查看: 1572|回复: 11
.h的代码长度有限制吗?
  • 打卡总天数:648
  • 最近打卡:2026-03-23 08:53:06
发表于 2024-5-26 10:13:48 | 显示全部楼层 |阅读模式
//unsigned char code tyk[] =                  // 数据表
//    0xF8, 0xFC, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
//    0xFF, 0xFF, 0xFF, 0xFF, 0x7F, 0x3F, 0x9F, 0xDF,
//    0x9F, 0x3F, 0x3F, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF,
//    0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xFC, 0xF8, 0x00,
//    0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x1F, 0x0F,
//    0xE7, 0xF3, 0xF9, 0x3C, 0x3E, 0x3F, 0x3F, 0x3F,
//    0x3F, 0x3F, 0x7E, 0xFC, 0xF9, 0xE3, 0xC7, 0x0F,
//    0x1F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x00,
//    0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00,
//    0xFF, 0xFF, 0xFF, 0x7F, 0x00, 0x3F, 0x7F, 0x7F,
//    0x3F, 0x1E, 0x00, 0x80, 0xFF, 0xFF, 0xFF, 0x00,
//    0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x00,
//    0x0F, 0x1F, 0x3F, 0x7F, 0x7F, 0x7F, 0x7C, 0x7C,
//    0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F,
//    0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7C,
//    0x7C, 0x7F, 0x7F, 0x7F, 0x3F, 0x1F, 0x0F, 0x00
//10*24点大字数字 取码方式:阴码,列行式,逆向
//unsigned char code num0[] =                  // 数据表
//    0xFC, 0xFE, 0xFF, 0x0F, 0x07, 0x07, 0x0F, 0xFF,
//    0xFE, 0xFC, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00,
//    0x00, 0xFF, 0xFF, 0xFF, 0x0F, 0x1F, 0x3F, 0x3C,
//    0x38, 0x38, 0x3C, 0x3F, 0x1F, 0x0F
unsigned char code num1[] =                  // 数据表
    0x00, 0x18, 0x18, 0x1C, 0xFE, 0xFF, 0xFF, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF,
    0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x38, 0x38,
    0x3F, 0x3F, 0x3F, 0x38, 0x38, 0x00
unsigned char code num2[] =                  // 数据表
    0x3C, 0x3E, 0x3F, 0x0F, 0x07, 0x07, 0x8F, 0xFF,
    0xFE, 0xFC, 0x00, 0x00, 0x80, 0xE0, 0xF8, 0x7E,
    0x1F, 0x07, 0x01, 0x00, 0x38, 0x3E, 0x3F, 0x3F,
    0x39, 0x38, 0x38, 0x38, 0x38, 0x38
unsigned char code num3[] =                  // 数据表
    0x3C, 0x3E, 0x3F, 0x0F, 0x07, 0x07, 0x0F, 0xFF,
    0xFE, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x0E, 0x0E,
    0x1F, 0xFF, 0xFB, 0xF1, 0x0E, 0x1E, 0x3E, 0x3C,
unsigned char code num4[] =                  // 数据表
    0x00, 0x00, 0x00, 0xC0, 0xF8, 0xFF, 0xFF, 0xFF,
    0x00, 0x00, 0x80, 0xF0, 0xFE, 0x3F, 0x07, 0xFF,
    0xFF, 0xFF, 0x00, 0x00, 0x07, 0x07, 0x07, 0x07,
    0x07, 0x3F, 0x3F, 0x3F, 0x07, 0x07
unsigned char code num5[] =                  // 数据表
    0xFF, 0xFF, 0xFF, 0x87, 0x87, 0x87, 0x87, 0x87,
    0x07, 0x07, 0x0F, 0x0F, 0x0F, 0x07, 0x03, 0x03,
    0x07, 0xFF, 0xFF, 0xFE, 0x0E, 0x1E, 0x3E, 0x3C,
unsigned char code num6[] =                  // 数据表
    0xFC, 0xFE, 0xFF, 0x0F, 0x07, 0x07, 0x0F, 0x3F,
    0x3E, 0x3C, 0xFF, 0xFF, 0xFF, 0x0F, 0x07, 0x07,
    0x0F, 0xFF, 0xFE, 0xFC, 0x0F, 0x1F, 0x3F, 0x3C,
unsigned char code num7[] =                  // 数据表
    0x07, 0x07, 0x07, 0x07, 0x07, 0x07, 0xE7, 0xFF,
    0xFF, 0x3F, 0x00, 0x00, 0x00, 0xC0, 0xF8, 0xFF,
    0x1F, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3F,
    0x3F, 0x3F, 0x00, 0x00, 0x00, 0x00
//unsigned char code num8[] =                  // 数据表
//    0xFE, 0xFC, 0xFB, 0xFF, 0xFF, 0x1F, 0x0E, 0x0E,
//    0x1F, 0xFF, 0xFF, 0xFB, 0x0F, 0x1F, 0x3F, 0x3C,
//unsigned char code num9[] =                  // 数据表
//    0xFE, 0xFC, 0x0F, 0x1F, 0x3F, 0x3C, 0x38, 0x38,
//    0x3C, 0xFF, 0xFF, 0xFF, 0x0F, 0x1F, 0x3F, 0x3C,
unsigned char code strA[] =                  // 数据表
    0x00, 0x00, 0xC0, 0xF0, 0xC0, 0x00, 0x00, 0x00, // -A-
    0x30, 0x3E, 0x07, 0x04, 0x07, 0x3E, 0x30, 0x00
unsigned char code strV[] =                  // 数据表
    0x30, 0xF0, 0x80, 0x00, 0x80, 0xF0, 0x30, 0x00, // -V-
    0x00, 0x01, 0x0F, 0x3C, 0x0F, 0x01, 0x00, 0x00
unsigned char code strPoint[] =                  // 数据表
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x18, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00 //. 14
unsigned char code strW[] =                  // 数据表
    0xF0, 0xF0, 0x00, 0x00, 0x00, 0xF0, 0xF0, 0x00, // -W-
    0x0F, 0x3F, 0x38, 0x0E, 0x38, 0x3F, 0x0F, 0x00 //15
//unsigned char code strO[] =                  // 数据表
//    0x80, 0x40, 0x20, 0x20, 0x20, 0x40, 0x80, 0x00, // -O-
//    0x23, 0x24, 0x38, 0x00, 0x38, 0x24, 0x23, 0x00 //16
//unsigned char code TC[] =                  // 摄氏度符号
//    0x02, 0x05, 0x02, 0x38, 0x44, 0x82, 0x82, 0x44
//unsigned char code ONE1[] =                  // 序号1符号
//    0x00, 0x00, 0x42, 0x7F, 0x40, 0x00, 0x00, 0x00 /*"1"*/
//unsigned char code TWO2[] =                  // 序号2符号
//    0x00, 0x00, 0xC4, 0xA2, 0x92, 0x8C, 0x00, 0x00 /*"2"*/
//unsigned char code SHU16x16[] =                  // "数”
//    0x90, 0x52, 0x34, 0x10, 0xFF, 0x10, 0x34, 0x52,
//    0x80, 0x70, 0x8F, 0x08, 0x08, 0xF8, 0x08, 0x00,
//    0x82, 0x9A, 0x56, 0x63, 0x22, 0x52, 0x8E, 0x00,
//    0x80, 0x40, 0x33, 0x0C, 0x33, 0x40, 0x80, 0x00, /*"数",28*/
//unsigned char code KONG16x16[] =
//        0x10,0x10,0x10,0xFF,0x90,0x20,0x98,0x48,0x28,0x09,0x0E,0x28,0x48,0xA8,0x18,0x00,
//        0x02,0x42,0x81,0x7F,0x00,0x40,0x40,0x42,0x42,0x42,0x7E,0x42,0x42,0x42,0x40,0x00,/*"控",1*/
//unsigned char code DIAN16x16[] =
//        0x00,0x00,0xF8,0x88,0x88,0x88,0x88,0xFF,0x88,0x88,0x88,0x88,0xF8,0x00,0x00,0x00,
//        0x00,0x00,0x1F,0x08,0x08,0x08,0x08,0x7F,0x88,0x88,0x88,0x88,0x9F,0x80,0xF0,0x00,/*"电",2*/
//unsigned char code YUAN16x16[] =
//        0x10,0x60,0x02,0x8C,0x00,0xFE,0x02,0xF2,0x52,0x5A,0x56,0x52,0x52,0xF2,0x02,0x00,
//        0x04,0x04,0x7E,0x41,0x30,0x0F,0x20,0x13,0x49,0x81,0x7F,0x01,0x09,0x13,0x20,0x00,/*"源",3*/
这段代码随意注释掉一部分液晶屏都可正常,全部上的话液晶屏第一个字符会乱码。不知道是什么问题,求大佬们看下
  • 打卡总天数:746
  • 最近打卡:2026-03-24 00:01:22
发表于 2024-5-26 10:36:56 来自手机 | 显示全部楼层
这个大小没有限制吧
  • 打卡总天数:648
发表于 2024-5-26 10:42:38 | 显示全部楼层
so*** 发表于 2024-5-26 10:36
这个大小没有限制吧
就是不知道什么问题,多加一行就会出乱码,我任意注释掉一部分代码就能正常显示,感觉跟长度有关系,代码分开试的话都能正常显示
  • 打卡总天数:839
  • 最近打卡:2026-03-24 02:11:55
发表于 2024-5-26 11:07:05 | 显示全部楼层
mtia*** 发表于 2024-5-26 10:42
就是不知道什么问题,多加一行就会出乱码,我任意注释掉一部分代码就能正常显示,感觉跟长度有关系,代码 ...
可能是flash溢出了,注意一下
  • 打卡总天数:632
  • 最近打卡:2026-03-23 20:57:52
发表于 2024-5-26 11:15:04 | 显示全部楼层
理论上.h大小没限制,实际上编译器很有可能有限制。当然,普通情况下应该也不会用到超出限制的。
你这些内容不应该写在.h文件里,应该写在.c里。
  • 打卡总天数:842
  • 最近打卡:2026-03-24 07:50:47
发表于 2024-5-26 12:03:01 | 显示全部楼层
这个没有限制吧
  • 打卡总天数:646
  • 最近打卡:2026-03-24 09:15:35
发表于 2024-5-27 09:24:58 | 显示全部楼层
你这些内 ...
只调用一次,问题不大。
如果写在.c里面和驱动一起不觉得乱么,,,如果分开写感觉又有点儿拖沓。。当然可能也是我先入为主的观念了
  • 打卡总天数:632
发表于 2024-5-27 22:31:24 | 显示全部楼层
_奶*** 发表于 2024-5-27 09:24
只调用一次,问题不大。
如果写在.c里面和驱动一起不觉得乱么,,,如果分开写感觉又有点儿拖沓。。当然 ...
一个项目分多个c文件是好习惯
  • 打卡总天数:537
  • 最近打卡:2026-03-18 09:40:02
发表于 2024-5-28 07:56:15 | 显示全部楼层
编译信息发出来,让大家分析看看.还有就是用的哪个芯片,看看是不是溢出.
  • 打卡总天数:778
  • 最近打卡:2026-03-24 09:02:14
发表于 2024-5-28 08:54:08 | 显示全部楼层
没听说,没遇到过.h大小限制的情况。
具体原因要结合你其他代码看,方便的话放上来让大家一起看看吧
GMT+8, 2026-3-24 16:20 , Processed in 0.125793 second(s), 100 queries .
