查看: 1029|回复: 0
STC8G2K64S4的AD采样有问题,10路AD一起采样,变换程序总有一路采集值为零
发表于 2023-7-25 11:16:51 | 显示全部楼层 |阅读模式
问题如下,两种不同的代码,每次都有固定的一路采样的AD值为零,但为零的如果单独采样则值是正确的
代码一如下,其问题是 ADC_N_L1采集的AD值始终为零,其实这个口的外部电压为电源电压一半,单独采样则AD是512
void ADC_ISR() interrupt 5
        ADC_CONTR &=~ADC_FLAG;        //清除中断
    if(AD_conver_ii == 0)
                    ADC_ref_avg= (ADC_RES<<8)|ADC_RESL;
                        Ref_flg =1;
                         ADC_CONTR = ADC_SELECTCHS0;
    else        if(AD_conver_ii == 1)
                    ADC_TEST= (ADC_RES<<8)|ADC_RESL;
                        DC5v_flg =1;
                         ADC_CONTR = ADC_SELECTCHS1;
    else        if(AD_conver_ii == 2)
                    ADC_N_L1= (ADC_RES<<8)|ADC_RESL;
                        L1N_flg =1;
                         ADC_CONTR = ADC_SELECTCHS2;
    else        if(AD_conver_ii == 3)
                    ADC_L1_L2 = (ADC_RES<<8)|ADC_RESL;
                        L1L2_flg =1;
                         ADC_CONTR = ADC_SELECTCHS3;
    else        if(AD_conver_ii == 4)
                    ADC_L1_L3= (ADC_RES<<8)|ADC_RESL;
                        L1L3_flg =1;
                         ADC_CONTR = ADC_SELECTCHS4;
    else        if(AD_conver_ii == 5)
                    ADC_BAT_V = (ADC_RES<<8)|ADC_RESL;
                        Bat_v_flg =1;// 电池电压
                         ADC_CONTR = ADC_SELECTCHS5;
    else if(AD_conver_ii == 6)
                        ADC_BAT_I =(ADC_RES<<8)|ADC_RESL;
                        Bat_i_flg =0;// 充电电流
                         ADC_CONTR = ADC_SELECTCHS6;
        else if(AD_conver_ii == 7)
                        ADC_BUS=(ADC_RES<<8)|ADC_RESL;
                        Vbus_flg =1;//        母线电压
                        ADC_CONTR = ADC_SELECTCHS7;
        else if(AD_conver_ii == 8)
                        ADC_AC_OUT=(ADC_RES<<8)|ADC_RESL;
                        Inv_v_out =1;//        逆变电压
                        ADC_CONTR = ADC_SELECTCHS13;
                ADC_AC_I_OUT=(ADC_RES<<8)|ADC_RESL;
                Inv_i_out =1;//  逆变电流
                AD_finish =1;
                ADC_CONTR = ADC_SELECTINNER;
   AD_conver_ii =(AD_conver_ii +1)%10;
代码二问题是采集的芯片的内部参考信号源1.91V的AD值始终为零
        ADC_CONTR &=~0x20;        //清除中断
          ADC_BUS=(ADC_RES<<8)|ADC_RESL; //P16
      Vbus_flg =1;//        母线电压
          ADC_CONTR = 0xc7;
                 ADC_CONTR = 0xc1;
            AD_L1N= (ADC_RES<<8)|ADC_RESL;
                L1N_flg =1;
                 ADC_CONTR = 0xc2;
                L1L2_flg =1;
                 ADC_CONTR = 0xc3;
                L1L3_flg =1;
                 ADC_CONTR = 0xc4;
                 ADC_CONTR = 0xc5;
                 ADC_CONTR = 0xc0;
                DC5v_flg =1;
                ADC_CONTR = 0xcf;
                Ref_flg =1;
                ADC_CONTR = 0xcd;
                AD_finish =1;
                ADC_CONTR = 0xc6;
AD采取右对齐且MCU的时钟是30MHZ  AD基本配置如下
           ADCCFG = 0x00;
        EAXSFR();
        ADCTIM = 0xCF;
        EAXRAM();
        ADCCFG = 0x20;//右对齐
        ADC_CONTR = ADC_POWER | AD_INNER;
        Delay_T3_nms(100);
        ADC_CONTR = ADC_POWER |ADC_START| AD_INNER;//先启动内部信号参考源1.91V
        EADC=1;
谢谢!
GMT+8, 2026-9-23 16:09 , Processed in 0.068055 second(s), 41 queries .
