查看: 1721|回复: 5
STC8G2K64S4的10路AD采样,两种不同的代码,总有一路AD采样值不对且始终为零
发表于 2023-7-25 11:21:11 | 显示全部楼层 |阅读模式
问题如下,两种不同的代码,每次都有固定的一路采样的AD值为零,但为零的如果单独采样则值是正确的
代码一如下,其问题是 ADC_N_L1采集的AD值始终为零,其实这个口的外部电压为电源电压一半,单独采样则AD是512
void ADC_ISR() interrupt 5
        ADC_CONTR &=~ADC_FLAG;        //清除中断
    if(AD_conver_ii == 0)
                    ADC_ref_avg= (ADC_RES<<8)|ADC_RESL;
                        Ref_flg =1;
                         ADC_CONTR = ADC_SELECTCHS0;
    else        if(AD_conver_ii == 1)
                    ADC_TEST= (ADC_RES<<8)|ADC_RESL;
                        DC5v_flg =1;
                         ADC_CONTR = ADC_SELECTCHS1;
    else        if(AD_conver_ii == 2)
                    ADC_N_L1= (ADC_RES<<8)|ADC_RESL;
                        L1N_flg =1;
                         ADC_CONTR = ADC_SELECTCHS2;
    else        if(AD_conver_ii == 3)
                    ADC_L1_L2 = (ADC_RES<<8)|ADC_RESL;
                        L1L2_flg =1;
                         ADC_CONTR = ADC_SELECTCHS3;
    else        if(AD_conver_ii == 4)
                    ADC_L1_L3= (ADC_RES<<8)|ADC_RESL;
                        L1L3_flg =1;
                         ADC_CONTR = ADC_SELECTCHS4;
    else        if(AD_conver_ii == 5)
                    ADC_BAT_V = (ADC_RES<<8)|ADC_RESL;
                        Bat_v_flg =1;// 电池电压
                         ADC_CONTR = ADC_SELECTCHS5;
    else if(AD_conver_ii == 6)
                         ADC_BAT_I =(ADC_RES<<8)|ADC_RESL;
                        Bat_i_flg =0;// 充电电流
                         ADC_CONTR = ADC_SELECTCHS6;
        else if(AD_conver_ii == 7)
                        ADC_BUS=(ADC_RES<<8)|ADC_RESL;
                        Vbus_flg =1;//        母线电压
                        ADC_CONTR = ADC_SELECTCHS7;
        else if(AD_conver_ii == 8)
                        ADC_AC_OUT=(ADC_RES<<8)|ADC_RESL;
                        Inv_v_out =1;//        逆变电压
                        ADC_CONTR = ADC_SELECTCHS13;
                ADC_AC_I_OUT=(ADC_RES<<8)|ADC_RESL;
                Inv_i_out =1;//  逆变电流
                AD_finish =1;
                ADC_CONTR = ADC_SELECTINNER;
   AD_conver_ii =(AD_conver_ii +1)%10;
代码二问题是采集的芯片的内部参考信号源1.91V的AD值始终为零
        ADC_CONTR &=~0x20;        //清除中断
          ADC_BUS=(ADC_RES<<8)|ADC_RESL; //P16
      Vbus_flg =1;//        母线电压
          ADC_CONTR = 0xc7;
                 ADC_CONTR = 0xc1;
            AD_L1N= (ADC_RES<<8)|ADC_RESL;
                L1N_flg =1;
                 ADC_CONTR = 0xc2;
                L1L2_flg =1;
                 ADC_CONTR = 0xc3;
                L1L3_flg =1;
                 ADC_CONTR = 0xc4;
                 ADC_CONTR = 0xc5;
                 ADC_CONTR = 0xc0;
                DC5v_flg =1;
                ADC_CONTR = 0xcf;
                Ref_flg =1;
                ADC_CONTR = 0xcd;
                AD_finish =1;
                ADC_CONTR = 0xc6;
AD采取右对齐且MCU的时钟是30MHZ  AD基本配置如下
           ADCCFG = 0x00;
        EAXSFR();
        ADCTIM = 0xCF;
        EAXRAM();
        ADCCFG = 0x20;//右对齐
        ADC_CONTR = ADC_POWER | AD_INNER;
         Delay_T3_nms(100);
         ADC_CONTR = ADC_POWER |ADC_START| AD_INNER;//先启动内部信号参考源1.91V
        EADC=1;
谢谢!
发表于 2023-7-25 13:08:04 | 显示全部楼层
用附件的例程试试
16路ADC中断轮询采样-串口1返回结果.zip
8.99 KB, 下载次数: 159
 楼主| 发表于 2023-7-25 14:07:55 | 显示全部楼层
乘风*** 发表于 2023-7-25 13:08
用附件的例程试试
收到 谢谢
 楼主| 发表于 2023-7-25 14:43:52 | 显示全部楼层
用附件的例程试试
这个例子是可以的,为什么P1.2没有设置成高阻输入却是AD口?上电复位就是高阻输入?
为什么我的例子却不可以 谢谢!
发表于 2023-7-25 19:06:36 | 显示全部楼层
为什么我的例子却不 ...
STC8系列开始,IO口除了P3.0,P3.1外,其它上电默认都是高阻输入模式。
 楼主| 发表于 2023-7-26 14:30:16 | 显示全部楼层
谢谢
GMT+8, 2026-11-8 01:38 , Processed in 0.068902 second(s), 65 queries .
