查看: 2480|回复: 3
全局不关中中断编译出错,是不是要修改中断向量
发表于 2023-9-3 04:06:44 | 显示全部楼层 |阅读模式
Build target 'CosyOS_STC32G_Demo'
compiling os_debug.c...
compiling os_iss.c...
compiling os_main.c...
compiling os_starter.c...
compiling os_sysidle.c...
compiling os_taskmge.c...
assembling .\Objects\os_taskmge.src...
compiling os_taskmgr.c...
compiling os_timtask.c...
compiling os_var.c...
compiling sv_int_loc.c...
compiling sv_task.c...
compiling sv_tick.c...
compiling mcucfg_80251.c...
compiling System_init.c...
compiling putchar.c...
compiling adckey.c...
compiling display.c...
compiling i2c_ps.c...
compiling MatrixKey.c...
compiling ntc.c...
compiling pwmb.c...
compiling rtc.c...
compiling uart2_3.c...
compiling STC32G_ADC.c...
compiling STC32G_CAN.c...
compiling STC32G_Clock.c...
compiling STC32G_Compare.c...
compiling STC32G_Delay.c...
compiling STC32G_DMA.c...
compiling STC32G_EEPROM.c...
compiling STC32G_Exti.c...
compiling STC32G_GPIO.c...
compiling STC32G_I2C.c...
compiling STC32G_LCM.c...
compiling STC32G_LIN.c...
compiling STC32G_NVIC.c...
compiling STC32G_PWM.c...
compiling STC32G_RTC.c...
compiling STC32G_Soft_I2C.c...
compiling STC32G_Soft_UART.c...
compiling STC32G_SPI.c...
compiling STC32G_Timer.c...
compiling STC32G_UART.c...
compiling STC32G_USART.c...
compiling STC32G_WDT.c...
compiling STC32G_ADC_Isr.c...
compiling STC32G_CAN_Isr.c...
compiling STC32G_Compare_Isr.c...
compiling STC32G_DMA_Isr.c...
Sources\Driver\isr\STC32G_DMA_Isr.c(47): error C168: interrupt: value not in range 0 ... 31
Sources\Driver\isr\STC32G_DMA_Isr.c(64): error C168: interrupt: value not in range 0 ... 31
Sources\Driver\isr\STC32G_DMA_Isr.c(91): error C168: interrupt: value not in range 0 ... 31
Sources\Driver\isr\STC32G_DMA_Isr.c(112): error C168: interrupt: value not in range 0 ... 31
Sources\Driver\isr\STC32G_DMA_Isr.c(136): error C168: interrupt: value not in range 0 ... 31
Sources\Driver\isr\STC32G_DMA_Isr.c(157): error C168: interrupt: value not in range 0 ... 31
Sources\Driver\isr\STC32G_DMA_Isr.c(181): error C168: interrupt: value not in range 0 ... 31
Sources\Driver\isr\STC32G_DMA_Isr.c(202): error C168: interrupt: value not in range 0 ... 31
Sources\Driver\isr\STC32G_DMA_Isr.c(226): error C168: interrupt: value not in range 0 ... 31
Sources\Driver\isr\STC32G_DMA_Isr.c(247): error C168: interrupt: value not in range 0 ... 31
Sources\Driver\isr\STC32G_DMA_Isr.c(271): error C168: interrupt: value not in range 0 ... 31
Sources\Driver\isr\STC32G_DMA_Isr.c(304): error C168: interrupt: value not in range 0 ... 31
Sources\Driver\isr\STC32G_DMA_Isr.c(325): error C168: interrupt: value not in range 0 ... 31
Sources\Driver\isr\STC32G_DMA_Isr.c(346): error C168: interrupt: value not in range 0 ... 31
compiling STC32G_Exti_Isr.c...
compiling STC32G_GPIO_Isr.c...
compiling STC32G_I2C_Isr.c...
compiling STC32G_LCM_Isr.c...
Sources\Driver\isr\STC32G_LCM_Isr.c(23): error C168: interrupt: value not in range 0 ... 31
compiling STC32G_LIN_Isr.c...
compiling STC32G_PWM_Isr.c...
compiling STC32G_RTC_Isr.c...
Sources\Driver\isr\STC32G_RTC_Isr.c(26): error C168: interrupt: value not in range 0 ... 31
compiling STC32G_SPI_Isr.c...
compiling STC32G_Timer_Isr.c...
compiling STC32G_UART_Isr.c...
compiling idle_hook.c...
compiling init_hook.c...
compiling start_hook.c...
compiling tick_hook.c...
Target not created.
Build Time Elapsed:  00:00:25
发表于 2023-9-3 08:22:23 | 显示全部楼层
中断向量号超过了31,需要中断向量号扩展。在文件夹“软件工具”中,有相关说明和扩展插件。
 楼主| 发表于 2023-9-3 09:14:33 | 显示全部楼层
Cos*** 发表于 2023-9-3 08:22
中断向量号超过了31,需要中断向量号扩展。在文件夹“软件工具”中,有相关说明和扩展插件。 ...
谢谢,插件刚才找到了,安装编译成功
发表于 2024-4-30 10:51:32 | 显示全部楼层
GMT+8, 2026-11-7 12:35 , Processed in 0.069939 second(s), 63 queries .
