查看: 317|回复: 2
stc32g12k128读写问题
发表于 2026-5-9 09:37:00 | 显示全部楼层 |阅读模式
这个是官方例程的iap.c代码
#include "stc.h"
#include "iap.h"
void iap_init()
    IAP_CONTR = 0x80;
    IAP_TPS = FOSC / 1000000;
BOOL iap_check_addr(DWORD addr)
    addr &= 0x1ffff;
    return ((addr < 0x10000) ||
            (addr >= (0x10000 + LDR_SIZE)));
BYTE iap_read_byte(DWORD addr)
    return *(BYTE ecode *)(addr | 0x00fe0000);
BOOL iap_write_byte(DWORD addr, BYTE dat)
    if (!iap_check_addr(addr))
        return 0;
    IAP_CMD = 2;
    IAP_ADDRE = BYTE2(addr) & 0x01;
    IAP_ADDRH = BYTE1(addr);
    IAP_ADDRL = BYTE0(addr);
    IAP_DATA = dat;
    IAP_TRIG = 0x5a;
    IAP_TRIG = 0xa5;
    return (iap_read_byte(addr) == dat);
void iap_erase_page(DWORD addr)
        return;
    IAP_CMD = 3;
    IAP_TRIG = 0x5a;
    IAP_TRIG = 0xa5;
Q1如果要擦除FE:1000H到FE:FFFFH
      addr=0x1000;
      while (addr < 0x10000)
            iap_erase_page(addr);
            addr += 0x200;
Q2如果要擦除FF:1000H到FF:FFFFH
      addr=0x11000;
      while (addr < 0x20000)
            addr += 0x200;
这样操作对吗
发表于 2026-5-9 10:30:37 | 显示全部楼层
地址没错,FE:0000H~FE:FFFFH 区域的IAP操作地址是 0x000000~0x00FFFF
FF:0000H~FF:FFFFH 区域的IAP操作地址是 0x010000~0x01FFFF
 楼主| 发表于 2026-5-9 10:57:17 | 显示全部楼层
FF:0000H~FF:FFFFH 区域的IAP操作地 ...
感谢大佬
GMT+8, 2026-11-7 12:10 , Processed in 0.066546 second(s), 51 queries .
