楼主: xxkj2010
STC8H8K64U转双串口,第二次板子打样,使用TSSOP20封装芯片
发表于 2024-1-25 11:44:37 | 显示全部楼层
发表于 2024-1-25 13:23:44 | 显示全部楼层
Add crystal oscillator frequency stabilization, and the RX2 pin serves as both RX2 output and frequency measurement input (use a small toggle switch).
Good ideas, but the existing STC USB-2UART board already has a 22.1184MHz crystal fitted, so this does not improve much. (I measure about -50ppm too slow)
Suggest you look to fit a TCXO oscillator for better frequency precision ?
This can AC couple through 1nF to XTALI pin
Common TCXO values are 19.2M, 26.000M, 38.4M, 52MHz (overclocked)
lcsc examples:
KDS Daishinku 1XXA26000MAA VC-TCXO 26MHz voltage trim
TG2016SMN 38.4000M-MCGNNM3 Seiko Epson 2.8V~3.3V Clipped Sine Wave ±500ppb SMD2016-4P
If you want to extend the frequency counter MHz-in range, small logic parts like 74AHC1G4210GW can extend > 100MHz
(or even ~~STC8H2K08U-45I-SOP16~~, it's cheap enough to replace logic. Oops, needs to be STC8H2K08U-45I-TSSOP20 (same price) to have a XTALI pin, for divider input. XTALI is missing on SOP16 )
 楼主| 发表于 2024-1-25 20:41:13 | 显示全部楼层
jm*** 发表于 2024-1-25 13:23
Good ideas, but the existing STC USB-2UART board already has a 22.1184MHz crystal fitted, so this d ...
大佬,俺不懂英语的
还是咱们国语交流起来更方便  详情 回复 发表于 2024-2-4 11:07
发表于 2024-1-27 15:24:23 | 显示全部楼层
热烈支持,能把PCB项目分享给大家吗,都来玩玩
发表于 2024-2-4 10:10:40 | 显示全部楼层
搞得很好看啊!赞!
发表于 2024-2-4 11:07:18 | 显示全部楼层
xxkj*** 发表于 2024-1-25 20:41
大佬,俺不懂英语的
还是咱们国语交流起来更方便
热线19952583534
www.STCAI.com
 楼主| 发表于 2024-2-4 13:11:20 | 显示全部楼层
国学*** 发表于 2024-2-4 11:07
还是咱们国语交流起来更方便
是的,用国语方便,包括stc官方例程,我都喜欢看中文注释的。一看到英文注释,就觉得学不下去
发表于 2024-2-5 01:12:27 | 显示全部楼层
请问楼主:STC8H8K64U有4个串口,搞成USB转4串口可行吗?
STC8H8K64U可以的,USB端点和串口都够,但是tssop20的好像硬件没有四个串口,带硬件4串口的可以做  详情 回复 发表于 2024-2-5 16:49
发表于 2024-2-5 08:25:24 | 显示全部楼层
感谢分享,有PCB链接吗
 楼主| 发表于 2024-2-5 09:41:57 | 显示全部楼层
没有试过,也不知道怎么处理,这个问题得问stc工程师他们。
GMT+8, 2026-11-8 03:07 , Processed in 0.085051 second(s), 97 queries .
