查看: 2251|回复: 5
STC8H第15路采样固定输出0X3FF
发表于 2023-5-29 23:36:56 | 显示全部楼层 |阅读模式
MCU:STC8H1K08
工作频率:22.118
VCC:5V
ADC_VRef+:5V
  1. void GPIO_Init (void)
  2. {
  3.     //设置IO端口模式
  4.     P0M0 = 0x00; P0M1 = 0x00;
  5.     P1M0 = 0x14; P1M1 = 0x03;
  6.     P2M0 = 0x00; P2M1 = 0x00;
  7.     P3M0 = 0x1c; P3M1 = 0x6c;
  8.     P4M0 = 0x00; P4M1 = 0x00;
  9.     P5M0 = 0x00; P5M1 = 0x00;
  10.     P6M0 = 0x00; P6M1 = 0x00;
  11.     P7M0 = 0x00; P7M1 = 0x00;
  12.     P1IE = 0xfc;
  13.     P3IE = 0x9f;
  14.     P_SW2 |= 0x80;                              //使能XFR
  15.     P_SW2 |= 0x30;                               //切换<i>I2C引脚</i>SCL_4/P3.2, SDA_4/P3.3
  16. }
  1. void ADC_init(void)
//串口这么用的采的是第15路 1.19V内置电压
TI = 1;
printf("adc4:%d\n",GitADC(15));
TI = 0;
仿真显示ADCbuff值为 0x3f,串口使用pintf()函数输出的是1024附近的值
原理图
原理图
 楼主| 发表于 2023-5-30 08:57:29 | 显示全部楼层
  1. int GitADC (unsigned char CH)
  2. {
  3.     int ADCbuff;
  4.         ADC_RES = 0;
  5.         ADC_RESL = 0;
  6.     CH &= 0xf0;
  7.     ADC_CONTR |= CH;
  8.     ADC_CONTR |=0x40;
  9.     Delay500us();
  10.     ADCbuff = ADC_RES<<8;
  11.     return ADCbuff |=ADC_RESL;
  12. }
  1. void ADC_Init(void)
  2. {
  3.     ADCTIM = 0x2A;                              //����ADC�ڲ�ʱ��
  4.     ADCCFG = 0x20;                              //右对齐
  5.         ADC_RES = 0;
  6.         ADC_RESL = 0;
  7.     ADC_CONTR = 0xc0;                           //ʹ�ܲ�����ADCģ��
  8. }
  1. void ADC_Isr() interrupt 5
  2. {
  3.     ADC_CONTR &= ~0x20;                         //���жϱ�־
  4. }
 楼主| 发表于 2023-5-30 08:59:45 | 显示全部楼层
  1.         TI = 1;
  2.         //printf("VREF:%d\n",GitADC(0));
  3.         //printf("RREF:%d\n",GitADC(1));
  4.         //printf("VOUT:%d\n",GitADC(14));
  5.         //printf("VIN:%d\n",GitADC(13));
  6.         printf("adc4:%d\n",GitADC(15));
  7.         TI = 0;
发表于 2023-5-30 09:02:22 | 显示全部楼层
烧录附件例程到芯片里试试,串口1(P3.0,P3.1)打印采样结果,波特率115200,N,8,1。
烧录时, 选择IRC时钟 24MHz
16路ADC轮询-每路16次ADC转换取中间8次求平均值-串口1返回结果.zip
10.98 KB, 下载次数: 208
 楼主| 发表于 2023-5-30 09:25:03 | 显示全部楼层
烧录时, 选择IRC时钟  ...
[09:24:26.575]接收←STC8H系列ADC测试程序!
[09:24:26.778]接收←ADC00=0216
[09:24:26.981]接收←ADC01=0037
[09:24:27.184]接收←ADC02=0000
[09:24:27.387]接收←ADC03=0000
[09:24:27.590]接收←ADC04=0000
[09:24:27.793]接收←ADC05=0000
[09:24:27.997]接收←ADC06=0000
[09:24:28.200]接收←ADC07=0000
[09:24:28.403]接收←ADC08=1023
[09:24:28.606]接收←ADC09=1023
[09:24:28.809]接收←ADC10=1018
[09:24:29.028]接收←ADC11=1018
[09:24:29.231]接收←ADC12=1023
[09:24:29.426]接收←ADC13=0084
[09:24:29.629]接收←ADC14=0967
[09:24:29.832]接收←Bandgap=0243
发表于 2023-5-30 09:29:41 | 显示全部楼层
用例程测试没问题,内部参考电压根据15通道采样值计算出来差不多是1.19V左右:
GMT+8, 2026-11-8 01:40 , Processed in 0.073698 second(s), 65 queries .
