查看: 310|回复: 8
终于搞定液晶了
发表于 2026-8-28 23:26:47 | 显示全部楼层 |阅读模式
main.c:
#include <STC89C5xRC.H>
#include "LCD.h"
//char *str1="    Hello World!        Hello World!    ";
//char *str2="    I'm LCD1602A        I'm LCD1602A    ";
//void main(){
//  unsigned int counter=0;
//  LCD_Init();
//  LCD_ShowString(0,0,str1);
//  LCD_ShowString(0,1,str2);
//  while(1){
//    for(counter=0;counter<500;counter++){
//      LCD_Delay();
//    LCD_Scroll(0);
unsigned char heart[]={0x00,0x0a,0x1f,0x1f,0x0e,0x04,0x00,0x00};
void main(){
  LCD_Init();
  LCD_Write_CGRAM(7,heart);
  LCD_SetPox(0,0);
  LCD_WD(0x07);
  while(1);
LCD.c:
#define LCD_DATA  P0
sbit LCD_RS=P1^0;
sbit LCD_RW=P1^1;
sbit LCD_E=P1^2;
void LCD_Delay();
void LCD_WS(unsigned char ws);
void LCD_WD(unsigned char wd);
void LCD_Init();
void LCD_SetPox(unsigned char x,unsigned char y);
void LCD_ShowString(unsigned char x,unsigned char y,char *str);
void LCD_Scroll(bit fx);
void LCD_Write_CGRAM(unsigned char weizhi,unsigned char *array);
void LCD_Delay(){
  unsigned char data i, j;//24MHz 2ms
        i = 8;
        j = 197;
        do
                while (--j);
        } while (--i);
void LCD_WS(unsigned char ws){
  LCD_E=1;
  LCD_RS=0;//S
  LCD_RW=0;//W
  LCD_DATA=ws;
  LCD_Delay();
  LCD_E=0;
void LCD_WD(unsigned char wd){
  LCD_E=1;
  LCD_RS=1;//R
  LCD_RW=0;//W
  LCD_DATA=wd;
  LCD_Delay();
  LCD_E=0;
void LCD_Init(){
  LCD_WS(0x38);
  LCD_WS(0x0C);
  LCD_WS(0x06);
  LCD_WS(0x01);
void LCD_SetPox(unsigned char x,unsigned char y){
  if(y){
    LCD_WS(0x80+0x40+x);
  }else{
    LCD_WS(0x80+x);
void LCD_ShowString(unsigned char x,unsigned char y,char *str){
  LCD_SetPox(x,y);
  while(*str){
    LCD_WD(*str);
    str++;
void LCD_Scroll(bit fx){
  if(fx){
    LCD_WS(0x1C);//right
  }else{
    LCD_WS(0x18);//left
void LCD_Write_CGRAM(unsigned char weizhi,unsigned char *array){
  //0<=weizhi<8,array[8]
  unsigned char i=(weizhi<<3)|0x40;
  LCD_WS(i);
  for(i=0;i<8;i++){
    LCD_WD(array[i]);
  LCD_WS(0x80);
LCD.h:
#ifndef __LCD_H
#define __LCD_H
void LCD_Delay();
void LCD_Init();
#endif
发表于 2026-8-29 11:07:37 | 显示全部楼层
成熟的1602和12864代码到处都是,不用这么吃力吧。
发表于 2026-8-29 23:56:22 | 显示全部楼层
还没用上AI写代码吗?
发表于 2026-9-3 10:06:36 | 显示全部楼层
 楼主| 发表于 2026-9-5 12:43:52 | 显示全部楼层
jker*** 发表于 2026-8-29 23:56
还没用上AI写代码吗?
自己写更好吧
 楼主| 发表于 2026-9-12 18:51:53 | 显示全部楼层
发表于 2026-9-12 20:44:23 | 显示全部楼层
12864显存模型,看得明白的话,就能在屏上做出各种特效了
12点击汉字字模
12点击汉字字模
16点阵
16点阵
 楼主| 发表于 2026-9-12 20:48:45 | 显示全部楼层
唔,OLED和这个好像也能适配,让我们再一起想想吧
发表于 2026-9-12 21:11:15 | 显示全部楼层
其实任意单色屏都适配这套模型的,这是在内存中划出的一块做显存的,就是一数组,刷屏前将显示数据写入数组,数据是换算成bit写入的,写的时候记录下改变的位置(也是一数组),显示数据写完后再将变化的部分送给屏幕去显示,效率比较高,
可以看看这个视频中的样子,https://www.bilibili.com/video/B ... p;bvid=BV1zy4y1c7rC,因为是公司项目用于产品中的,其他的你自己尝试研究研究
GMT+8, 2026-11-7 11:25 , Processed in 0.077664 second(s), 93 queries .
