- 打卡等级:初来乍到
- 打卡总天数:3
- 最近打卡:2026-04-30 08:20:38
- 积分
- 28
本例程基于AI8051U为主控芯片的实验箱进行编写测试.
用STC的MCU的IO方式控制74HC595驱动8位数码管。
显示效果为: 数码时钟.
使用Timer0的16位自动重装来产生1ms节拍,程序运行于这个节拍下, 用户修改MCU主时钟频率时,自动定时于1ms.
下载时, 选择时钟 24MHZ (用户可自行修改频率).
#include "AI8051U.h"
#include "stdio.h"
#include "stc32_stc8_usb.h"
#define MAIN_Fosc 24000000UL
#define DIS_DOT 0x20
#define DIS_BLACK 0x10
#define DIS_ 0x11
u8 code t_display[]={ //标准字库
sbit P_HC595_SER = P3^4; //pin 14 SER data input
sbit P_HC595_RCLK = P3^5; //pin 12 RCLk store (latch) clock
sbit P_HC595_SRCLK = P3^2; //pin 11 SRCLK Shift data clock
u8 LED8[8]; //显示缓冲
u8 display_index; //显示位索引
bit B_1ms; //1ms标志
u8 hour,minute,second;
u16 msecond;
/**************** 外部函数声明和外部变量声明 *****************/
/********************** 显示时钟函数 ************************/
void DisplayRTC(void)
if(hour >= 10) LED8[0] = hour / 10;
else LED8[0] = DIS_BLACK;
LED8[1] = hour % 10;
LED8[2] = DIS_;
LED8[3] = minute / 10;
LED8[4] = minute % 10;
LED8[5] = DIS_;
LED8[6] = second / 10;
LED8[7] = second % 10;
/********************** RTC演示函数 ************************/
void RTC(void)
if(++second >= 60)
second = 0;
if(++minute >= 60)
minute = 0;
if(++hour >= 24) hour = 0;
u8 i,k;
EAXFR = 1; //扩展寄存器(XFR)访问使能
CKCON = 0; //提高访问XRAM速度
P_SW2 |= 0x80;
usb_init(); //USB CDC 接口配置
T0x12 = 1; //Timer0 set as 1T, 16 bits timer auto-reload,
TR0 = 1; //Tiner0 run
EA = 1; //打开总中断
display_index = 0;
hour = 11; //初始化时间值
minute = 59;
second = 58;
RTC();
DisplayRTC();
// for(i=0; i<8; i++) LED8 = DIS_BLACK; //上电消隐
for(i=0; i<8; i++) LED8 = i; //显示01234567
k = 0;
if (bUsbOutReady)
USB_SendData(UsbOutBuffer,OutNumber); //发送数据缓冲区,长度(接收数据原样返回, 用于测试)
usb_OUT_done();
if(B_1ms) //1ms到
B_1ms = 0;
if(++msecond >= 1000) //1秒到
// P42 = !P42;
msecond = 0;
RTC();
DisplayRTC();
/**************** 向HC595发送一个字节函数 ******************/
void Send_595(u8 dat)
u8 i;
for(i=0; i<8; i++)
dat <<= 1;
P_HC595_SER = CY;
P_HC595_SRCLK = 1;
P_HC595_SRCLK = 0;
void DisplayScan(void)
Send_595(t_display[LED8[display_index]]); //输出段码
Send_595(~T_COM[display_index]); //输出位码
P_HC595_RCLK = 1;
P_HC595_RCLK = 0;
DisplayScan(); //1ms扫描显示一位
B_1ms = 1; //1ms标志
