查看: 1827|回复: 0
STC8G2K64S4,总计使用10路AD,问题如下
发表于 2023-7-24 19:10:20 | 显示全部楼层 |阅读模式
1.下面两种代码,每种代码都有一路的AD值为零,实际上AD通道的模拟值不为零
代码一 的ADC_N_L1值每次都是零但如果单独只有这一路采样得到AD值512换算后与外部模拟值相吻合
void ADC_ISR() interrupt 5
        ADC_CONTR &=~ADC_FLAG;        //清除中断
    if(AD_conver_ii == 0)
                    ADC_ref_avg= (ADC_RES<<8)|ADC_RESL; //内部1.91的AD值
                        Ref_flg =1;
                         ADC_CONTR = 0xc0;
    else        if(AD_conver_ii == 1)
                    ADC_TEST= (ADC_RES<<8)|ADC_RESL;
                        DC5v_flg =1;
                         ADC_CONTR = 0xc1;
    else        if(AD_conver_ii == 2)
                    ADC_N_L1= (ADC_RES<<8)|ADC_RESL;
                        L1N_flg =1;
                         ADC_CONTR = 0xc2;
    else        if(AD_conver_ii == 3)
                    ADC_L1_L2 = (ADC_RES<<8)|ADC_RESL;
                        L1L2_flg =1;
                         ADC_CONTR = 0xc3;
    else        if(AD_conver_ii == 4)
                    ADC_L1_L3= (ADC_RES<<8)|ADC_RESL;
                        L1L3_flg =1;
                         ADC_CONTR = 0xc4;
    else        if(AD_conver_ii == 5)
                    ADC_BAT_V = (ADC_RES<<8)|ADC_RESL;
                        Bat_v_flg =1;// 电池电压
                         ADC_CONTR = 0xc5;
    else if(AD_conver_ii == 6)
                        ADC_BAT_I =(ADC_RES<<8)|ADC_RESL;
                        Bat_i_flg =0;// 充电电流
                         ADC_CONTR = 0xc6;
        else if(AD_conver_ii == 7)
                        ADC_BUS=(ADC_RES<<8)|ADC_RESL;
                        Vbus_flg =1;//        母线电压
                        ADC_CONTR = 0xc7;
        else if(AD_conver_ii == 8)
                        ADC_AC_OUT=(ADC_RES<<8)|ADC_RESL;
                        Inv_v_out =1;//        逆变电压
                        ADC_CONTR = 0xcd;
                ADC_AC_I_OUT=(ADC_RES<<8)|ADC_RESL;
                Inv_i_out =1;//  逆变电流
                AD_finish =1;
                ADC_CONTR = 0xcf;
   AD_conver_ii =(AD_conver_ii +1)%10;
代码二 发现内部参考信号源1.91V的AD值变量ADC_ref_avg为零
          ADC_BUS=(ADC_RES<<8)|ADC_RESL; //P16
      Vbus_flg =1;//        母线电压
          ADC_CONTR = 0xc7;
                 ADC_CONTR = 0xc1;
                L1N_flg =1;
                 ADC_CONTR = 0xc2;
                L1L2_flg =1;
                 ADC_CONTR = 0xc3;
                L1L3_flg =1;
                 ADC_CONTR = 0xc4;
                 ADC_CONTR = 0xc5;
                 ADC_CONTR = 0xc0;
                DC5v_flg =1;
                ADC_CONTR = 0xcf;
                ADC_ref_avg= (ADC_RES<<8)|ADC_RESL; //内部参考信号源1.91的AD值
                Ref_flg =1;
                ADC_CONTR = 0xcd;
                AD_finish =1;
                ADC_CONTR = 0xc6;
系统时钟选用30MHZ且ADC转换时间为480K左右 谢谢!
请问这是什么问题造成的?
GMT+8, 2026-9-23 16:12 , Processed in 0.064075 second(s), 41 queries .
