楼主: Mr.Yan
坚守心念,万难可破 | 整机 1.5uA
发表于 2024-10-5 10:48:42 | 显示全部楼层
晓*** 发表于 2024-10-1 00:14
我用量很大,没有发现你说的问题。非要说我没啥实践经验的话,确实,路子比较正,严格按厂家的推荐设计做 ...
厂家都承认的问题,你按厂家的推荐设计有什么用啊!
发表于 2024-10-5 11:50:41 | 显示全部楼层
STC Icc numbers are generally quite good.
However, one area where STC is not so great, is when running the CPU at a low sub-clock
Compare these ~32kHz clocking numbers for three 8 bit MCU vendors - they must be better at putting FLASH memory to sleep longer, at the low kHz clocks.
Something STC may be able to improve ?
发表于 2024-10-29 10:45:22 | 显示全部楼层
However, one area where STC is not so great, is when run ...
Although STC MCU is running at MCS-51 instruction set ,but it is real 16bit or 32bit core inside , whitch have four stage pipeline.So it can make the operating efficiency very high , but the price is a little higher operating current , so  it cost more current at low frequency too than other MCU. But when STC's MCU processing the same equivalent operating speed , there MCUs is real lower current cost , many times better than M0+ core. If your design just need running at low operating clock and low current cost, choose a simpler MCU core maybe better.
发表于 2024-10-29 14:47:38 | 显示全部楼层
感谢楼主的实验分享!!
发表于 2025-1-22 09:29:04 来自手机 | 显示全部楼层
这个功耗可以了,倒是电池的选型也得考虑下…
发表于 2025-1-22 10:00:55 | 显示全部楼层
超低功耗应用@STC8H4K64TLCD
====郭天祥老师新实战项目三
====【大屏LCD液晶屏常亮+RTC时钟】@15uA低功耗
====200mA纽扣电池用1年
====0.4uA待机电流@STC8H4K64TLCD系列
【新提醒】0.4uA待机电流,15uA低功耗,郭天祥老师实战项目3超低功耗应用 - 郭天祥老师从51到32位51直播视频课程,实战项目专区 国芯技术交流网站 - AI32位8051交流社区  https://www.stcaimcu.com/forum.p ... p;extra=&page=1
STC官网:https://www.stcai.com/
QQ:2593903262
微信号:18106296598
发表于 2026-3-5 17:36:06 | 显示全部楼层
我不担心STC芯片低功耗问题,我担心的是你上图中这种万用表能否测准1.5~50uA问题????
发表于 2026-7-23 10:14:15 | 显示全部楼层
神*** 发表于 2023-11-20 16:36
借楼主的宝帖,推荐下我们打造硬件大生态的2篇核心技术文章,信息量极大:
完整的系统设计参考原理图@STC8 ...
掉电的时候真的来得及保存RAM数据到Flash吗?要不要在电源入口加大法拉电容?
只要不死学,就往学里死
发表于 2026-7-23 10:23:36 | 显示全部楼层
EEPROM的使用 请 配合比较器做掉电检测 | 唯一正解,电力系统标准应用 - EEPROM/DataFlash 国芯人工智能技术交流网站 - AI32位8051交流社区
EEPROM的使用 请 配合比较器掉电检测,
EEPROM中的本次上电后可能要改的数据,上电后先读到 SRAM中
电源正常时操作SRAM, 掉电时及时写回 EEPROM
发表于 2026-7-24 10:01:45 | 显示全部楼层
stc做低功耗是没问题的,很多ETC都是用stc单片机做的
GMT+8, 2026-9-23 15:04 , Processed in 0.083162 second(s), 106 queries .
