楼主: 神农鼎
8051U已测试正常, 追风剑-II@8051USB实验箱,从8051到国产32位51 自主可控
发表于 2024-6-13 13:25:13 | 显示全部楼层
我觉得上面第一张图8051字太大了,不协调
发表于 2024-6-13 13:36:23 | 显示全部楼层
[/b][/b][color=Red]好强大的STC851U,一直在等 ,在公司期待一个这么强大的实验箱,还没有过STC的实验箱,好期待[/color]
发表于 2024-6-13 14:00:28 | 显示全部楼层
不但是听歌神器,还是。。。
发表于 2024-6-13 14:10:58 | 显示全部楼层
第二款丝印好看,精致,显得更正式,第一款比较细,虽然大但是看起来还不如第二个清晰。
发表于 2024-6-13 18:59:33 | 显示全部楼层
建议下面的,字高 线宽 比 不能太大(字高线宽就要粗,字矮可以细,这种0线宽的建议矮字)
发表于 2024-6-13 21:58:55 | 显示全部楼层
期待能有个试验箱
发表于 2024-6-14 18:46:02 | 显示全部楼层
丝印下面的好
发表于 2024-6-15 07:59:50 | 显示全部楼层
The IC's silkscreen marking should directly reflect the orderable part codes.
That makes the QFP44/QFP48 better than the DIP40.
eg If the orderable part code is STC8051U-32K64-QFP48
The silkscreen should split that part code into two lines -
either
STC8051U-
34K64-QFP48
or
STC8051U
-34K64-QFP48
The TFPU@108M should not be the first marking, as that will be seen as a part code by many people.
It can go under the part, in smaller font, like this :
STC8051U
-34K64-QFP48
TFPU@108M
DateCodes
The heading mentions STC8051USB, so also ok is this part code / label
STC8051USB-32K64-QFP48
STC8051USB
-34K64-QFP48
TFPU@108M
DateCodes
Addit: I see most other STC parts have MHz included in the order part code.
Should that MHz info also be included for STC8051U ?
( Web formatting has broken for editing. CrLf are lost ?  Preview = OK, Web = x )
 楼主| 发表于 2024-6-15 08:46:42 | 显示全部楼层
qqfa 发表于 2024-6-14 23:47
能否与时俱进上触摸屏,数码管这些用处少了很多
===最近4年的大学计划实验箱,都是支持触摸TFT彩屏
发表于 2024-6-15 20:18:31 来自手机 | 显示全部楼层
支持支持,等了一年终于要到啦,支持
高级模式
GMT+8, 2026-9-23 16:04 , Processed in 0.073340 second(s), 101 queries .
