查看: 5312|回复: 11
STC8G1K08A-36I-SOP8烧录不进去固件
发表于 2023-1-18 10:04:49 | 显示全部楼层 |阅读模式
原理图: STC8G1K08A-36I-SOP8烧录不进去固件-1.png STC8G1K08A-36I-SOP8烧录不进去固件-2.png
  • 打卡总天数:360
  • 最近打卡:2026-03-24 18:18:13
844
发表于 2023-1-18 10:31:56 | 显示全部楼层
都放假了,你淘宝上买个如下工具烧录
  • 打卡总天数:360
844
发表于 2023-1-18 10:32:48 | 显示全部楼层
都放假了,你淘宝上买个如下工具烧录
  • 打卡总天数:360
844
发表于 2023-1-18 10:36:23 | 显示全部楼层
如下:第三方 USB 转串口,隔离锗二极管必须加
发表于 2023-1-18 14:10:19 | 显示全部楼层
还是不能下载
  • 打卡总天数:360
844
发表于 2023-1-18 14:20:35 | 显示全部楼层
连接到电脑的详细的原理图,你没发上来,这部分电路可能有问题,
我们已放假,你抓紧淘宝买个我们的工具,马上过节了,快递都是问题
发表于 2023-1-31 17:50:06 | 显示全部楼层
Hey
Problem with STC8G1K08A
After the firmware, the controller does not start.
  The code:
#include<reg51.h>
sbit OUT2 = P3^3;
void Delay500us()                //@11.0592MHz
        unsigned char i, j;
        i = 6;
        j = 93;
        do
                while (--j);
        } while (--i);
int main () {
        while (1) {
                OUT2 = 0;
                Delay500us();
                OUT2 = 1;
                Delay500us();
Log STC-ISP
Checking target MCU ...
  MCU type: STC8G1K08A-8PIN
  F/W version: 7.3.12U
Current H/W Option:
  . ISP-IRC frequency: 23.686MHz
  . IRC frequency: 11.058MHz
  . Wakeup Timer frequency: 35.100KHz
  . Do not detect the level of P3.2 and P3.3 next download
  . Power-on reset, use the extra power-on delay
  . RESET pin behaves as IO pin
  . Reset while detect a Low-Voltage
  . Thresh voltage level of the built-in LVD : 2.00 V
  . Hardware enable Watch-Dog-Timer when power-on reset
  . Watch-Dog-Timer pre-scalar : 256
  . Watch-Dog-Timer stop count in idle mode
  . Erase user EEPROM area at next download
  . Do not control 485 at next download
  . Do not check user password next download
  . Reference voltage: 1190 mV (Range: 1100~1300mV)
  . Testing time: 2021-8-12
Adjusting frequency ...                        [0.610"]
Adjusted frequency: 11.062MHz (0.022%)
Re-handshaking ... Successful                        [0.125"]
Current Baudrate: 115200
Erasing MCU flash ...  OK !                [0.188"]
Programming user code ... OK !                [0.062"]
Programming OPTIONS ... OK !                [0.016"]
H/W Option upgrade to:
  . IRC frequency: 11.062MHz
  . Thresh voltage level of the built-in LVD : 3.00 V
MCU ID : F794C4A304863A
  . Set frequency: 11.059MHz
  . Adjusted frequency: 11.062MHz (clock divider = 2)
  . Trim error: 0.022%
  Complete !(2023-01-31 12:47:46)
Where did the error creep in?
  • 打卡总天数:332
  • 最近打卡:2025-09-15 20:02:54
发表于 2023-1-31 18:45:05 | 显示全部楼层
Kol9*** 发表于 2023-1-31 17:50
Hey
The reference manual for STC8H in English is available here: http://www.stcmcudata.com/STC8F-DATASHEET/STC8H-EN.pdf
Please refer to section 9 I/O Ports. You have to configure your MCU IOs before using since all the IOs (except P3.0 and P3.1) are in high-impedance by default. For instance, at the beginning of your main function, add:
  1. P3M0 = 0x00; P3M1 = 0x00;
In addition, if you have any further question, you can enter the relavent mod from the index (click the bold text next to bubbles in gray or yellow) and then click "发帖" button with blue background (since it is a picture so it won't be translated). That means creating a new thread instead of replying a current one.
  • 打卡总天数:360
844
发表于 2023-1-31 18:59:32 | 显示全部楼层
OK,  success
OK,  success
  • 打卡总天数:332
发表于 2023-1-31 19:00:07 | 显示全部楼层
Hey
See STC8G manual here: www (dot) stcmcudata (dot) com . Search STC8G, and here is an item named "STC8G系列英文用户手册". Sorry for my last reply (currently security check pending ince it contains url) gave that for STC8H.
Here's an extract:
Screen Shot 2023-01-31 at 18.56.43 .png Screen Shot 2023-01-31 at 18.57.24 .png
Codes also available in stc-isp (not a tiny version):
GMT+8, 2026-3-25 13:23 , Processed in 0.115802 second(s), 86 queries .
