查看: 187|回复: 5
图中16*32双色点阵模组,这款点亮方式是静态还是动态刷新,有没有例程可供参考测试
发表于 2026-9-7 17:16:17 | 显示全部楼层 |阅读模式
需要用这种屏拼成64*128的屏,横行4块,竖向也是4块
发表于 2026-9-7 17:35:40 | 显示全部楼层
这是LED点阵屏单元板,可以多块拼接成很大的面积。
这是HUB12接口,看其地址ABCD是16扫的,肯定是动态扫描的,扫描速度为0.5~1ms一行,刷新率62.5~125Hz。单色的驱动时序多数兼容74HC595,单元屏如果点阵比较密的多为64x16或64x32,你这个点阵比较疏,32x16,则一行4个字节,扫16次完成一屏。
发表于 2026-9-7 19:49:27 | 显示全部楼层
点阵必须是动态扫描的
睁开眼睛做场梦~~~
 楼主| 发表于 2026-9-9 16:40:34 | 显示全部楼层
如下搞了一个测试程序,显示怎么也不正确,按理说最后一个字节固定了0xff,应该是屏的最后25-32列全亮,现在反而是4行全亮。还有,如果地址固定一个值(某行),屏反而不显示了
#include    "STC8C.h"
sbit    ADDR_A    =P3^5;
sbit    ADDR_B    =P3^4;
sbit    ADDR_C    =P3^3;
sbit    ADDR_D    =P3^2;
sbit    CLK        =P4^6;
sbit    LAT        =P0^7;
sbit    OE        =P0^6;
sbit    R_dat    =P0^4;
sbit    G_dat    =P0^3;
struct FONT_DATA
    unsigned char dat[32];
struct FONT_DATA code Font_Data[] =
    0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x80,0x02,0x40,0x04,0x20,0x04,0x20,0x04,0x20,
    0x04,0x20,0x04,0x20,0x04,0x20,0x04,0x20,0x02,0x40,0x01,0x80,0x00,0x00,0x00,0x00, /*'0',0*/
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x03,0x80,0x00,0x80,0x00,0x80,0x00,0x80,
    0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x03,0xE0,0x00,0x00,0x00,0x00, /*'1',1*/
    0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xC0,0x04,0x20,0x04,0x20,0x04,0x20,0x00,0x20,
    0x00,0x40,0x00,0x80,0x01,0x00,0x02,0x00,0x04,0x20,0x07,0xE0,0x00,0x00,0x00,0x00, /*'2',2*/
    0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xC0,0x04,0x20,0x04,0x20,0x00,0x20,0x00,0x40,
    0x01,0x80,0x00,0x40,0x00,0x20,0x04,0x20,0x04,0x20,0x03,0xC0,0x00,0x00,0x00,0x00, /*'3',3*/
    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x00,0xC0,0x00,0xC0,0x01,0x40,0x02,0x40,
    0x02,0x40,0x04,0x40,0x07,0xF0,0x00,0x40,0x00,0x40,0x01,0xF0,0x00,0x00,0x00,0x00, /*'4',4*/
    0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x04,0x00,0x04,0x00,0x04,0x00,0x07,0x80,
    0x04,0x40,0x00,0x20,0x00,0x20,0x04,0x20,0x04,0x40,0x03,0x80,0x00,0x00,0x00,0x00, /*'5',5*/
    0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x80,0x02,0x40,0x04,0x00,0x04,0x00,0x05,0xC0,
    0x06,0x20,0x04,0x20,0x04,0x20,0x04,0x20,0x02,0x20,0x01,0xC0,0x00,0x00,0x00,0x00, /*'6',6*/
    0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x04,0x20,0x00,0x40,0x00,0x40,0x00,0x80,
    0x00,0x80,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x00,0x00,0x00,0x00, /*'7',7*/
    0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xC0,0x04,0x20,0x04,0x20,0x04,0x20,0x02,0x40,
    0x01,0x80,0x02,0x40,0x04,0x20,0x04,0x20,0x04,0x20,0x03,0xC0,0x00,0x00,0x00,0x00, /*'8',8*/
    0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x80,0x04,0x40,0x04,0x20,0x04,0x20,0x04,0x20,
    0x04,0x60,0x03,0xA0,0x00,0x20,0x00,0x20,0x02,0x40,0x01,0x80,0x00,0x00,0x00,0x00, /*'9',9*/
unsigned char    bdata    Address;
sbit    Addr_A=Address^0;
sbit    Addr_B=Address^1;
sbit    Addr_C=Address^2;
sbit    Addr_D=Address^3;
void    TMR1_Isr()    interrupt    3 // 1ms定时
    unsigned char    i,j;
    ADDR_A=Addr_A;
    ADDR_B=Addr_B;
    ADDR_C=Addr_C;
    ADDR_D=Addr_D;   // 扫描行地址,如果固定为0000或其他值,屏幕什么也显示不出呢,郁闷
    OE=1;
    j=Address<<1;
    ACC=Font_Data[0].dat[j];        // 0,一行中第一个字节,此处是要显示 0 1 ,16*16点阵
    for (i=8;i>0;i--)
        G_dat=ACC&0x80;
        R_dat=0;
        CLK=0;
        CLK=1;
    j++;
    for (i=8;i>0;i--)
        G_dat=ACC&0x80;
        R_dat=0;
        CLK=0;
        CLK=1;
    j=Address<<1;
    ACC=Font_Data[1].dat[j];        // 1
    for (i=8;i>0;i--)
        G_dat=ACC&0x80;
        R_dat=0;
        CLK=0;
        CLK=1;
    j++;
    for (i=8;i>0;i--)
//        G_dat=ACC&0x80;
        G_dat=1;
        R_dat=0;
        CLK=0;
        CLK=1;
    LAT=0;
    LAT=1;
    OE=0;
    Address++;
    Address&=0x0f;
void    TMR1_Init(void)
    TR1=0;
    TMOD&=0x0f;        // 16 bit timer
    TH1=0xd1;
    TL1=0x20;
    AUXR|=0x40;
    TR1=1;
    ET1=1;
void    RST_WDT(void)
    WDT_CONTR=0x3a;
void    System_Init(void)
    P_SW2=0x80;
    XOSCCR=0xc0;        // Ñ¡ÓÃÍⲿ¾§Õñ
    while (!(XOSCCR&1));
    CLKDIV=0x00;
    CKSEL=0x01;
    P_SW2=0x00;
    P0M1=0x00;P0M0=0xff;
    P1M1=0x00;P1M0=0x00;
    P2M1=0x00;P2M0=0x00;
    P3M1=0x00;P3M0=0x3c;
    P4M1=0x00;P4M0=0x40;
    P5M1=0x00;P5M0=0x00;
main()
    IE=0;
    System_Init();
    TMR1_Init();
    EA=1;
        RST_WDT();
 楼主| 发表于 2026-9-9 17:54:42 | 显示全部楼层
做了4个数据测试显示,结果行列直接搞不懂了
OE=1;
        j=Address<<1;
//        ACC=Font_Data[0].dat[j];                // 0
        ACC=0x1;
        for (i=8;i>0;i--)
                G_dat=ACC&0x80;
                R_dat=0;
                CLK=0;
                CLK=1;
        j++;
        ACC=0x3;
        for (i=8;i>0;i--)
                G_dat=ACC&0x80;
                R_dat=0;
                CLK=0;
                CLK=1;
        j=Address<<1;
//        ACC=Font_Data[1].dat[j];                // 1
        ACC=0x5;
        for (i=8;i>0;i--)
                G_dat=ACC&0x80;
                R_dat=0;
                CLK=0;
                CLK=1;
        j++;
        ACC=0x30;
        for (i=8;i>0;i--)
                G_dat=ACC&0x80;
                R_dat=0;
                CLK=0;
                CLK=1;
        LAT=0;
        LAT=1;
        OE=0;
 楼主| 发表于 2026-9-22 12:04:50 | 显示全部楼层
最后搞定了,是4扫方式,这个方式太麻烦了,不是完整的一行。
GMT+8, 2026-11-8 02:49 , Processed in 0.072235 second(s), 66 queries .
