- 打卡等级:以坛为家I
- 打卡总天数:237
- 最近打卡:2025-09-17 09:03:31
- 积分
- 196
void ee_start( void)
ee_scl = 1 ;
ee_sda = 1 ;
delay(10) ;
ee_sda = 0 ;
delay(10) ;
ee_scl = 0 ;
delay(10) ;
void ee_stop( void)
ee_scl = 0 ;
ee_sda = 0 ;
delay(10) ;
ee_scl = 1 ;
delay(10) ;
ee_sda = 1 ;
delay(10) ;
unsigned char r_ack(void)
unsigned char ack = 0x55 ;
delay(5) ;
ee_scl = 1 ;
delay(5) ;
if(ee_sda == 0 ) ack = 0xaa ;
ee_scl = 0 ;
return ack ;
//55输出0 aa输出1
void w_ack(unsigned char ack)
if ( ack == 0x55 ) ee_sda = 0 ;
else if ( ack == 0xaa ) ee_sda = 1 ;
delay(5) ;
ee_scl = 1 ;
delay(5) ;
ee_scl = 0 ;
// ee.ack == 0xaa 表示正确
void ee_send_byte(unsigned char i)
unsigned char n = 0 ;
while ( n < 8 )
if (( i & 0x80 ) == 0x00 )
{ ee_sda = 0 ; }
{ ee_sda = 1 ; }
delay(5) ;
ee_scl = 1 ;
delay(5) ;
ee_scl = 0 ;
i = i << 1 ;
n = n + 1 ;
// 读取 ACK 位
// ack[0] = r_ack( ) ;
unsigned char ee_read_byte( )
unsigned char i ;
while ( n < 8 )
{ ee_scl = 1 ;
delay(5) ;
i = ( i << 1 ) & 0xfe ;
if ( ee_sda == 1 ) { i = i + 1 ; }
ee_scl = 0 ;
delay(5) ;
n = n + 1 ; }
return i ;
// 2408 address = 0 -- 3ff
void ee_write( unsigned char address,unsigned char dat)
ee_start( ) ;
ee_send_byte( 0xa0 ) ;
ack[0] = r_ack( ) ;
ee_send_byte( address ) ;
ack[1] = r_ack( ) ;
ee_send_byte( dat ) ;
ack[2] = r_ack( ) ;
ee_stop( ) ;
delay_ms(5) ;
//读 ACK 约使用 4ms
// delay_ms(10);
do
{ ee_start( ) ;
ack[3] = r_ack( ) ;
} while ( ack[3] == 0x55 ) ;
ee_stop( ) ;
// 读 1 BYTE 约需要 1 ms
unsigned char ee_read( unsigned char address )
unsigned char i ;
ee_start( ) ;
ack[0] = r_ack( ) ;
ack[1] = r_ack( ) ;
ee_start( ) ;
ee_send_byte( 0xa1 ) ;
ack[2] = r_ack( ) ;
i = ee_read_byte( ) ;
w_ack(0xaa) ;
ee_stop( ) ;
return i ;
void ee_read_p( unsigned char address )
ee_start( ) ;
ack[0] = r_ack( ) ;
ack[1] = r_ack( ) ;
ee_start( ) ;
ack[2] = r_ack( ) ;
a[0] = ee_read_byte( ) ;
w_ack(0x55) ;
a[1] = ee_read_byte( ) ;
w_ack(0x55) ;
a[2] = ee_read_byte( ) ;
w_ack(0x55) ;
a[3] = ee_read_byte( ) ;
w_ack(0x55) ;
a[4] = ee_read_byte( ) ;
w_ack(0x55) ;
a[5] = ee_read_byte( ) ;
w_ack(0x55) ;
a[6] = ee_read_byte( ) ;
w_ack(0x55) ;
a[7] = ee_read_byte( ) ;
w_ack(0xaa) ;
ee_stop( ) ;
#include <STC32G.H>
#include "stdio.h"
#include "config.h"
#include "base.c"
#include "2402.c"
EAXFR = 1; //扩展寄存器(XFR)访问使能
CKCON = 0; //提高访问XRAM速度
P0M1 = 0; P0M0 = 0; //设置P0.4、P0.5为漏极开路(实验箱加了上拉电阻到3.3V)
P1M1 = 0; P1M0 = 0; //设置P1.4、P1.5为漏极开路(实验箱加了上拉电阻到3.3V)
P2M1 = 0; P2M0 = 0; //设置P2.2~P2.5为漏极开路(实验箱加了上拉电阻到3.3V)
P3M1 = 0; P3M0 = 0; //设置P3.4、P3.6为漏极开路(实验箱加了上拉电阻到3.3V)
P4M1 = 0; P4M0 = 0; //设置P4.2~P4.5为漏极开路(实验箱加了上拉电阻到3.3V)
P1M0 = 0x02; P1M1 = 0x00;
// P2M0 = 0xc0; P2M1 = 0xc0;
P0M0 = 0x0c; P0M1 = 0x0c;
rs232_ini( ) ;
EA = 1; //打开总中断
//问题:单独一个BYTE读写都是对的,连续读就不正确,此时只有第一个BYTE正确
delay_ms(1000);
led = ~led ;
ee_read_p(0) ;
rs2_tx( 0xaa );
rs2_tx( 0xaa );
rs2_tx( 0xaa );
rs2_tx( 0xaa );
rs2_tx( ack[0] );
rs2_tx( ack[1] );
rs2_tx( ack[2] );
rs2_tx(a[0]);
rs2_tx(a[1]);
rs2_tx(a[2]);
rs2_tx(a[3]);
rs2_tx(a[4]);
rs2_tx(a[5]);
rs2_tx(a[6]);
rs2_tx(a[7]);
delay_ms(1000);
led = ~led ;
rs2_tx( 0xaa );
rs2_tx( 0xaa );
rs2_tx( 0xaa );
rs2_tx( 0xaa );
ee_read_p(0x10) ;
rs2_tx( ack[0] );
rs2_tx( ack[1] );
rs2_tx( ack[2] );
rs2_tx(a[0]);
rs2_tx(a[1]);
rs2_tx(a[2]);
rs2_tx(a[3]);
rs2_tx(a[4]);
rs2_tx(a[5]);
rs2_tx(a[6]);
rs2_tx(a[7]);
delay_ms(1000);
led = ~led ;
rs2_tx( 0xaa );
rs2_tx( 0xaa );
rs2_tx( 0xaa );
rs2_tx( 0xaa );
ee_read_p(0x20) ;
rs2_tx( ack[0] );
rs2_tx( ack[1] );
rs2_tx( ack[2] );
rs2_tx(a[0]);
rs2_tx(a[1]);
rs2_tx(a[2]);
rs2_tx(a[3]);
rs2_tx(a[4]);
rs2_tx(a[5]);
rs2_tx(a[6]);
rs2_tx(a[7]);
