- 打卡等级:常住居民I
- 打卡总天数:78
- 最近打卡:2026-07-21 13:27:09
- 积分
- 1069
39-DSP32–DSP指令-32位64位整数运算器,STC32G144K246实验箱演示程序
主程序main.C代码如下(汇编版本在附件中):
串口1(P3.6,P3.7)打印计算结果:115200,N,8,1
可通过屏蔽 lib 文件,用示波器测量IO口低电平时间,来对比芯片硬件32位/64位整数运算单元与标准算法库的计算效率
下载时, 选择IRC频率 48MHz,主时钟使用 PLL 90MHz 时钟频率.
#include "..\comm\STC32G144K246.h"
#include <math.h>
typedef unsigned char u8;
typedef unsigned int u16;
typedef unsigned long u32;
#define SEL_HPLL1 1
#define SEL_HPLL2 2
#define HPLL_SEL SEL_HPLL2
#if(HPLL_SEL==SEL_HPLL1)
#define MAIN_Fosc 120000000L //定义主时钟(超频)
#else
#define MAIN_Fosc 90000000L //定义主时钟
#endif
#define Baudrate 115200L
#define PrintUart 1 //1:printf 使用 UART1; 2:printf 使用 UART2
u16 Key1_cnt;
bit Key1_Flag;
bit Key1_Function;
volatile char c1 = 1, c2 = -2, c3 = 3;
volatile unsigned char uc1 = 1, uc2 = 2, uc3 = 3;
volatile int i1 = 1, i2 = -2, i3 = 3;
volatile long l1 = 1, l2 = -2, l3 = 3;
volatile unsigned long ul1 = 1, ul2 = 2, ul3 = 3;
/**************** 本地引脚定义 **************/
sbit TPIN = P4^7;
sbit KEY1 = P3^2;
void HPLL_config(void);
void UartInit(void);
void KeyScan(void);
void delay_ms(u16 ms);
EAXFR = 1; //扩展寄存器(XFR)访问使能
CKCON = 0; //提高访问XRAM速度
P3M1 = 0x00; P3M0 = 0x80; //设置P3.7推挽输出
P4M1 = 0x00; P4M0 = 0x80; //设置P4.7推挽输出
P3PU |= 0x04; //P32使能内部上拉电阻
HPLL_config();
UartInit();
delay_ms(1);
KeyScan();
if(Key1_Function)
Key1_Function = 0;
TPIN = 0;
c2 = -2; c3 = 3;
c1 = c2 % c3; // -2%3=-2
printf("-2%%3(=-2)=%d\n",(int)c1);
c2 = -2; c3 = 3;
c1 = c2 / c3; // -2/3=0
printf("-2/3(=0)=%d\n",(int)c1);
uc2 = 2; uc3 = 3;
uc1 = uc2 % uc3; // 2%3=2
printf("2%%3(=2)=%u\n",(unsigned int)uc1);
i2 = -2, i3 = 3;
i1 = i2 % i3; // -2%3=-2
printf("-2%%3(=-2)=%d\n",i1);
l2 = -2, l3 = 3;
l1 = l2 / l3; // -2/3=0 (整数除法)
printf("-2/3(=0)=%ld\n",l1);
l2 = -2, l3 = 3;
l1 = l2 % l3; // -2%3=-2
printf("-2%%3(=-2)=%ld\n",l1);
ul2 = 2, ul3 = 3;
ul1 = ul2 / ul3; // 2/3=0 (整数除法)
printf("2/3(=0)=%lu\n",ul1);
ul2 = 2, ul3 = 3;
ul1 = ul2 % ul3; // 2%3=2
printf("2%%3(=2)=%lu\n",ul1);
TPIN = 1;
// 函数: void HPLL_config(void)
// 描述: PLL时钟配置函数。
// 参数: none.
// 版本: VER1.0
// 日期: 2025-11-01
// 备注:
#if(HPLL_SEL==SEL_HPLL2)
WTST = 2; //通过WTST增加等待时钟控制Flash读取速度在33MHz以内, 主时钟:360MHz/2/2=90MHz, 读Flash速度:90MHz/(1+2)=30MHz
HPLLCR |= 0x80; //使能HPLL(高速外设默认使用HPLL时钟,切换到HPLL2前要先使能HPLL,切换完再关闭HPLL)
//首先需要将HIRC主频调节到48MHz
HPLL2CR &= ~0x10; //选择HPLL2输入时钟源为HIRC
// HPLL2CR |= 0x10; //选择HPLL2输入时钟源为IRCM
HPLL2PDIV = 8; //设置HPLL2输入时钟预分频为8(HPLL输入频率必须为6MHz)
// HPLL2CR |= 0x00; //HPLL2=6MHz*52=312MHz
// HPLL2CR |= 0x01; //HPLL2=6MHz*54=324MHz
// HPLL2CR |= 0x02; //HPLL2=6MHz*56=336MHz
// HPLL2CR |= 0x03; //HPLL2=6MHz*58=348MHz
HPLL2CR |= 0x04; //HPLL2=6MHz*60=360MHz
// HPLL2CR |= 0x05; //HPLL2=6MHz*62=372MHz
// HPLL2CR |= 0x06; //HPLL2=6MHz*64=384MHz
// HPLL2CR |= 0x07; //HPLL2=6MHz*66=396MHz
// HPLL2CR |= 0x08; //HPLL2=6MHz*68=408MHz
// HPLL2CR |= 0x09; //HPLL2=6MHz*70=420MHz
// HPLL2CR |= 0x0a; //HPLL2=6MHz*72=432MHz
// HPLL2CR |= 0x0b; //HPLL2=6MHz*74=444MHz
// HPLL2CR |= 0x0c; //HPLL2=6MHz*76=456MHz
// HPLL2CR |= 0x0d; //HPLL2=6MHz*78=468MHz
// HPLL2CR |= 0x0e; //HPLL2=6MHz*80=480MHz
// HPLL2CR |= 0x0f; //HPLL2=6MHz*82=492MHz
HPLL2CR |= 0x20; //高速外设时钟选择 HPLL2/2
HPLL2CR |= 0x80; //使能HPLL2
HPLLCR &= ~0x80; //关闭HPLL(高速外设默认使用HPLL时钟,切换到HPLL2前要先使能HPLL,切换完再关闭HPLL)
CLKDIV = 2; //系统时钟 = 主时钟源/2 = HPLL2/2/2 = 90MHz
CLKSEL = 0x08; //选择HPLL2/2作为主时钟源
#else
WTST = 3; //通过WTST增加等待时钟控制Flash读取速度在33MHz以内, 主时钟:480MHz/2/2=120MHz, 读Flash速度:120MHz/(1+3)=30MHz
HPLLCR &= ~0x10; //选择HPLL输入时钟源为HIRC
// HPLLCR |= 0x10; //选择HPLL输入时钟源为IRCM
HPLLPDIV = 8; //设置HPLL输入时钟预分频为8(HPLL输入频率必须为6MHz)
// HPLLCR |= 0x00; //HPLL=6MHz*52=312MHz
// HPLLCR |= 0x01; //HPLL=6MHz*54=324MHz
// HPLLCR |= 0x02; //HPLL=6MHz*56=336MHz
// HPLLCR |= 0x03; //HPLL=6MHz*58=348MHz
// HPLLCR |= 0x04; //HPLL=6MHz*60=360MHz
// HPLLCR |= 0x05; //HPLL=6MHz*62=372MHz
// HPLLCR |= 0x06; //HPLL=6MHz*64=384MHz
// HPLLCR |= 0x07; //HPLL=6MHz*66=396MHz
// HPLLCR |= 0x08; //HPLL=6MHz*68=408MHz
// HPLLCR |= 0x09; //HPLL=6MHz*70=420MHz
// HPLLCR |= 0x0a; //HPLL=6MHz*72=432MHz
// HPLLCR |= 0x0b; //HPLL=6MHz*74=444MHz
// HPLLCR |= 0x0c; //HPLL=6MHz*76=456MHz
// HPLLCR |= 0x0d; //HPLL=6MHz*78=468MHz
HPLLCR |= 0x0e; //HPLL=6MHz*80=480MHz
// HPLLCR |= 0x0f; //HPLL=6MHz*82=492MHz
HPLL2CR &= ~0x60; //高速外设时钟选择 HPLL/2
CLKDIV = 2; //系统时钟=主时钟源/2 = HPLL/2/2 = 120MHz
CLKSEL = 0x04; //选择HPLL/2作为主时钟源
#endif
// P5M0 |= 0x10; P5M1 &= ~0x10;//设置P5.4口为推挽输出
// P5SR &= ~0x10; //设置P5.4口为快速模式
// HIRCCR |= 0x10; //输出系统时钟
// MCLKOCR = 10; //系统时钟 10 分频到P5.4
// 函数: void KeyScan(void)
// 描述: 按键扫描函数。
// 参数: none.
// 版本: VER1.0
// 日期: 2025-11-01
// 备注:
void KeyScan(void)
if(!KEY1)
if(!Key1_Flag)
Key1_cnt++;
if(Key1_cnt >= 50) //50ms防抖
Key1_Flag = 1; //设置按键状态,防止重复触发
Key1_Function = 1;
Key1_cnt = 0;
Key1_Flag = 0;
// 函数: void delay_ms(unsigned int ms)
// 描述: 延时函数。
// 参数: ms,要延时的ms数.
// 版本: VER1.0
// 日期: 2025-11-01
// 备注: 由于芯片使能了Cache功能,软件延时时间可能不太准确
u16 i;
do{
i = MAIN_Fosc / 6000;
while(--i);
}while(--ms);
void UartInit(void)
#if(PrintUart == 1)
S1_S1 = 0; //UART1 switch to, 00: P3.0 P3.1, 01: P3.6 P3.7, 10: P1.6 P1.7, 11: P4.3 P4.4
S1_S0 = 1;
SCON = (SCON & 0x3f) | 0x40;
T1x12 = 1; //定时器时钟1T模式
S1BRT = 0; //串口1选择定时器1为波特率发生器
TL1 = TM;
TH1 = TM>>8;
TR1 = 1; //定时器1开始计时
// SCON = (SCON & 0x3f) | 0x40;
// T2L = TM;
// T2H = TM>>8;
// AUXR |= 0x15; //串口1选择定时器2为波特率发生器
#else
S2_S = 1; //UART2 switch to: 0: P1.0 P1.1, 1: P4.6 P4.7
S2CON = (S2CON & 0x3f) | 0x40;
T2L = TM;
T2H = TM>>8;
AUXR |= 0x14; //定时器2时钟1T模式,开始计时
#endif
#if(PrintUart == 1)
SBUF = dat;
while(TI==0);
TI = 0;
#else
S2BUF = dat;
while(S2TI == 0);
S2TI = 0; //Clear Tx flag
#endif
char putchar(char c)
UartPutc(c);
return c;
