查看: 1690|回复: 2
使用STC12C5A60S2单片机写的一个频率及占空比均可调带数码管程序
  • 打卡总天数:1
  • 最近打卡:2025-03-17 16:39:04
43
发表于 2023-8-30 22:21:18 | 显示全部楼层 |阅读模式
【声明】此程序仅用于学习与参考,引用请注明版权和作者信息!
#include"main.h"
#include"peizhi.h"
#include"smg.h"
#include"eeprom.h"
sfr WDT_CONTR=0XE1;
unsigned char HighRH = 0;  //高电平重载值的高字节
unsigned char HighRL = 0;  //高电平重载值的低字节
unsigned char LowRH  = 0;  //低电平重载值的高字节
unsigned char LowRL  = 0;  //低电平重载值的低字节
/***********************按键定义**********************************/
bit d1 = 1;
bit d2 = 1;
bit d3 = 1;
uint8 ci;
uint8 ca = 0;
uint8 ca1 = 0;
uint16 cb = 0;
void key();                 //按键函数声明
void ConfigPWM(unsigned int fr, unsigned char dc);  //频率和占空比调节函数
bit q1 = 1;
bit q2 = 1;
bit q3 = 1;
ca = EEPROMReadByte(0);
cb = EEPROMReadByte(1)*255+EEPROMReadByte(2);
EA = 1;       //开总中断
peizhit1(1);  //配置T0定时2ms
ConfigPWM(cb, ca);    //频率100Hz,占空比10%
if(d1 != q1)
q1 = d1;
if(d1 == 0)
ca1++;
if(ca1 >= 2)
ca1 = 0;
if(ca1 == 1)
if(d2 != q2)
q2 = d2;
if(d2 == 0)
ca++;
EEPROMSectorErase(0);
EEPROMWriteByte(0,ca);
EEPROMWriteByte(2,cb);
EEPROMWriteByte(1,cb>>8);
if(ca >= 99)
ca = 99;
if(d3 != q3)
q3 = d3;
if(d3 == 0)
if(ca>0)
ca--;
if(ca1 == 0)
if(d2 == 0)
cb++;
if(cb >= 9999)
cb = 9999;
if(d3 == 0)
if(cb>0)
cb--;
xianshi1(cb);
xianshi2(ca);
void key()
static uint8 saomiaozhi[] = {1,1,1,1};
saomiaozhi[0] = (saomiaozhi[0]<<1) | in1;
saomiaozhi[1] = (saomiaozhi[1]<<1) | in2;
saomiaozhi[2] = (saomiaozhi[2]<<1) | in3;
if(saomiaozhi[0] == 0x00)
d1 = 0;
if(saomiaozhi[0] == 0xff)
d1 = 1;
if(saomiaozhi[1] == 0x00)
d2 = 0;
if(saomiaozhi[1] == 0xff)
d2 = 1;
if(saomiaozhi[2] == 0x00)
d3 = 0;
if(saomiaozhi[2] == 0xff)
d3 = 1;
/* 配置并启动PWM,fr-频率,dc-占空比 */
unsigned int  high, low;
unsigned long tmp;
tmp  = (11059200/12) / fr;  //计算一个周期所需的计数值
high = (tmp*dc) / 100;      //计算高电平所需的计数值
low  = tmp - high;          //计算低电平所需的计数值
high = 65536 - high + 12;   //计算高电平的重载值并补偿中断延时
low  = 65536 - low  + 12;   //计算低电平的重载值并补偿中断延时
HighRH = (unsigned char)(high>>8); //高电平重载值拆分为高低字节
HighRL = (unsigned char)high;
LowRH  = (unsigned char)(low>>8);  //低电平重载值拆分为高低字节
LowRL  = (unsigned char)low;
TMOD &= 0xF0;   //清零T0的控制位
TMOD |= 0x01;   //配置T0为模式1
TH0 = HighRH;   //加载T0重载值
TL0 = HighRL;
ET0 = 1;        //使能T0中断
TR0 = 1;        //启动T0
PWMOUT = 1;     //输出高电平
/* T0中断服务函数,产生PWM输出 */
void InterruptTimer0() interrupt 1
if (PWMOUT == 0)  //当前输出为高电平时,装载低电平值并输出低电平
TH0 = LowRH;
TL0 = LowRL;
PWMOUT = 1;
else              //当前输出为低电平时,装载高电平值并输出高电平
TH0 = HighRH;
TL0 = HighRL;
PWMOUT = 0;
/* T0中断服务函数,完成数码管、按键扫描与秒表计数 */
void t1() interrupt 3
TH1 = T1RH;  //重新加载重载值
TL1 = T1RL;
ci++;
ssmg();                 //数码管扫描
if(ci>=2)
ci = 0;
key();
占空比频率可调程序 带掉电存储.rar
71.87 KB, 下载次数: 125
发表于 2024-12-4 01:22:02 | 显示全部楼层
为什么我用你这个程序没有PWM输出啊
  • 打卡总天数:868
  • 最近打卡:2026-05-10 08:10:26
发表于 2024-12-4 08:54:08 | 显示全部楼层
可能坛主也是从网上搬运过来的,没有验证
GMT+8, 2026-5-10 22:22 , Processed in 0.106083 second(s), 59 queries .
