楼主 |
发表于 2024-4-23 17:19:19
显示全部楼层
#include "stc8h.h"
sbit Sda = P3^7;
sbit STAR = P3^4;
sbit keyjia = P3^3;
sbit keyjian = P3^2;
void Timer0_Init(void) //1毫秒@5.5296MHz
AUXR |= 0x80; //定时器时钟1T模式
TMOD &= 0xF0; //设置定时器模式
TL0 = 0x66; //设置定时初始值
TH0 = 0xEA; //设置定时初始值
TF0 = 0; //清除TF0标志
TR0 = 1; //定时器0开始计时
ET0 = 1; //使能定时器0中断
void Delay1ms(void) //@5.5296MHz
unsigned char data i, j;
i = 8;
j = 43;
do
while (--j);
} while (--i);
void Delay100us(void) //@5.5296MHz
unsigned char data i;
i = 182;
while (--i);
void Delay20ms(void) //@5.5296MHz
i = 144;
j = 157;
do
while (--j);
} while (--i);
void delayms(unsigned int ms)
while(--ms)
Delay1ms();
void Wait(unsigned int us)
while(--us)
Delay100us();
void on_line(unsigned char Addr)
char i;
Wait(30);
for(i=0;i<8;i++)
Sda=1;
if(Addr&1)
Wait(15);Sda=0;Wait(5);
else{
Wait(5);
Sda=0;
Wait(15);
}Addr>>=1;
}Sda=1;
bit star_bofang = 0;
void key_star()
if(STAR == 0)
Wait(300);
if(STAR == 1)
star_bofang =! star_bofang;
unsigned int jia_time = 0,jian_time = 0;
unsigned char keyjia_flag = 0,keyjian_flag = 0;
unsigned char jia_key = 0,jian_key = 0;//按键值
void key_jia()
if(keyjia == 0)
keyjia_flag = 1;
if(keyjia == 1 && jia_time<1000 && keyjia_flag == 1)
keyjia_flag = 0;
jia_time = 0;
jia_key = 1;//短按
if(keyjia == 1 && jia_time>2000 && keyjia_flag == 1)
keyjia_flag = 0;
jia_time = 0;
jia_key = 2;//长按
void key_jian()
if(keyjian == 0)
keyjia_flag = 1;
if(keyjian == 1 && jian_time<1000 && keyjian_flag == 1)
keyjian_flag = 0;
jian_time = 0;
jian_key = 1;//短按
if(keyjian == 1 && jia_time>2000 && keyjian_flag == 1)
keyjian_flag = 0;
jian_time = 0;
jian_key = 2;//长按
void pwm_init(unsigned int zhouqi,unsigned int zhankongbi)
P_SW2 = 0x80;
PWMA_CCER1 = 0x00; //写CCMRx前必须先清零CCERx关闭通道
PWMA_CCMR1 = 0x60; //设置CC1为PWMA输出模式
PWMA_CCER1 = 0x01; //使能CC1通道
PWMA_CCR1 = zhankongbi; //设置占空比时间
PWMA_ARR = zhouqi; //设置周期时间
PWMA_ENO = 0x01; //使能PWM1P端口输出
PWMA_BKR = 0x80; //使能主输出
PWMA_CR1 = 0x01; //开始计时
unsigned int PWM_zhouqi,PWM_zhankongbi = 0,zhendong = 0;
void Delay300ms(void) //@5.5296MHz
unsigned char data i, j, k;
i = 9;
j = 107;
k = 90;
do
do
while (--k);
} while (--j);
} while (--i);
unsigned char yinliang = 0xe3;
P0M0 = 0x00;
P0M1 = 0x00;
P1M0 = 0x00;
P1M1 = 0x00;
P2M0 = 0x00;
P2M1 = 0x00;
P3M0 = 0x00;
P3M1 = 0x00;
P4M0 = 0x00;
P4M1 = 0x00;
P5M0 = 0x00;
P5M1 = 0x00;
P3M0 = 0x20; P3M1 = 0x00; //电机口推挽
P3M0 &= ~0x10; P3M1 &= ~0x10;
// P3M0 |= 0x10; P3M1 |= 0x10;
on_line(0xf1);//切换到u盘
Wait(500);
on_line(0xf7);//循环播放
Wait(500);
on_line(0xe3);//音量设置 d2-f0
Timer0_Init();//1毫秒定时
//pwm_init(100,PWM_zhankongbi);
// key_star();
// key_jia();
// key_jian();
// if(!STA )
// on_line(0xfa);//播放
// zhendong = 1;
// }else{ on_line(0xfb);zhendong = 0;}//暂停
if(jia_key == 1)//短按
jia_key = 0;
PWM_zhankongbi++;
if(jian_key == 1)//短按
jia_key = 0;
PWM_zhankongbi--;
if(jia_key == 2)//长按
jia_key = 0;
yinliang++;
on_line(yinliang);//音量设置 d2-f0
if(jian_key == 2)//长按
jia_key = 0;
yinliang--;
if(P33 == 0)
Delay20ms();
if(P33 == 0)
zhendong =! zhendong;
static int i,pwm_time;
i++;
if(i>500)
P15 =! P15;
i = 0;
if(keyjia_flag == 1)//判断按下的时间
jia_time++;
if(keyjian_flag == 1)//判断按下的时间
jian_time++;
if(zhendong == 1){
pwm_time++;
if(pwm_time<PWM_zhankongbi)
P35 = 1;
if(pwm_time>PWM_zhankongbi&&pwm_time<PWM_zhouqi)
P35 = 0;
if(pwm_time>PWM_zhouqi)
pwm_time = 0;
}else P35 = 0;
