代码如下
#include "config.h"
#include "STC8G_H_GPIO.h"
#include "STC8G_H_UART.h"
#include "STC8G_H_NVIC.h"
#include "STC8G_H_Delay.h"
#include "STC8G_H_Switch.h"
#define LED P32
void GPIO_config(void)
GPIO_InitTypeDef GPIO_InitStructure; //结构定义
GPIO_InitStructure.Pin = GPIO_Pin_0 | GPIO_Pin_1; //指定要初始化的IO, GPIO_Pin_0 ~ GPIO_Pin_7
GPIO_InitStructure.Mode = GPIO_PullUp; //指定IO的输入或输出方式,GPIO_PullUp,GPIO_HighZ,GPIO_OUT_OD,GPIO_OUT_PP
GPIO_Inilize(GPIO_P0,&GPIO_InitStructure); //初始化
GPIO_InitStructure.Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2; //指定要初始化的IO, GPIO_Pin_0 ~ GPIO_Pin_7
GPIO_Inilize(GPIO_P3,&GPIO_InitStructure); //初始化
void UART_config(void)
COMx_InitDefine COMx_InitStructure; //结构定义
COMx_InitStructure.UART_Mode = UART_8bit_BRTx; //模式, UART_ShiftRight,UART_8bit_BRTx,UART_9bit,UART_9bit_BRTx
COMx_InitStructure.UART_BRT_Use = BRT_Timer1; //选择波特率发生器, BRT_Timer1, BRT_Timer2 (注意: 串口2固定使用BRT_Timer2)
COMx_InitStructure.UART_BaudRate = 115200ul; //波特率, 一般 110 ~ 115200
COMx_InitStructure.UART_RxEnable = ENABLE; //接收允许, ENABLE或DISABLE
COMx_InitStructure.BaudRateDouble = DISABLE; //波特率加倍, ENABLE或DISABLE
UART_Configuration(UART1, &COMx_InitStructure); //初始化串口1 UART1,UART2,UART3,UART4
NVIC_UART1_Init(ENABLE,Priority_1); //中断使能, ENABLE/DISABLE; 优先级(低到高) Priority_0,Priority_1,Priority_2,Priority_3
UART1_SW(UART1_SW_P30_P31); //UART1_SW_P30_P31,UART1_SW_P36_P37,UART1_SW_P16_P17,UART1_SW_P43_P44
COMx_InitStructure.UART_BRT_Use = BRT_Timer3; //选择波特率发生器, BRT_Timer2, BRT_Timer3 (注意: 串口2固定使用BRT_Timer2)
COMx_InitStructure.UART_BaudRate = 9600ul; //波特率, 110 ~ 115200
UART_Configuration(UART3, &COMx_InitStructure); //初始化串口 UART1,UART2,UART3,UART4
NVIC_UART3_Init(ENABLE,Priority_1); //中断使能, ENABLE/DISABLE; 优先级(低到高) Priority_0,Priority_1,Priority_2,Priority_3
UART3_SW(UART3_SW_P00_P01); //UART3_SW_P00_P01,UART3_SW_P50_P51
int main(){
EAXSFR(); /* 扩展寄存器访问使能 */
GPIO_config();
UART_config();
LED=0;
delay_ms(500);
LED=1;
delay_ms(500);
PrintString1("111\t");
PrintString3("333\t");
