void PWM_config(void)
PWMx_InitDefine PWMx_InitStructure;
PWMx_InitStructure.PWM_Mode = CCMRn_ROLLOVER; //模式, CCMRn_FREEZE,CCMRn_MATCH_VALID,CCMRn_MATCH_INVALID,CCMRn_ROLLOVER,CCMRn_FORCE_INVALID,CCMRn_FORCE_VALID,CCMRn_PWM_MODE1,CCMRn_PWM_MODE2
PWMx_InitStructure.PWM_Duty = PWMB_Duty.PWM5_Duty; //PWM占空比时间, 0~Period
PWMx_InitStructure.PWM_EnoSelect = ENO5P; //输出通道选择, ENO1P,ENO1N,ENO2P,ENO2N,ENO3P,ENO3N,ENO4P,ENO4N / ENO5P,ENO6P,ENO7P,ENO8P
PWM_Configuration(PWM5, &PWMx_InitStructure); //初始化PWM, PWMA,PWMB
PWMx_InitStructure.PWM_Duty = PWMB_Duty.PWM6_Duty; //PWM占空比时间, 0~Period
PWMx_InitStructure.PWM_EnoSelect = ENO6P; //输出通道选择, ENO1P,ENO1N,ENO2P,ENO2N,ENO3P,ENO3N,ENO4P,ENO4N / ENO5P,ENO6P,ENO7P,ENO8P
PWM_Configuration(PWM6, &PWMx_InitStructure); //初始化PWM, PWMA,PWMB
PWMx_InitStructure.PWM_Duty = PWMB_Duty.PWM7_Duty; //PWM占空比时间, 0~Period
PWMx_InitStructure.PWM_EnoSelect = ENO7P; //输出通道选择, ENO1P,ENO1N,ENO2P,ENO2N,ENO3P,ENO3N,ENO4P,ENO4N / ENO5P,ENO6P,ENO7P,ENO8P
PWM_Configuration(PWM7, &PWMx_InitStructure); //初始化PWM, PWMA,PWMB
PWMx_InitStructure.PWM_Mode = CCMRn_PWM_MODE1; //模式, CCMRn_FREEZE,CCMRn_MATCH_VALID,CCMRn_MATCH_INVALID,CCMRn_ROLLOVER,CCMRn_FORCE_INVALID,CCMRn_FORCE_VALID,CCMRn_PWM_MODE1,CCMRn_PWM_MODE2
PWMx_InitStructure.PWM_Duty = PWMB_Duty.PWM8_Duty; //PWM占空比时间, 0~Period
PWMx_InitStructure.PWM_EnoSelect = ENO8P; //输出通道选择, ENO1P,ENO1N,ENO2P,ENO2N,ENO3P,ENO3N,ENO4P,ENO4N / ENO5P,ENO6P,ENO7P,ENO8P
PWM_Configuration(PWM8, &PWMx_InitStructure); //初始化PWM, PWMA,PWMB
PWMx_InitStructure.PWM_Period = 2400; //周期时间, 0~65535
PWMx_InitStructure.PWM_DeadTime = 0; //死区发生器设置, 0~255
PWMx_InitStructure.PWM_MainOutEnable= ENABLE; //主输出使能, ENABLE,DISABLE
PWMx_InitStructure.PWM_CEN_Enable = ENABLE; //使能计数器, ENABLE,DISABLE
PWM_Configuration(PWMB, &PWMx_InitStructure); //初始化PWM通用寄存器, PWMA,PWMB
NVIC_PWM_Init(PWMB,DISABLE,Priority_0);
// PWM5_SW(PWM5_SW_P20); //PWM5_SW_P20,PWM5_SW_P17,PWM5_SW_P00,PWM5_SW_P74
PWM6_SW(PWM6_SW_P01); //PWM6_SW_P21,PWM6_SW_P54,PWM6_SW_P01,PWM6_SW_P75
PWM7_SW(PWM7_SW_P02); //PWM7_SW_P22,PWM7_SW_P33,PWM7_SW_P02,PWM7_SW_P76
PWM8_SW(PWM8_SW_P03); //PWM8_SW_P23,PWM8_SW_P34,PWM8_SW_P03,PWM8_SW_P77
PWMB_OC7_RelosdDisable();
// PWMB_CC8P_LowValid();
PWMB_CC7P_HighValid();
