查看: 148|回复: 4
请教bootloader问题
发表于 2026-9-22 08:50:04 | 显示全部楼层 |阅读模式
为了学习bootloader做了个简单的ISP和APP,设计目标是通电先进入ISP 串口收到0X0A就跳到APP, APP串口收到0X0B就重启回到ISP.两个hex用HexMerge合并,一起刷入单片机 ,单片机是STC32G12K128。但是刷进去后,直接就进入APP,发0X0B重启还是APP。
ISP代码如下
#include "stc32g.h"
#define FOSC 11059200UL
#define BRT (65536 - (FOSC / 115200+2) / 4)
bit busy;
char wptr;
char rptr;
char buffer[16];
void UartIsr() interrupt 4
if (TI)
  TI = 0;
  busy = 0;
if (RI)
  RI = 0;
  buffer[wptr++] = SBUF;
  wptr &= 0x0f;
void UartInit()
SCON = 0x50;
T2L = BRT;
T2H = BRT >> 8;
S1BRT = 1;
T2x12 = 1;
T2R = 1;
wptr = 0x00;
rptr = 0x00;
busy = 0;
void UartSend(char dat)
while (busy);
busy = 1;
SBUF = dat;
void UartSendStr(char *p)
while (*p)
  UartSend(*p++);
char GetVa;
EAXFR = 1;
CKCON = 0x00;
WTST = 0x00;
P0M0 = 0x00;
P0M1 = 0x00;
P1M0 = 0x00;
P1M1 = 0x00;
P2M0 = 0x00;
P2M1 = 0x00;
P3M0 = 0x00;
P3M1 = 0x00;
P4M0 = 0x00;
P4M1 = 0x00;
P5M0 = 0x00;
P5M1 = 0x00;
UartInit();
ES = 1;
UartSendStr("ISP Star !\r\n");
  if (rptr != wptr)
                GetVa=buffer[rptr++];
                if(GetVa==0x0A)
                        UartSendStr("Go APP !\r\n");
                        EA = 0;         //?????
    ES = 0;         //??????
    AUXR &= ~(1<<2);//??T2???
    TI = 0;
    RI = 0;
    busy = 0;
    //????APP
    ((void (far *)())(0xff2000))();
    while(1);
   UartSend(GetVa);
   rptr &= 0x0f;
keil 设置如下
APP 代码如下
#include "stc32g.h"   //????????
#define FOSC 11059200UL //?????????,??????
    //?2??????Keil???
bit busy;
char wptr;
char rptr;
char buffer[16];
if (TI)
  TI = 0;
  busy = 0;
if (RI)
  RI = 0;
  wptr &= 0x0f;
void UartInit()
SCON = 0x50;
T2L = BRT;
T2H = BRT >> 8;
S1BRT = 1;
T2x12 = 1;
T2R = 1;
wptr = 0x00;
rptr = 0x00;
busy = 0;
while (busy);
busy = 1;
SBUF = dat;
{ while (*p)
  UartSend(*p++);
         char GetVa;
EAXFR = 1; //????XFR,????????
CKCON = 0x00; //?????????????
WTST = 0x00;  //??????????,
P0M0 = 0x00;
P0M1 = 0x00;
P1M0 = 0x00;
P1M1 = 0x00;
P2M0 = 0x00;
P2M1 = 0x00;
P3M0 = 0x00;
P3M1 = 0x00;
P4M0 = 0x00;
P4M1 = 0x00;
P5M0 = 0x00;
P5M1 = 0x00;
UartInit();
ES = 1;
UartSendStr("APP Strar !\r\n");
  if (rptr != wptr)
                if(GetVa==0x0B)
                        IAP_CONTR = 0x20;
                 UartSend(0x01);
   UartSend(GetVa);
   rptr &= 0x0f;
keil 设置如下
发表于 2026-9-22 09:12:58 | 显示全部楼层
建议先用官方的在线升级例子测试,官方例子功能验证正常后,在例子基础上根据自身需要添加/修改功能。
例如添加串口收到指定数据进行跳转功能。
注意:STC32G12K128没有专用的用户ISP空间,所以用户ISP跟用户APP只能在其中一处使用中断。
例子是在用户ISP空间使用查询模式,用户APP空间使用中断模式。
官方在线升级例子下载页面:https://www.stcai.com/zxsj
 楼主| 发表于 2026-9-22 09:48:10 | 显示全部楼层
例如 ...
例子已经试过没问题,想自己一步步搭建bootlaoder。
发表于 2026-9-22 10:21:14 | 显示全部楼层
在例子框架上进行修改,避免设置出问题。
例子也是使用串口通信升级,修改串口指令判断处理函数就可以实现跳转功能。
 楼主| 发表于 2026-9-22 11:50:52 | 显示全部楼层
乘风*** 发表于 2026-9-22 10:21
在例子框架上进行修改,避免设置出问题。
例子也是使用串口通信升级,修改串口指令判断处理函数就可以实 ...
我想自己一步步搭建平台,这个也是按照例子的设置来的
GMT+8, 2026-11-8 02:46 , Processed in 0.092564 second(s), 63 queries .
