查看: 157|回复: 1
AI8051U 串口2 实验箱使用中的问题 | 已经解决
发表于 2026-7-12 16:44:15 | 显示全部楼层 |阅读模式
修改例子 《ai8051\Ai8051U-32Bit\51-USB-CDC转双串口-根据串口波特率选择出厂时校准的几种常用时钟频率做主频》 后,  如果 有  3.6 和  3.7 干扰, 记得拨通断开关
void sys_init()
    EAXFR = 1; //扩展寄存器(XFR)访问使能
    CKCON = 0; //提高访问XRAM速度
    S1_S1 = 0;
    S1_S0 = 1;      //UART1(RxD1_2/P3.6, TxD1_2/P3.7)
    S2_S = 1;       //UART2(RxD2_2/P4.2, TxD2_2/P4.3)
void uart_init()
    SCON = 0x50;
    TMOD &= ~0xf0;
    TL1 = BR(MAIN_Fosc,115200);
    TH1 = BR(MAIN_Fosc,115200) >> 8;
    T1x12 = 1;
    TR1 = 1;
    PS = 1;     //提高串口1中断优先级,防止数据丢失
    ES = 1;
    S2CON = 0x50;
    T2L = BR(MAIN_Fosc,115200);
    T2H = BR(MAIN_Fosc,115200) >> 8;
    T2x12 = 1;
    T2R = 1;
    PS2 = 1;    //提高串口2中断优先级,防止数据丢失
    ES2 = 1;
    LineCoding1.dwDTERate = REV4(115200);
    LineCoding1.bCharFormat = 0;
    LineCoding1.bParityType = 0;
    LineCoding1.bDataBits = 8;
    LineCoding2.dwDTERate = REV4(115200);
    LineCoding2.bCharFormat = 0;
    LineCoding2.bParityType = 0;
    LineCoding2.bDataBits = 8;
    Uart1TxBusy = 0;
    Uart2TxBusy = 0;
    Uart1RxRptr = 0;
    Uart2RxRptr = 0;
    Uart1RxWptr = 0;
    Uart2RxWptr = 0;
    Uart1TxRptr = 0;
    Uart2TxRptr = 0;
    Uart1TxWptr = 0;
    Uart2TxWptr = 0;
 楼主| 发表于 2026-8-21 13:58:14 | 显示全部楼层
把串口1的图也贴上吧。看起来方便。
GMT+8, 2026-9-23 16:09 , Processed in 0.062781 second(s), 45 queries .
