查看: 3090|回复: 4
STC8单片机之EV1527无线433M解码程序
发表于 2024-3-26 17:49:44 | 显示全部楼层 |阅读模式
MCU:STC8单片机
解码协议:EV1527
显示:LCD1602
单片机源程序如下:
#include "time.h"
#include "uart.h"
#include "delay.h"
#include "task.h"
unsigned char decode_ok;
unsigned int  hh_w,ll_w;
unsigned char  ma_x;
unsigned char  bma1,bma2,bma3,bma4;
unsigned char  mma1,mma2,mma3,mma4;
unsigned char mmb1,mmb2,mmb3,mmb4;
//extern uint8_t mmb1,mmb2,mmb3,mmb4;
unsigned char rf_ok1,rf_ok2,rf_ok;
unsigned char old_rc5;
unsigned char tb_ok;
unsigned char D0,D1,D2,D3 ;
unsigned int s ,s1;
unsigned char bt_auto;
unsigned char rf_data[4];
void rexode_433M(void);
//bit open_led_flag=0;
unsigned char count_5ms=0;
extern unsigned char code out[];//LED数组
extern u8 add1,spacing,mode;//地址,间隔时间,模式
void Timer0Init(void)
        TMOD|=0x00;
        TL0=65536-10;                                                //定时10ms
        TH0=(65536-10)>>8;
/////////////////////以下STC12/////////////////////
//                TL0=65536-46;                                                //定时10ms,系统时钟12分频后,定时1的时钟为2.25M,
//                TH0=(65536-46)>>8;
        TR0=1;ET0=1;        //定时器0 ,定时16位模式
        EA=1;
void timer0_interrupt(void) interrupt 1
        TL0=(65535-50)%256;                                                //定时50us,
        TH0=(65535-50)/256;
        count_5ms++;
        TX_433M_pin=~TX_433M_pin;
        rexode_433M();
        if (!RF)
                ll_w++;
                old_rc5=0;
        hh_w++;
        if (!old_rc5)
        {   // 2/5 100/130
                if (((hh_w>=2)&&(hh_w<=15))&&((ll_w>=160)&&(ll_w<=320)))
                        tb_ok = 1 ;
                        ma_x = 0;
                        bma1=0; bma2=0; bma3=0; bma4=0;
                else if ((tb_ok)&&((ll_w>=19)&&(ll_w<=33))) //8/13
                        ma_x++;
                        if(ma_x>23)
                                if(!rf_ok1)
                                        mma1=bma1;
                                        mma2=bma2;
                                        mma3=bma3;
                                        mma4=bma4;
                                        rf_ok1=1;
                                        tb_ok=0;
                                        s=10000;
                                                mmb1=bma1;
                                                mmb2=bma2;
                                                mmb3=bma3;
                                                mmb4=bma4;
                                                rf_ok2=1;
                                                tb_ok=0;
                         else if ((tb_ok)&&((ll_w>=2)&&(ll_w<=14)))   // 2/7
                                 switch (ma_x)
                                 case 0 : { bma1=bma1 | 0x01; break; }
                                 case 1 : { bma1=bma1 | 0x02; break; }
                                 case 2 : { bma1=bma1 | 0x04; break; }
                                 case 3 : { bma1=bma1 | 0x08; break; }
                                 case 4 : { bma1=bma1 | 0x10; break; }
                                 case 5 : { bma1=bma1 | 0x20; break; }
                                 case 6 : { bma1=bma1 | 0x40; break; }
                                 case 7 : { bma1=bma1 | 0x80; break; }
                                 case 8 : { bma2=bma2 | 0x01; break; }
                                 case 9 : { bma2=bma2 | 0x02; break; }
                                 case 10: { bma2=bma2 | 0x04; break; }
                                 case 11: { bma2=bma2 | 0x08; break; }
                                 case 12: { bma2=bma2 | 0x10; break; }
                                 case 13: { bma2=bma2 | 0x20; break; }
                                 case 14: { bma2=bma2 | 0x40; break; }
                                 case 15: { bma2=bma2 | 0x80; break; }
                                 case 16: { bma3=bma3 | 0x01; break; }
                                 case 17: { bma3=bma3 | 0x02; break; }
                                 case 18: { bma3=bma3 | 0x04; break; }
                                 case 19: { bma3=bma3 | 0x08; break; }
                                 case 20: { bma3=bma3 | 0x10; break; }// ?????1?
                                 case 21: { bma3=bma3 | 0x20; break; }
                                 case 22: { bma3=bma3 | 0x40; break; }
                                 case 23: { bma3=bma3 | 0x80;
                                                          if(!rf_ok1)
        mma1=bma1;
        mma2=bma2;
        mma3=bma3;
                                                           // mma4=bma4;
        rf_ok1=1;
        tb_ok=0;
//                                   bt_auto=0;
        s=10000;
        break;
        mmb1=bma1;
        mmb2=bma2;
        mmb3=bma3;
        //mmb4=bma4;
        rf_ok2=1;
        tb_ok=0;
        break;
                    ma_x++;
                 {ma_x=0; tb_ok=0;bt_auto=0;bma1=0;bma2=0; bma3=0; hh_w=1;ll_w=0;}
                 ll_w=0;hh_w=1;
             old_rc5=1;
       if(rf_ok1)
            s--;
            if(!s) rf_ok1=0;
            if(rf_ok2)
            if((mma1==mmb1)&&(mma2==mmb2)&&(mma3==mmb3))
                rf_ok=1;
                rf_ok1=0;
                rf_ok2=0;
                rf_ok=0;
                rf_ok1=0;
                rf_ok2=0;
    if((rf_ok))
        TR0=0;
        rf_ok=0;
        rf_data[0]=mma1;
        rf_data[1]=mma2;
        rf_data[2]=mma3;
                SendOneByte(rf_data[0]);
                SendOneByte(rf_data[1]);
                SendOneByte(rf_data[2]);
        decode_ok=1;
        TR0=1;
void EV1527_decoding()
        char i=0;
        /////////////////解码值////////////////////////////////
                if(decode_ok)
                         decode_ok=0;
                        switch(rf_data[2])
                                case  0x19: OUT1=~OUT1;rf_data[2]=0;break;//1号键
                                case  0x29: OUT2=~OUT2;rf_data[2]=0;break;
                                case  0x49: OUT3=~OUT3;rf_data[2]=0;break;
                                case  0x89: OUT4=~OUT4;rf_data[2]=0;break;
                                case  0x39: OUT5=~OUT5;rf_data[2]=0;break;
                                case  0x59: OUT6=~OUT6;rf_data[2]=0;break;
                                case  0xa9: OUT7=~OUT7;rf_data[2]=0;break;
                                case  0x69: OUT8=~OUT8;rf_data[2]=0;break;
                                case  0x79: OUT9=~OUT9;rf_data[2]=0;break;
                                case  0xe9: OUT10=~OUT10;rf_data[2]=0;break;//10号键
/////////////11键亮(流水)/////////12键灭(流水)////////////////////////////////////////////
                                case 0X99:   //解码                遥控器11键
                                        delay_ms(1);
                                        led=out[i];//led灯开始往后面亮delay_ms(2);//led灯开始往后面亮
                                        i++;
                                        delay_ms(spacing*100);
                                        if(i>8)//如果led灯亮完了
                                                i=8;
                                                led=0xff;rf_data[2]=0;
                                }break;
                                case 0Xd9:   //解码                遥控器12键
                                        delay_ms(1);
                                        led=out[i];//灭-》灭
                                        i--;
                                        if(i<0)
                                                i=0;led=0x00; //p35=1;
                                                rf_data[2]=0;
                                }break;
#include "time.h"
#include "uart.h"
#include "LCD1602.h"
#include "delay.h"
#include "key.h"
#include "task.h"
extern u8         xdata U1RxBuf[];
extern u8 add;
extern bit flag;
extern unsigned char Uartflag ;                          //UART判断标志位
extern char Recive_state ;   //接收完成标志
                            主函数
        InitUART();
        Timer0Init();
///////////////配置端口为双向口////////////////////////
        P1M0=0X00;
        P1M1=0X00;
        P2M0=0X00;
        P2M1=0X00;
        P3M0=0X00;
        P3M1=0X00;
        Init_LCD1602();;//lcd初始化
        delay_ms(10);
        LCD_Clear();          //清屏
//////////////////////LOGO///////////////////////////
        LCD1602_write_com(0x80);                //指针指向第1行第0个位置
        LCD1602_write_word("       BLD      ");//宝蕾德电子产品
        LCD1602_write_com(0x80+0x40);        //指针指向第2行第0个位置
        LCD1602_write_word("0~10s APPLE:S118");
        delay_ms(100);
        LCD_Clear();//清屏
        LCD1602_write_word("                 ");
        LCD1602_write_word("spacing:    s~   ");        //
//        spacing=IapRead(0x0000);         //EEPROM  读0x0000到hc[0]
//        add1=IapRead(0x0002);         //EEPROM  读0x0002到hc[1]
//        mode=IapRead(0x0004);         //EEPROM  读0x0002到hc[2]
        delay_ms(2);
        spacing_data();
        P2=0x00;
        while(1)   //无限循环
                EV1527_decoding();//解码
                display_zhu();
STC8-解码433M EV1527 串口发送OK版.rar
84.37 KB, 下载次数: 400
发表于 2025-3-18 10:52:09 来自手机 | 显示全部楼层
直接看不懂
发表于 2026-9-15 14:53:45 | 显示全部楼层
学习一下
发表于 2026-10-15 09:40:27 | 显示全部楼层
有硬件原理图吗?
发表于 2026-11-4 19:06:34 | 显示全部楼层
谢谢分享
GMT+8, 2026-11-20 07:29 , Processed in 0.070627 second(s), 72 queries .
