如题,换了两个不同批次的芯片一样的程序,测试版芯片就ok换新买的芯片就没有数值。
mcu采用1s锂电降压到3.3v供电,电源为锂电池,用73k电阻接电池正极两串分压接地取1/2电池电压接入VRef引脚,
取两次电压之和得到检测电压,程序如下:
void ADCinit()
P_SW2|=0x80;
ADCTIM=0x3f;
P_SW2&=0x7f;
ADCCFG = 0x2f; //设置ADC时钟为系统时钟/2/16/16
ADC_CONTR = 0x80;
/************ADC数据显示************/
void ShowResult(uint cl)
uint ADCbg;
uchar a1;
// P1M0 = 0x00; //设置P1.7为ADC口
// P1M1 = 0xff;
for(a1=0;a1<8;a1++)
ADC_CONTR |= cl; //使能ADC模块 选择15通道
ADC_CONTR |= 0x40; //启动AD转换
while (!(ADC_CONTR & 0x20)); //查询ADC完成标志
ADC_CONTR &= ~0x20; //清完成标志
ADCbg=(ADC_RES<<8)|ADC_RESL;
if(a1==3)//第一次采样
Vx=(uint)(4096L**BGV/ADCbg);
if(a1==7)//第二次采样累加
Vx=Vx+(uint)(4096L**BGV/ADCbg);
用isp里面的例程如下:
#include "reg51.h"
#define FOSC 11059200UL
#define BRT (65536 - FOSC / 115200 / 4)
sfr AUXR = 0x8e;
sfr ADC_CONTR = 0xbc;
sfr ADC_RES = 0xbd;
sfr ADC_RESL = 0xbe;
sfr ADCCFG = 0xde;
sfr P_SW2 = 0xba;
#define ADCTIM (*(unsigned char volatile xdata *)0xfea8)
sfr P0M1 = 0x93;
sfr P0M0 = 0x94;
sfr P1M1 = 0x91;
sfr P1M0 = 0x92;
sfr P2M1 = 0x95;
sfr P2M0 = 0x96;
sfr P3M1 = 0xb1;
sfr P3M0 = 0xb2;
sfr P4M1 = 0xb3;
sfr P4M0 = 0xb4;
sfr P5M1 = 0xc9;
sfr P5M0 = 0xca;
int *BGV; //内部1.19V参考信号源值存放在idata中
//idata的EFH地址存放高字节
//idata的F0H地址存放低字节
//电压单位为毫伏(mV)
bit busy;
void UartIsr() interrupt 4
if (TI)
TI = 0;
busy = 0;
if (RI)
RI = 0;
void UartInit()
SCON = 0x50;
TMOD = 0x00;
TL1 = BRT;
TH1 = BRT >> 8;
TR1 = 1;
AUXR = 0x40;
busy = 0;
void UartSend(char dat)
while (busy);
busy = 1;
SBUF = dat;
void ADCInit()
P_SW2 |= 0x80;
ADCTIM = 0x3f; //设置ADC内部时序
P_SW2 &= 0x7f;
ADC_CONTR = 0x8f; //使能ADC模块,并选择第15通道
int ADCRead()
int res;
res = (ADC_RES << 8) | ADC_RESL; //读取ADC结果
return res;
int res;
int vcc;
int i;
P0M0 = 0x00;
P0M1 = 0x00;
P1M0 = 0x00;
P1M1 = 0x00;
P2M0 = 0x00;
P2M1 = 0x00;
P3M0 = 0x00;
P3M1 = 0x00;
P4M0 = 0x00;
P4M1 = 0x00;
P5M0 = 0x00;
P5M1 = 0x00;
BGV = (int idata *)0xef;
ADCInit(); //ADC初始化
UartInit(); //串口初始化
ES = 1;
// ADCRead();
// ADCRead(); //前两个数据建议丢弃
res = 0;
for (i=0; i<8; i++)
res += ADCRead(); //读取8次数据
res >>= 3; //取平均值
// vcc = (int)(1024L * *BGV / res); //(10位ADC算法)计算VREF管脚电压,即电池电压
vcc = (int)(4096L * *BGV / res); //(12位ADC算法)计算VREF管脚电压,即电池电压
//注意,此电压的单位为毫伏(mV)
UartSend(vcc >> 8); //输出电压值到串口
UartSend(vcc);
while (1);
串口返回数据00 00
同一块板子换老的测试版芯片返回数据08 4f或者08 4d
芯片图片如下:
