-Defined 12) 09 0C
    Usage (Vendor-Defined 13) 09 0D
    Report ID (244) 85 F4
    Usage (Vendor-Defined 14) 09 0E
    Usage (Vendor-Defined 15) 09 0F
    Report ID (245) 85 F5
    Usage (Vendor-Defined 16) 09 10
    Usage (Vendor-Defined 17) 09 11
    Report ID (246) 85 F6
End CollectionC0
发表于 2023-2-6 13:26:27 | 显示全部楼层
我们研究一下,实现您的功能,需要一些时间。届时会回复您:loveliness:
发表于 2023-10-11 17:31:43 | 显示全部楼层
可以了吗?正好需要一份!可以发一下份吗?感谢
发表于 2023-10-24 22:49:10 | 显示全部楼层
搞定了吗?
  • 打卡总天数:1
  • 最近打卡:2024-05-31 10:55:24
发表于 2024-5-31 11:52:04 | 显示全部楼层
报告描述符是用什么工具写的?
GMT+8, 2026-7-23 21:26 , Processed in 0.081531 second(s), 70 queries .
