楼主: success
申请STC核心板,用于测试RTOS和BASIC编程
发表于 2024-1-2 20:37:02 | 显示全部楼层
succ*** 发表于 2024-1-2 19:17
噢,BASIC是可以的,可以一起学习和交流一下。
这论坛不支持账户加好友的
 楼主| 发表于 2024-1-3 07:37:14 | 显示全部楼层
没事,到时发到本论坛这个帖子里,一起讨论一起交流一起学习。
发表于 2024-1-4 15:09:26 | 显示全部楼层
是不是需要先将固件下载到单片机,然后再向单片机发送简单的BASIC指令
 楼主| 发表于 2024-1-8 09:56:31 | 显示全部楼层
抱歉,测试了一下,BASIC编程不成功,还是用C51好一些吧。
发表于 2024-1-8 10:52:55 | 显示全部楼层
发表于 2024-1-8 11:03:01 | 显示全部楼层
That one is nice and small at 4k size.
There is also BASIC52 around on the web, derived from the original 8K intel code.  The latest bug fixes I can find on my hard drive, mention V1.31 fixed by D. Wulf
Intel original BASIC52 uses this less common float :
1.6 FLOATING POINT FORMAT
MCS BASIC-52 stores all floating point numbers in a normalized packed BCD format with an offset binary exponent.
The new STC8051H with 32k RAM, 64K flash and USB, should make a very good host for an extended BASIC
I'll put links in the next post.
发表于 2024-1-8 11:04:20 | 显示全部楼层
Basic52 links:
One port is here
https://github.com/sittisaks/sup ... master/BASIC-52.SRC
and more info on another here
https://www.nomad.ee/micros/index.shtml
发表于 2024-1-8 11:27:30 | 显示全部楼层
Yes, BASIC interpreters run code in flash, that scan BASIC source code usually downloaded and stored in RAM, or EEPROM.
发表于 2024-1-8 11:50:43 | 显示全部楼层
jm*** 发表于 2024-1-8 11:27
Yes, BASIC interpreters run code in flash, that scan BASIC source code usually downloaded and sto ...
我不懂英语的,估计无法实现BASIC 应用于单片机,相关资料又 少之又少。
发表于 2024-1-8 11:54:20 | 显示全部楼层
kk*** 发表于 2024-1-8 10:52
https://www.pjrc.com/tech/8051/contrib/tb51/index.html
这有一个basic的解释器
这世界真的很发达,居然有这样的产品。
GMT+8, 2026-11-8 01:17 , Processed in 0.086652 second(s), 91 queries .
