查看: 2318|回复: 11
求助!这个功能怎么写完成的速度快
  • 打卡等级:偶尔看看II
  • 打卡总天数:21
  • 最近打卡:2026-01-25 19:48:45
发表于 2024-5-19 21:55:57 | 显示全部楼层 |阅读模式
我想完成这样的功能,
在一个数组中,根据index的值,取出相应位的值输出到管脚。我写了一段程序,根据iIndex的值,读取aiData[]中的某个位输出到P03,
用逻辑分析仪测量P01信号,从取数据到输出大约要2.5us,STC32G@33.1776M
请高手指导,有没有办法更快一些。
#include <STC32G.H>
volatile unsigned char aiData[] = {0x1,0x3,0x7,0xF,0x1F,0x3F,0x7F,0xFF};
volatile unsigned char iIndex;
volatile unsigned char iIndexa;
volatile unsigned char iByte;
volatile unsigned char iBit;
        WTST = 0;
        EAXFR = 1;
        CKCON = 0;
        P0M1 = 0xF0;
        P0M0 = 0x00;
        EA = 0;
        iIndex = 0;
                if (iIndex > 63)
                        iIndex = 0;
                        P03 = 0;
                P01 = 0;
                iIndexa = 63 - iIndex;
                iByte = iIndexa / 8;
                iBit = iIndexa % 8;
                if ((1<<(iBit)) & (aiData[iByte]))
                        P03 = 1;
                        P03 = 0;
                P01 = 1;
                iIndex++;
  • 打卡等级:偶尔看看II
  • 打卡总天数:21
发表于 2024-5-19 22:10:42 | 显示全部楼层
移位改查表,快了
#include <STC32G.H>
volatile unsigned char aiFlag[] = {0x1,0x2,0x4,0x8,0x10,0x20,0x40,0x80};
        WTST = 0;
        EAXFR = 1;
        CKCON = 0;
        P0M1 = 0xF0;
        P0M0 = 0x00;
        EA = 0;
        iIndex = 0;
                if (iIndex > 63)
                        iIndex = 0;
                        P03 = 0;
                P01 = 0;
                iBit = iIndexa % 8;
                if (aiFlag[iBit] & aiData[iByte])
                        P03 = 1;
                        P03 = 0;
                P01 = 1;
                iIndex++;
  • 打卡等级:偶尔看看II
  • 打卡总天数:21
发表于 2024-5-19 22:19:39 | 显示全部楼层
                P03 = aiFlag[iBit] & aiData[iByte];
//                if (aiFlag[iBit] & aiData[iByte])
//                        P03 = 1;
//                else
//                        P03 = 0;
这样又快了,请高手帮忙看看,还有办法提速吗?
  • 打卡总天数:537
  • 最近打卡:2026-03-18 09:40:02
发表于 2024-5-20 00:44:47 | 显示全部楼层
  1. //都查表了,内存又那么大,直接来个大点的数组好了
  2. aiData[]={
  3.     0,0,0,0,0,0,0,1,//0x01
  4.     0,0,0,0,0,0,1,1,//0x03
  5.     0,0,0,0,0,1,1,1,//0x07
  6.     0,0,0,0,1,1,1,1,//0x0f
  7.     //0x1f
  8.     //0x3f
  9.     //0x7f
  10.     //0xff
  11. }
  • 打卡等级:偶尔看看II
  • 打卡总天数:21
发表于 2024-5-20 00:46:03 | 显示全部楼层
#include <STC32G.H>
//bit abtData[8];
volatile unsigned int iIndex;
volatile unsigned int iIndexa;
volatile unsigned int iByte;
volatile unsigned int iBit;
        WTST = 0;
        EAXFR = 1;
        CKCON = 0;
        P0M1 = 0xF0;
        P0M0 = 0x00;
        EA = 0;
        iIndex = 0;
                if (iIndex > 63)
                        iIndex = 0;
                        P03 = 0;
                P01 = 0;
                iByte = iIndexa >> 3;
                iBit = iIndexa & 0x7;
//                        P03 = 1;
//                else
//                        P03 = 0;
                P01 = 1;
                iIndex++;
换成int型,用移位代替除法,用与取代取余,目前速度最快,1us不到了,还能快吗?
  • 打卡总天数:10
  • 最近打卡:2025-11-11 20:31:19
发表于 2024-5-20 03:35:02 | 显示全部楼层
不管怎么运算,要想快,必须先把变量定义为data类型
  • 打卡等级:偶尔看看II
  • 打卡总天数:21
发表于 2024-5-20 06:16:12 | 显示全部楼层
aiData[]里的数据不固定,是变的,程序里只是举个粟子
  • 打卡等级:偶尔看看II
  • 打卡总天数:21
发表于 2024-5-20 06:21:49 | 显示全部楼层
变量名前加data,速度慢了120ns
  • 打卡总天数:296
  • 最近打卡:2026-01-08 10:11:26
发表于 2024-5-20 09:34:46 | 显示全部楼层
  1. #include <STC32G.H>
  2. volatile unsigned char aiData[] = {0x1,0x3,0x7,0xF,0x1F,0x3F,0x7F,0xFF};
  3. volatile unsigned char iIndex;
  4. volatile unsigned char iIndexa;
  5. volatile unsigned char edata iByte;
  6. volatile unsigned char iBit;
  7. sbit iByte0 = iByte^0;
  8. sbit iByte1 = iByte^1;
  9. sbit iByte2 = iByte^2;
  10. sbit iByte3 = iByte^3;
  11. sbit iByte4 = iByte^4;
  12. sbit iByte5 = iByte^5;
  13. sbit iByte6 = iByte^6;
  14. sbit iByte7 = iByte^7;
  15. void main()
  16. {
  17.         WTST = 0;
  18.         EAXFR = 1;
  19.         CKCON = 0;
  20.
  21.         P0M1 = 0xF0;
  22.         P0M0 = 0x00;
  23.         EA = 0;
  24.
  25.         iIndex = 0;
  26.
  27.         while (1)
  28.         {
  29.                 if (iIndex > 63)
  30.                 {
  31.                         iIndex = 0;
  32.                         P03 = 0;
  33.                 }
  34.                 P01 = 0;
  35.                 iIndexa = 63 - iIndex;
  36.                 iByte = iIndexa >> 4;
  37.                 iBit = iIndexa & 0x0F;
  38.                                 switch(iBit)
  39.                                 {
  40.                                         case 0:P03=iByte0;break;
  41.                                         case 1:P03=iByte1;break;
  42.                                         case 2:P03=iByte2;break;
  43.                                         case 3:P03=iByte3;break;
  44.                                         case 4:P03=iByte4;break;
  45.                                         case 5:P03=iByte5;break;
  46.                                         case 6:P03=iByte6;break;
  47.                                         case 7:P03=iByte7;break;
  48.                                 }
  49.                 P01 = 1;
  50.                 iIndex++;
  51.
  52.         }
  53.
  54. }
  • 打卡等级:偶尔看看II
  • 打卡总天数:21
发表于 2024-5-20 13:00:10 | 显示全部楼层
感谢,CSAE语句有选择,我想会造成执行时间有长短,但是有一个思路,应该尝试指针
GMT+8, 2026-3-24 14:47 , Processed in 0.122195 second(s), 87 queries .
