查看: 64|回复: 0
用STC8H8K64U做一个GPS时钟
  • 打卡总天数:366
  • 最近打卡:2026-05-30 00:01:31
发表于 2026-5-14 21:51:35 | 显示全部楼层 |阅读模式
用几块钱的材料动手做了一个GPS时钟。
主要的代码由豆包生成。
#include <STC8H.H>
#include <intrins.h>
#include <string.h>
typedef unsigned char  u8;
typedef unsigned int   u16;
typedef unsigned long  u32;
// 硬件引脚
sbit LCD_CLK  = P3^6;
sbit LCD_DAT  = P3^7;
sbit LCD_RS   = P3^5;
sbit LCD_RST  = P3^4;
#define FOSC 35000000L
// 时钟变量
u8 year=26, mon=5, day=10;
u8 hour=17, min=22, sec=0;
u8 week=0;
u16 ms_cnt = 0;
bit gps_valid = 0;
bit gps_synced = 0;
u8 last_display_sec = 0xFF;
u8 slow_refresh_cnt = 0;
// GPS定位信息变量
u32 latitude = 0;          // 纬度,格式:DDMM.MMMM,实际存储为度数*1000000
u32 longitude = 0;         // 经度,格式:DDDMM.MMMM,实际存储为度数*1000000
u16 altitude = 0;
u8  satellite = 0;
u16 speed = 0,speed_kmh=0;
char lat_dir = 'N';        // 纬度方向 N/S
char lon_dir = 'E';        // 经度方向 E/W
u8 gps_display_buf[256];  // 用于显示的GPS数据缓冲区
bit gps_data_ready = 0;   // GPS数据更新标志
u8 last_valid_lat_lon[50]; // 保存最后一次有效的经纬度字符串
// 显示模式
bit disp_mode = 0;
u8 disp_cnt = 0;
code u8 week_table[7][4]={"SUN","MON","TUE","WED","THU","FRI","SAT"};
code u8 ASCII[][5] = {
    // 数字 '0' - 索引0
    {0x3E,0x41,0x41,0x3E,0x00},  // 0x3E=00111110, 0x41=01000001, 0x41=01000001, 0x3E=00111110 -> 显示0
    // 数字 '1' - 索引1
    {0x00,0x42,0x7F,0x40,0x00},  // 0x7F=01111111(全亮竖线), 0x42=01000010, 0x40=01000000 -> 显示1
    // 数字 '2' - 索引2
    {0x62,0x51,0x49,0x46,0x00},  // 01100010,01010001,01001001,01000110 -> 显示2
    // 数字 '3' - 索引3
    {0x42,0x49,0x49,0x36,0x00},  // 01000010,01001001,01001001,00110110 -> 显示3
    // 数字 '4' - 索引4
    {0x1C,0x12,0x7F,0x10,0x00},  // 00011100,00010010,01111111,00010000 -> 显示4
    // 数字 '5' - 索引5
    {0x4F,0x49,0x49,0x31,0x00},  // 01001111,01001001,01001001,00110001 -> 显示5
    // 数字 '6' - 索引6
    {0x3E,0x49,0x49,0x30,0x00},  // 00111110,01001001,01001001,00110000 -> 显示6
    // 数字 '7' - 索引7
    {0x00,0x03,0x71,0x09,0x07},  // 00000000,00000011,01110001,00001001,00000111 -> 显示7
    // 数字 '8' - 索引8
    {0x36,0x49,0x49,0x36,0x00},  // 00110110,01001001,01001001,00110110 -> 显示8
    // 数字 '9' - 索引9
    {0x06,0x49,0x49,0x3E,0x00},  // 00000110,01001001,01001001,00111110 -> 显示9
    // 空格 ' ' - 索引10
    {0x00,0x00,0x00,0x00,0x00},  // 全0,空白字符
    // 短横线 '-' - 索引11
    {0x08,0x08,0x08,0x08,0x08},  // 00001000重复5次 -> 显示一条水平线
    // 冒号 ':' - 索引12
    {0x00,0x00,0x24,0x00,0x00},  // 00000000,00000000,00100100,00000000,00000000 -> 显示上下两个点
    // 字母 'A' - 索引13
    {0x7C,0x12,0x11,0x7C,0x00},  // 01111100,00010010,00010001,01111100 -> 显示A
    // 字母 'B' - 索引14
    {0x7F,0x49,0x49,0x36,0x00},  // 01111111,01001001,01001001,00110110 -> 显示B
    // 字母 'C' - 索引15
    {0x3E,0x41,0x41,0x22,0x00},  // 00111110,01000001,01000001,00100010 -> 显示C
    // 字母 'D' - 索引16
    {0x7F,0x41,0x41,0x3E,0x00},  // 01111111,01000001,01000001,00111110 -> 显示D
    // 字母 'E' - 索引17
    {0x7F,0x49,0x49,0x41,0x00},  // 01111111,01001001,01001001,01000001 -> 显示E
    // 字母 'F' - 索引18
    {0x7F,0x09,0x09,0x01,0x00},  // 01111111,00001001,00001001,00000001 -> 显示F
    // 字母 'G' - 索引19
    {0x3E,0x41,0x49,0x72,0x00},  // 00111110,01000001,01001001,01110010 -> 显示G
    // 字母 'H' - 索引20
    {0x7F,0x08,0x08,0x7F,0x00},  // 01111111,00001000,00001000,01111111 -> 显示H
    // 字母 'I' - 索引21
    {0x00,0x7F,0x00,0x00,0x00},  // 00000000,01111111,00000000,00000000,00000000 -> 显示I(竖线)
    // 字母 'J' - 索引22
    {0x40,0x40,0x3F,0x00,0x00},  // 01000000,01000000,00111111,00000000,00000000 -> 显示J
    // 字母 'K' - 索引23
    {0x7F,0x08,0x14,0x63,0x00},  // 01111111,00001000,00010100,01100011 -> 显示K
    // 字母 'L' - 索引24
    {0x7F,0x40,0x40,0x40,0x00},  // 01111111,01000000,01000000,01000000 -> 显示L
    // 字母 'M' - 索引25
    {0x7F,0x02,0x04,0x02,0x7F},  // 01111111,00000010,00000100,00000010,01111111 -> 显示M
    // 字母 'N' - 索引26
    {0x7F,0x04,0x08,0x10,0x7F},  // 01111111,00000100,00001000,00010000,01111111 -> 显示N
    // 字母 'O' - 索引27
    {0x3E,0x41,0x41,0x41,0x3E},  // 00111110,01000001,01000001,01000001,00111110 -> 显示O
    // 字母 'P' - 索引28
    {0x7F,0x09,0x09,0x06,0x00},  // 01111111,00001001,00001001,00000110,00000000 -> 显示P
    // 字母 'Q' - 索引29
    {0x3E,0x41,0x51,0x7E,0x00},  // 00111110,01000001,01010001,01111110,00000000 -> 显示Q
    // 字母 'R' - 索引30
    {0x7F,0x09,0x19,0x66,0x00},  // 01111111,00001001,00011001,01100110,00000000 -> 显示R
    // 字母 'S' - 索引31
    {0x26,0x49,0x49,0x32,0x00},  // 00100110,01001001,01001001,00110010,00000000 -> 显示S
    // 字母 'T' - 索引32
    {0x01,0x01,0x7F,0x01,0x01},  // 00000001,00000001,01111111,00000001,00000001 -> 显示T
    // 字母 'U' - 索引33
    {0x3F,0x40,0x40,0x3F,0x00},  // 00111111,01000000,01000000,00111111,00000000 -> 显示U
    // 字母 'V' - 索引34
    {0x07,0x18,0x60,0x18,0x07},  // 00000111,00011000,01100000,00011000,00000111 -> 显示V
    // 字母 'W' - 索引35
    {0x7F,0x20,0x10,0x20,0x7F},  // 01111111,00100000,00010000,00100000,01111111 -> 显示W
    // 字母 'X' - 索引36
    {0x63,0x14,0x08,0x14,0x63},  // 01100011,00010100,00001000,00010100,01100011 -> 显示X
    // 字母 'Y' - 索引37
    {0x03,0x0C,0x70,0x0C,0x03},  // 00000011,00001100,01110000,00001100,00000011 -> 显示Y
    // 字母 'Z' - 索引38
    {0x61,0x51,0x49,0x45,0x43},   // 01100001,01010001,01001001,01000101,01000011 -> 显示Z
    {0x00,0x0C,0x12,0x0C,0x00},  // 39: °
    //{0x00,0x00,0x10,0x20,0x00}   // 40: '
    //{0x04,0x00,0x00,0x00,0x00}   // 底部
    //{0x01,0x02,0x00,0x00,0x00},  // 两个点斜向右下
    {0x02,0x01,0x00,0x00,0x00}   // 两个点斜向左下
u8 uart2_buf[256];
u8 uart2_cnt = 0;
bit uart2_done = 0;
// 函数声明
void GPIO_Init(void);
void delayms(u16 ms);
void Lcd_WriteByte(u8 dat);
void Lcd_WriteCmd(u8 cmd);
void Lcd_WriteData(u8 dat);
void Lcd_SetPos(u8 x, u8 y);
void Lcd_Clear(void);
void Lcd_Init(void);
void LCD_ShowChar(u8 x, u8 y, u8 ch);
void LCD_ShowStr(u8 x, u8 y, u8 *str);
void LCD_ShowNum(u8 x, u8 y, u32 num, u8 len);
void ShowDate(void);
void ShowTime(void);
void UART2_Init(void);
void UART2_ISR(void);
void GPS_Update(void);
void ParseGPGGA(void);
void Local_Time(void);
void ShowAllInfo(void);
void ShowLatLon(void);
u8 ZellerWeek(u8 year, u8 mon, u8 day);  // 蔡勒公式计算星期函数声明
// 蔡勒公式计算星期
// 输入:年(0-99实际为2000-2099),月(1-12),日(1-31)
// 输出:0-6 对应星期日到星期六
    u16 y, m, c;
    u16 week;
    // 将月份转换为蔡勒公式要求的格式(3月=1,4月=2,...,1月=13,2月=14)
    if (mon == 1 || mon == 2) {
        m = mon + 12;      // 1月=13,2月=14
        y = (year - 1 + 2000) % 100;  // 年份减1
        c = (year - 1 + 2000) / 100;  // 世纪数
    } else {
        m = mon;
        y = (year + 2000) % 100;
        c = (year + 2000) / 100;
    // 蔡勒公式:week = (y + y/4 + c/4 - 2*c + 26*(m+1)/10 + day - 1) mod 7
    week = (y + y/4 + c/4 - 2*c + (26*(m+1))/10 + day - 1) % 7;
    // 转换为0-6,0=星期日,1=星期一,...,6=星期六
    return (u8)week;
// LCD 驱动
    P3M0 |= 0xF8;
    P3M1 &= 0x07;
    u16 i,j;
    for(i=ms;i>0;i--)
        for(j=1100;j>0;j--);
    u8 i;
    for(i=0;i<8;i++)
        LCD_CLK=0;
        LCD_DAT=(dat&0x80);
        dat<<=1;
        LCD_CLK=1;
void Lcd_WriteCmd(u8 cmd)  { LCD_RS=0; Lcd_WriteByte(cmd); }
void Lcd_WriteData(u8 dat){ LCD_RS=1; Lcd_WriteByte(dat); }
void Lcd_SetPos(u8 x,u8 y)
    y = (y+4)%8;
    Lcd_WriteCmd(0xB0 | y);
    Lcd_WriteCmd(0x00 | (x&0x0F));
    Lcd_WriteCmd(0x10 | (x>>4));
    u8 i,j;
    for(i=0;i<8;i++)
        Lcd_SetPos(0,i);
        for(j=0;j<132;j++) Lcd_WriteData(0x00);
void Lcd_Init(void)
    LCD_RST=0; delayms(200);
    LCD_RST=1; delayms(100);
    Lcd_WriteCmd(0xE2); delayms(10);
    Lcd_WriteCmd(0xAE);
    Lcd_WriteCmd(0xA2);
    Lcd_WriteCmd(0xA0);
    Lcd_WriteCmd(0xC8);
    Lcd_WriteCmd(0x2F);
    Lcd_WriteCmd(0x81);
    Lcd_WriteCmd(0x20);
    Lcd_WriteCmd(0xAF);
void LCD_ShowChar(u8 x,u8 y,u8 ch)
    u8 i,idx=10;
    if(ch>='0'&&ch<='9') idx=ch-'0';
    else if(ch=='-') idx=11;
    else if(ch==':') idx=12;
    else if(ch>='A'&&ch<='Z') idx=13+ch-'A';
    else if(ch == 0xDF) idx = 39;
    else if(ch == 0x27) idx = 40;
    else if(ch==' ') idx=10;
    Lcd_SetPos(x,y);
    for(i=0;i<5;i++) Lcd_WriteData(ASCII[idx][i]);
void LCD_ShowStr(u8 x,u8 y,u8 *str)
    while(*str) { LCD_ShowChar(x,y,*str); x+=6; str++; }
    u8 buf[12];
    u8 i;
    buf[len] = 0;
    for(i=len; i>0; i--)
        buf[i-1] = (num % 10) + '0';
        num /= 10;
    LCD_ShowStr(x, y, buf);
void ShowDate(void)
    u8 buf[16];
    buf[0]='2'; buf[1]='0';
    buf[2]=(year/10)+'0';
    buf[3]=(year%10)+'0';
    buf[4]='-';
    buf[5]=(mon/10)+'0';
    buf[6]=(mon%10)+'0';
    buf[7]='-';
    buf[8]=(day/10)+'0';
    buf[9]=(day%10)+'0';
    buf[10]=0;
    LCD_ShowStr(10,2,buf);
    LCD_ShowStr(76,2,(u8*)week_table[week]);
    if(gps_valid)
        LCD_ShowStr(100,2,(u8*)"A");
        LCD_ShowStr(100,2,(u8*)"-");
void ShowTime(void)
    u8 buf[16];
    buf[0]=hour/10+'0'; buf[1]=hour%10+'0'; buf[2]=':';
    buf[3]=min/10+'0';  buf[4]=min%10+'0';  buf[5]=':';
    buf[6]=sec/10+'0';  buf[7]=sec%10+'0';  buf[8]=0;
    LCD_ShowStr(20,3,buf);
// 串口2
    P1M0 &= ~0x02;
    P1M1 |= 0x02;
    S2CON = 0x50;
    AUXR |= 0x04;
    T2L = 0x71;
    T2H = 0xFC;
    AUXR |= 0x10;
    IE2 |= 0x01;
void UART2_ISR(void) interrupt 8
    u8 ch;
    if(S2CON & 0x01)
        S2CON &= ~0x01;
        ch = S2BUF;
        if(uart2_cnt < sizeof(uart2_buf) - 2)
            uart2_buf[uart2_cnt++] = ch;
        // ? 只在遇到换行符时标记一帧
        if(ch == '\n')
            uart2_buf[uart2_cnt] = 0;
            uart2_done = 1;
// GPS解析(更新版,添加经纬度解析)
    u8 *p;
    u8 temp_sat = 0;
    u16 temp_alt = 0;
    u8 cnt = 0;
    u8 i;
    p = strstr((char*)uart2_buf, "$GPGGA");
    if(p == 0)
        p = strstr((char*)uart2_buf, "$GNGGA");
        if(p == 0) return;
    /* ---------- 卫星数(第7个逗号) ---------- */
    cnt = 0;
    for(i = 0; p[i] && p[i]!='*'; i++)
        if(p[i] == ',')
            cnt++;
            if(cnt == 7)
                i++;
                while(p[i] >= '0' && p[i] <= '9')
                    temp_sat = temp_sat * 10 + (p[i] - '0');
                    i++;
                satellite = temp_sat;   // ? 允许 0
                break;
    /* ---------- 海拔(第9个逗号) ---------- */
    cnt = 0;
        if(p[i] == ',')
            cnt++;
            if(cnt == 9)
                i++;
                while((p[i] >= '0' && p[i] <= '9') || p[i] == '.')
                    if(p[i] == '.') { i++; break; }
                    temp_alt = temp_alt * 10 + (p[i] - '0');
                    i++;
                if(temp_alt < 5000)
                    altitude = temp_alt;
                break;
    u8 *p;
    u8 hh,mm,ss,dd,mmd,yy;
    u8 status;
    u16 temp_hour;
    u8 i;
    p = strstr((char*)uart2_buf, "$GPRMC");
    if(p == 0) return;
    p += 7;
    if(p[0] < '0' || p[0] > '9') return;
    hh = (p[0] - '0') * 10 + (p[1] - '0');
    mm = (p[2] - '0') * 10 + (p[3] - '0');
    ss = (p[4] - '0') * 10 + (p[5] - '0');
    p = strchr(p, ',');
    if(p == 0) return;
    p++;
    status = *p;
    gps_valid = (status == 'A') ? 1 : 0;
    if(!gps_valid) return;
    // 保存有效的经纬度数据到显示缓冲区
    memcpy(gps_display_buf, uart2_buf, uart2_cnt + 1);
    gps_data_ready = 1;
    // 解析速度
// 跳到第 7 个逗号(速度字段)
for(i=0; i<6; i++)
    p = strchr(p, ',');
    if(p == 0) return;
    p++;
speed = 0;
while((*p >= '0' && *p <= '9') || *p == '.')
    if(*p == '.')
        p++;
        break;
    speed = speed * 10 + (*p - '0');
    p++;
speed_kmh = speed * 1852 /1000;
    // 跳转到日期
    for(i=0; i<1; i++) {
        p = strchr(p, ',');
        if(p == 0) return;
        p++;
    dd  = (p[0] - '0') * 10 + (p[1] - '0');
    mmd = (p[2] - '0') * 10 + (p[3] - '0');
    yy  = (p[4] - '0') * 10 + (p[5] - '0');
    temp_hour = hh + 8;
    if(temp_hour >= 24)
        temp_hour -= 24;
        dd++;
        if(dd > 31) { dd = 1; mmd++; }
        if(mmd > 12) { mmd = 1; yy++; }
    hour = (u8)temp_hour;
    min = mm;
    sec = ss;
    day = dd;
    mon = mmd;
    year = yy;
    // 使用蔡勒公式计算星期
    week = ZellerWeek(year, mon, day);
    gps_synced = 1;
    static u16 local_ms = 0;
    local_ms++;
    if(local_ms >= 1000)
        local_ms = 0;
        if(!gps_valid)   // ? 只有在 GPS 无效时才自增
            sec++;
            if(sec >= 60)
                sec = 0;
                min++;
                if(min >= 60)
                    min = 0;
                    hour++;
                    if(hour >= 24) hour = 0;
// 主函数
// 修改主函数中的while循环部分
    u8 display_counter = 0;
    // 初始化时使用蔡勒公式计算初始星期
    GPIO_Init();
    UART2_Init();
    Lcd_Init();
    Lcd_Clear();
    delayms(500);
    // 初始显示
    ShowAllInfo();
        ms_cnt++;
        if(ms_cnt >= 20)
            ms_cnt = 0;
            Local_Time();
        if(uart2_done)
            if(strstr((char*)uart2_buf, "$GPRMC") ||
               strstr((char*)uart2_buf, "$GNRMC"))
                GPS_Update();
            if(strstr((char*)uart2_buf, "$GPGGA") ||
               strstr((char*)uart2_buf, "$GNGGA"))
                ParseGPGGA();
             uart2_cnt = 0;
            uart2_done = 0;
        // 每100ms刷新一次显示
        display_counter++;
        if(display_counter >= 2)  // 约200ms刷新一次
            ShowAllInfo();
        if(strstr((char*)uart2_buf, "$GPGGA"))
        delayms(100);
// 新增函数:在一屏内显示所有信息(包含经纬度)
    u8 buf[20];
    // 第0行:卫星数和GPS状态
    buf[0] = 'S';
    buf[1] = 'A';
    buf[2] = 'T';
    buf[3] = ':';
    buf[4] = (satellite/10)+'0';
    buf[5] = (satellite%10)+'0';
    if(gps_valid)
        buf[6] = 'A';
        buf[7] = 0;
        buf[6] = '-';
        buf[7] = 0;
    LCD_ShowStr(0, 0, buf);
    // 第8行:海拔
    buf[0] = 'A';
    buf[1] = 'L';
    buf[2] = 'T';
    buf[3] = ':';
    buf[4] = (altitude/1000)+'0';
    buf[5] = ((altitude%1000)/100)+'0';
    buf[6] = ((altitude%100)/10)+'0';
    buf[7] = (altitude%10)+'0';
    buf[8] = 'm';
    buf[9] = 0;
    LCD_ShowStr(0, 7, buf);
    // 第2行:速度
    buf[0] = 'S';
    buf[1] = 'P';
    buf[2] = 'D';
    buf[3] = ':';
    buf[4] = (speed_kmh/100)? (speed_kmh/100)%10+'0' : ' ';
    buf[5] = (speed_kmh/10)? (speed_kmh/10)%10+'0' : ' ';
    buf[6] = (speed_kmh%10)+'0';
    buf[7] = 'K';
    buf[8] = 'M';
    buf[9] = 'H';
    buf[10] = 0;
    LCD_ShowStr(0, 2, buf);
    // 第8行:日期
    buf[4]='-';
    buf[7]='-';
    buf[10]=0;
    LCD_ShowStr(55, 7, buf);
    // 星期
    LCD_ShowStr(116, 7, (u8*)week_table[week]);
    // 第4行:时间
    LCD_ShowStr(40, 5, buf);
    // 第5-6行:经纬度
    ShowLatLon();
// 新增:显示经纬度函数
    u8 buf[30];
    u8 *p;
    u8 lat_deg, lat_min;
    u8 lon_deg, lon_min;
    u8 lat_dir_char, lon_dir_char;  // 所有变量声明在开头
    if(gps_data_ready && gps_valid)
        p = strstr((char*)gps_display_buf, "$GPRMC");
        if(p)
            p += 7;
            p = strchr(p, ','); if(p) p++;
            if(p && p[0] >= '0' && p[0] <= '9')
                lat_deg = (p[0] - '0') * 10 + (p[1] - '0');
                lat_min = (p[2] - '0') * 10 + (p[3] - '0');
                p = strchr(p, ',');
                if(p) p++;
                lat_dir_char = *p;
                // 手动拼接纬度字符串
                buf[0] = lat_dir_char;
                buf[1] = lat_deg/10 + '0';
                buf[2] = lat_deg%10 + '0';
                buf[3] = 0xDF;
                buf[4] = lat_min/10 + '0';
                buf[5] = lat_min%10 + '0';
                buf[6] = 0x27;
                buf[7] = 0;
                LCD_ShowStr(45, 0, buf);
                // 跳转到经度
                p = strchr(p, ',');
                if(p) p++;
                    lon_deg = (p[0] - '0') * 100 + (p[1] - '0') * 10 + (p[2] - '0');
                    lon_min = (p[3] - '0') * 10 + (p[4] - '0');
                    p = strchr(p, ',');
                    if(p) p++;
                    lon_dir_char = *p;
                    // 手动拼接经度字符串(包含分钟符号)
//                    buf[0] = 'L'; buf[1] = 'O'; buf[2] = 'N'; buf[3] = ':';
                    buf[1] = lon_deg/100 + '0';
                    buf[2] = (lon_deg%100)/10 + '0';
                    buf[3] = lon_deg%10 + '0';
                    buf[4] = 0xDF;
                    buf[5] = lon_min/10 + '0';
                    buf[6] = lon_min%10 + '0';
                    buf[7] = 0x27;      // 分钟符号
                    buf[0] = lon_dir_char;  // 方向字母
                    buf[8] = 0;          // 结束符
                    LCD_ShowStr(88, 0, buf);
//        LCD_ShowStr(0, 5, (u8*)"LAT:--- --' ");
//        LCD_ShowStr(0, 6, (u8*)"LON:--- --' ");
GMT+8, 2026-5-30 04:44 , Processed in 0.098132 second(s), 42 queries .
