查看: 2224|回复: 3
Keil 5没法编译
发表于 2023-11-28 14:30:36 | 显示全部楼层 |阅读模式
大家好:第一次用STC32,安装Keil 5后编译提示如下错误,如何处理?
Error: *** Project 'sample', Target 'Sample', Device 'STC::STC32G12K128 Series' is not supported by Toolchain ! ***.
发表于 2023-11-28 15:11:57 | 显示全部楼层
安装C251编译器了吗
 楼主| 发表于 2023-11-28 17:59:29 | 显示全部楼层
hz_m*** 发表于 2023-11-28 15:11
安装C251编译器了吗
已经安装了,关于版本信息如下,是不是安装成功了的
IDE-Version:
μVision V5.25.3.0
Copyright (C) 2018 ARM Ltd and ARM Germany GmbH. All rights reserved.
License Information:
1 1
LIC=BU22Z-JXBFU-1CWUA-164BT-VKYD7-PQBRA
Tool Version Numbers:
Toolchain:        PK251 Prof. Developers Kit  Version: 5.60.0.0
Toolchain Path:    C:\Keil_v5\C251\BIN
C Compiler:         C251.exe    V5.60.0.0
Assembler:          A251.exe    V4.69.13.0
Linker/Locator:     L251.exe    V4.66.93.0
Librarian:             LIB251.exe    V4.30.1.0
Hex Converter:      OH251.exe    V1.47.0.0
CPU DLL:               S251.DLL             V3.129.0.0
Dialog DLL:         DCORE51.DLL          V2.81.6.0
发表于 2023-11-28 18:09:35 | 显示全部楼层
用STC-ISP 添加型号和头文件
GMT+8, 2026-11-7 14:36 , Processed in 0.066219 second(s), 57 queries .
