查看: 3255|回复: 9
SPI-LCD12864, 单工: ST7920 AIP31020 串口模式
发表于 2023-12-13 21:48:16 | 显示全部楼层 |阅读模式
SPI-LCD12864, 单工 : ST7920,AIP31020 串口模式
STC8F1K08
#define         Write_Command        0xf8
#define         Write_Data        0xfa
#define         Read_Command        0xfc
#define                Read_Data        0xfe
#define                Setting_Basic_Instruction_Set                                        0x30
#define                Setting_Extended_Instruction_Set_Drawing_Off        0x34
#define                Setting_Extended_Instruction_Set_Drawing_On                0x36
#define                Clear_Display        0x01
#define                Entry_Mode_Cursor_Left                                                        0x04
#define                Entry_Mode_Entire_Right                                                        0x05
#define                Entry_Mode_Cursor_Right                                                        0x06
#define                Entry_Mode_Entire_Left                                                        0x07
#define                Display_Off        0x08
#define                Display_On_Cursor_Off_Inverse_Off                                0x0c
#define                Display_On_Cursor_Off_Inverse_On                                0x0d
#define                Display_On_Cursor_On_Inverse_Off                                0x0e
#define                Display_On_Cursor_On_Inverse_On                                        0x0f
#define                Cursor_Move_Left        0x10
#define                Cursor_Move_Right        0x14
#define                Display_Move_Left        0x18
#define                Display_Move_Right        0x1c
/*----------------------------写1字节命令或数据----------------------------*/
void LCD12864_Write_Byte(unsigned char temp)
        unsigned char i;
        for(i=0;i<8;i++)
                if((temp<<i)&0x80)
                        LCD12864_SID=1;
                        LCD12864_SID=0;
                LCD12864_SCLK=0;
                LCD12864_SCLK=1;
/*----------------------------传送数据或者命令----------------------------*/
void LCD12864_Write(unsigned char Command,unsigned char temp)
        LCD12864_Write_Byte(Command);
        LCD12864_Write_Byte(temp&0xf0);
        LCD12864_Write_Byte((temp<<4)&0xf0);
/*----------------------------清空GDRAM----------------------------*/
void Clear_GDRAM(void)
        unsigned char i,j,k;
        LCD12864_Write(Write_Command,Setting_Extended_Instruction_Set_Drawing_Off);
        k=0x80;
        for(i=0;i<32;i++)
                LCD12864_Write(Write_Command,k++);
                LCD12864_Write(Write_Command,0x80);
                for(j=0;j<16;j++)
                        LCD12864_Write(Write_Data,0x00);
        k=0x80;
        for(i=0;i<32;i++)
                LCD12864_Write(Write_Command,0x88);
                for(j=0;j<16;j++)
        LCD12864_Write(Write_Command,Setting_Extended_Instruction_Set_Drawing_On);
/*----------------------------整页显示字符----------------------------*/
void Display_Text(unsigned char code *addr)
        unsigned char i;
        LCD12864_Write(Write_Command,Setting_Basic_Instruction_Set);
        LCD12864_Write(Write_Command,0x80);        //设置DDRAM地址
        Delay_10us();
        for(i=0;i<16;i++)
                LCD12864_Write(Write_Data,*addr);
                addr++;
        LCD12864_Write(Write_Command,0x90);        //设置DDRAM地址
        Delay_10us();
        for(i=0;i<16;i++)
                addr++;
        LCD12864_Write(Write_Command,0x88);        //设置DDRAM地址
        Delay_10us();
        for(i=0;i<16;i++)
                addr++;
        LCD12864_Write(Write_Command,0x98);        //设置DDRAM地址
        Delay_10us();
        for(i=0;i<16;i++)
                addr++;
/*----------------------------指定位置显示字符----------------------------*/
void Display_Data(unsigned char x,unsigned char y,unsigned char Data1,unsigned char Data2)
        switch(y)
                case 0:
                        LCD12864_Write(Write_Command,0x80+x);        //设置DDRAM地址
                        Delay_10us();
                        LCD12864_Write(Write_Data,Data1);
                        LCD12864_Write(Write_Data,Data2);
                        break;
                case 1:
                        LCD12864_Write(Write_Command,0x90+x);        //设置DDRAM地址
                        Delay_10us();
                        break;
                case 2:
                        LCD12864_Write(Write_Command,0x88+x);        //设置DDRAM地址
                        Delay_10us();
                        break;
                case 3:
                        LCD12864_Write(Write_Command,0x98+x);        //设置DDRAM地址
                        Delay_10us();
                        break;
/*----------------------------初始化12864----------------------------*/
void LCD12864_Init(void)
        Delay_x10ms(4);                        //40mS延时
        Delay_x10us(10);                //100uS延时
        Delay_x10us(4);                        //40uS延时
        LCD12864_Write(Write_Command,Clear_Display);                                                //显示光标闪烁完全关闭
        LCD12864_Write(Write_Command,Clear_Display);                                                //清除显示
        Delay_x10ms(1);                        //10mS延时
        LCD12864_Write(Write_Command,Entry_Mode_Cursor_Right);                                //光标右移模式
        LCD12864_Write(Write_Command,Display_On_Cursor_Off_Inverse_Off);        //开显示,无光标,光标不闪烁
        Clear_GDRAM();                        //清空GDRAM
声明:该装置正常通过民航安检,没有在起飞降落阶段使用,没有任何锂电池处于充电状态,没有发射无线电信号的功能,没有导体意外接触裸露电极,没有影响其他人员或造成不良后果,请勿模仿。
1 喜欢他/她就送朵鲜花吧,赠人玫瑰,手有余香!
发表于 2023-12-14 08:16:09 | 显示全部楼层
帮发几个 STC32G/STC8H, SPI/I2C 控制 LCD12864的例子
发表于 2024-3-20 17:29:53 | 显示全部楼层
你这个是用软件模拟SPI  能不能做内部SPI驱动
发表于 2024-6-1 03:58:26 | 显示全部楼层
没有工程文件吗?好麻烦哦
工程文件包含大量其他无关内容,无法提供  发表于 2024-6-3 18:14
发表于 2024-6-5 01:17:24 | 显示全部楼层
#include "./comm/STC32G.H"
#define     MAIN_Fosc       24000000L   //?????
#define LCD_Data P2
sbit    LCD_RS = P0^1;  //????
sbit    LCD_RW = P0^2;
sbit    LCD_E  = P0^3;
sbit    PSB    = P0^4;      //PSB??12864??????????,????8?????,PSB=1
sbit    LCD_RESET   =   P4^5;   //  17---RESET  L-->Enable
#define LCD12864_SID   LCD_RW
#define LCD12864_SCLK  LCD_E
#define Busy    0x80 //????LCD?????Busy??
void Delay_10us()
        u32 i;
        u16 us = 10;
        do {
                i = MAIN_Fosc / 13;
                while(--i)    ;   //14T per loop
        } while(--us);
void Delay_x10us(u16 tm)
        u16 i = tm;
        do {
                Delay_10us();   //14T per loop
        } while(--i);
void Delay_10ms()
        u16 i;
        u16 ms = 10;
        do {
                i = MAIN_Fosc / 1300;
        } while(--i);
void Delay_x10ms(u16 tm)
        u16 i = tm;
        do {
                Delay_10ms();   //14T per loop
        } while(--i);
/*----------------------------?1???????----------------------------*/
        unsigned char i;
        for(i=0; i<8; i++) {
                if((temp<<i)&0x80)
                        LCD12864_SID=1;
                        LCD12864_SID=0;
                LCD12864_SCLK=0;
                LCD12864_SCLK=1;
/*----------------------------??GDRAM----------------------------*/
        k=0x80;
        for(i=0; i<32; i++) {
                for(j=0; j<16; j++) {
        k=0x80;
        unsigned char i;
        LCD12864_Write(Write_Command,0x80);        //??DDRAM??
        Delay_10us();
        for(i=0; i<16; i++) {
                addr++;
        LCD12864_Write(Write_Command,0x90);        //??DDRAM??
        Delay_10us();
                addr++;
        LCD12864_Write(Write_Command,0x88);        //??DDRAM??
        Delay_10us();
                addr++;
        LCD12864_Write(Write_Command,0x98);        //??DDRAM??
        Delay_10us();
                addr++;
        switch(y) {
        case 0:
                LCD12864_Write(Write_Command,0x80+x);        //??DDRAM??
                Delay_10us();
                break;
        case 1:
                LCD12864_Write(Write_Command,0x90+x);        //??DDRAM??
                Delay_10us();
                break;
        case 2:
                LCD12864_Write(Write_Command,0x88+x);        //??DDRAM??
                Delay_10us();
                break;
        case 3:
                LCD12864_Write(Write_Command,0x98+x);        //??DDRAM??
                Delay_10us();
                break;
/*----------------------------???12864----------------------------*/
        Delay_x10ms(4);                        //40mS??
        Delay_x10us(10);                //100uS??
        Delay_x10us(4);                        //40uS??
        LCD12864_Write(Write_Command,Clear_Display);                                                //??????????
        Delay_x10ms(1);                        //10mS??
        LCD12864_Write(Write_Command,Entry_Mode_Cursor_Right);                                //??????
        LCD12864_Write(Write_Command,Display_On_Cursor_Off_Inverse_Off);        //???,???,?????
        Clear_GDRAM();                        //??GDRAM
unsigned char code LCD_STR[]    = {"HELLO"};
        P0M1 = 0x00;
        P0M0 = 0x00;   //???????
        P1M1 = 0x00;
        P1M0 = 0x00;   //???????
        P2M1 = 0x00;
        P2M0 = 0x00;   //???????
        P3M1 = 0x00;
        P3M0 = 0x00;   //???????
        P4M1 = 0x00;
        P4M0 = 0x00;   //???????
        P5M1 = 0x00;
        P5M0 = 0x00;   //???????
        P6M1 = 0x00;
        P6M0 = 0x00;   //???????
        P7M1 = 0x00;
        P7M0 = 0x00;   //???????
        LCD12864_Init(); //LCM???
        Delay_x10ms(5); //????(???)
        while(1) {
                Display_Text(LCD_STR);
发表于 2024-6-5 01:19:41 | 显示全部楼层
发表于 2024-6-5 01:25:06 | 显示全部楼层
不知道为啥,我试了不行。 上面是我的代码和连接图
发表于 2025-4-1 11:39:17 | 显示全部楼层
请问这2条设置指令发送了2次,是因为有时会有发送不成功的现象吗。
忘记了,可能是数据手册要求的  详情 回复 发表于 2025-4-1 13:45
 楼主| 发表于 2025-4-1 13:45:06 | 显示全部楼层
忘记了,可能是数据手册要求的
GMT+8, 2026-11-7 14:42 , Processed in 0.080657 second(s), 85 queries .
