查看: 1731|回复: 5
麻烦大家帮忙看一下,LCD显示汉字,汉字显示正常,最上面多了一条虚线。
  • 打卡总天数:228
  • 最近打卡:2025-10-29 07:37:28
发表于 2023-5-19 11:00:24 | 显示全部楼层 |阅读模式
typedef struct
        unsigned char Index[4];
        unsigned char Msk[128];
}typFNT_GB32;
"康",0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0xFE,0xFF,0xFF,0xFF,0xF8,0xFF,
0xFF,0xFF,0xF9,0xFF,0xDF,0xFF,0xFB,0xE7,0x1F,0x00,0x00,0xC0,0x9F,0xFF,0xFD,0xFF,
0x9F,0xFF,0xF9,0xFF,0x9F,0xFF,0xFD,0xFE,0x9F,0x01,0x00,0xFC,0x9F,0xFF,0xFD,0xFC,
0x9F,0xFF,0xFD,0xFC,0x9F,0xFF,0xFD,0xE4,0x1F,0x00,0x00,0xC0,0x9F,0xFF,0xFD,0xFC,
0x9F,0xFF,0xFD,0xFC,0x9F,0x01,0x00,0xFC,0x9F,0xFF,0xF5,0xFE,0x9F,0xFB,0xF5,0xF3,
0x9F,0xE7,0xF5,0xE1,0xDF,0xCF,0xED,0xFC,0xDF,0xCF,0x4C,0xFE,0xCF,0x1F,0x9D,0xFF,
0xEF,0xCF,0x9D,0xFF,0xEF,0xE3,0x3D,0xFF,0xE7,0xF8,0x7D,0xFC,0x77,0xFC,0xFC,0xE0,
0xFB,0x1E,0xFC,0xE1,0xFB,0x7F,0xFC,0xF7,0xFD,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*"康",2*/
"佳",0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF7,0xFF,0xFF,0xF9,0xC7,0xFF,
0xFF,0xF8,0xE7,0xFF,0xFF,0xFC,0xE7,0xFF,0xFF,0xFC,0xE7,0xFF,0x7F,0xFE,0xE7,0xF9,
0x7F,0x0E,0x00,0xF0,0x7F,0xFF,0xE7,0xFF,0x3F,0xFF,0xE7,0xFF,0x3F,0xFE,0xE7,0xFF,
0x5F,0xFE,0xE7,0xFF,0x4F,0xFE,0xE7,0xE7,0x6F,0x02,0x00,0xC0,0x77,0xFE,0xFF,0xFF,
0x7B,0xFE,0xE7,0xFF,0x7D,0xFE,0xC7,0xFF,0x7F,0xFE,0xE7,0xFF,0x7F,0xFE,0xE7,0xFF,
0x7F,0xFE,0xE7,0xFB,0x7F,0x0E,0x00,0xF0,0x7F,0xFE,0xE7,0xFF,0x7F,0xFE,0xE7,0xFF,
0x7F,0xFE,0xE7,0xFF,0x7F,0xFE,0xE7,0xFF,0x7F,0xFE,0xE7,0xFF,0x7F,0xFE,0xE7,0xE7,
0x7F,0x00,0x00,0xC0,0x7F,0xFE,0xFF,0xFF,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*"佳",3*/
#include "config.h"
#include        "STC32G_SPI.h"
#include        "LCD_TFT.h"
#include "face_word.h"
#include        "ASCII_8x16_H.h"
char xdata buffer2[2000];
char *digit_code[13]={num0,num1,num2,num3,num4,num5,num6,num7,num8,num9,num10,num11,num12}; //指针数组,建立数字与字模的联系
// 函数: void LCD_delay(u16 ms)
// 描述: 延时函数
// 参数: ms 延时时间 1~65535 ms
// 返回: 无
// 版本:
    u16 i;
        do{
        //        i = MAIN_Fosc / 14000;        //STC12F
        //        i = MAIN_Fosc / 13000;        //STC15F
        //        i = MAIN_Fosc / 10000;        //STC8
                i = MAIN_Fosc / 6000;        //STC32G
                while(--i)        ;
    }while(--ms);
      函数说明:LCD串行数据写入函数
      入口数据:dat  要写入的串行数据
      返回值:  无
void transfer_data(unsigned int data1)//需要传送命令时加DC=0
    CS=0;//怀疑这里的CS就是SPI的SS
    SPSTAT=0xc0;//写一清零指令,最迷惑人的指令,明明在写一,作用是清零
    SPDAT=data1;
    while(!SPIF)
        ;    //等待发送完成
函数: void LCD_SetWindows(u16 xStar, u16 yStar,u16 xEnd,u16 yEnd)
功能: 设置lcd显示窗口,在此区域写点数据自动换行. 每行从 xStar开始 到yStar结束, 如果xStar==yStar则只写一点便换行, 可以用于画竖线.
入口: xy起点和终点
返回: 无
//设置显示窗口函数,是基本函数
void lcd_address(unsigned int x_start,unsigned int y_start,unsigned int x_end,unsigned int y_end)
//  unsigned short int x = x_start + 2,y=x_end+ 2;//屏参数2,不加参数时屏幕显示出亮边
    unsigned int x = x_start ,y=x_end;//屏参数2
    DC=0;
    transfer_data(0x2a);     //Column address set
    DC=1;
    transfer_data(x>>8);    //start column
    transfer_data(x);
    transfer_data(y>>8);    //end column
    transfer_data(y);
    //x = y_start + 1;//加1为偏移值,屏参数
    x = y_start;//加1为偏移值,屏参数
    //y=y_end+ 1;
    y = y_end;
    DC=0;
    transfer_data(0x2b);     //Row address set
    DC=1;
    transfer_data(x>>8);    //start row
    transfer_data(x);
    transfer_data(y>>8);    //end row
    transfer_data(y);
    DC=0;
    transfer_data(0x2C);     //Memory write
    DC=1;
void DMASPI_initial(void)//批量数据传送时需要在命令执行完后先执行一下初始化,方便以后快速调用数据传送指令
    DMA_SPI_TXAH=0;
    DMA_SPI_TXAL=0;//只使用一个缓存数组时,简化该函数的形式,用起来更方便。地址是xdata的起始地址01:0000H
    DMA_SPI_AMTH=0;
    DMA_SPI_AMT=0;
    DMA_SPI_STA=0;//清中断标志位及错误标志位
//刷屏幕图像,把显示缓冲区的数据刷到屏幕上,也叫批量传送函数
void SPI_DMA_test(unsigned int num,char xdata *Q)//num为传送数据个数,受buffer空间限制,Q为使用的在xdata处的缓冲数组地址指针;
    unsigned long addr;
    addr=(unsigned long)(Q);//取地址指针的当前值,一般就是首地址值了
    DMA_SPI_TXAH=(addr)>>8;
    DMA_SPI_TXAL=addr;//只使用一个缓存数组时,简化该函数的形式,用起来更方便。地址是xdata的起始地址01:0000H
    DMA_SPI_AMTH=(num-1)>>8;
    DMA_SPI_AMT=(num-1);
    DMA_SPI_CR=0xc1;//开始执行,采用主机模式,并清空FIFO,这句明显要跟着程序走的
//使用DMA_SPI显示字符时,首先把数据传到buffer,然后开显示窗口,再传数据就行了。
    while(!(DMA_SPI_STA&0x01))
        ;    //等待吧。这时可以做其它事,比如去读一个AD值,最佳任务是处理中断。这个模式有可能丢掉数据,导致部分显示图像与原数据不同
    DMASPI_initial();//
// 函数: void LCD_Fill_XY(u8 x0,u16 y0,u8 x,u16 y,u16 color)
// 描述: 给屏填充开始坐标为x0,y0,长x,高y,以color的数据至各点中
// 参数: x0,y0 开始坐标,  x 长,        y 高, color: 要填充的颜色数据
// 返回: 无
// 版本: V1.0
void LCD_Fill_XY(u16 x0,u16 y0,u16 x,u16 y,u16 color)
    unsigned int i,j;
    char xdata *p;
    lcd_address(x0,y0,x,y);//示范围
    for(j=0; j<64; j++)
        p=public_buf;
        for(i=0; i<1200; i++)
            *p=(color>>8);
            p++;
            *p=(color);
            p++;
        SPI_DMA_test(2400,public_buf);
void word16x16_bydma_spi(unsigned int x,unsigned int y,unsigned char code *p,int16 font_color,int16 back_color,char xdata *Q)
    unsigned char column=0;
    unsigned char tm=0,temp;
    unsigned long kee;
//  char *point;
    char xdata *kkee;
    kkee=Q;//这是保留缓冲区指针初值
//  point=digit_code[segin];//把要显示的数字(segin)转换成对应的字模地址point
    //先把字模数据转换成屏显所用数据存到缓冲区,因为写入缓冲区是并行处理,且没有其它操作。所以比写屏快很多
    for(column=0; column<64; column++) //字节数循环,逐个字节进行转换
        temp=*p;//*point是原字模数据指针,取出原字模数值
        //把字节信息换算成屏需要的数据,送到缓冲区
        for(tm=0; tm<8; tm++)
            if(temp&0x01)//注意这是低位先出模式,如果与字模不符,可以考虑改为高位先出模式
                *Q=(font_color>>8);//Q是缓冲区指针
                Q++;
                *Q=(font_color);
                Q++;
                *Q=(back_color>>8);
                Q++;
                *Q=(back_color);
                Q++;
            temp>>=1;
        p++;
//开始刷屏,因为由DMA_SPI操作,基本不需要占用mcu时间。
    lcd_address(x,y,x+15,y+15);
    kee=(unsigned int)(kkee);//取缓冲区首地址的值,也就是打算发送给屏幕的数据源地址的值
    DMA_SPI_TXAH=(kee)>>8;//把源地值高位赋给地址寄存器
    DMA_SPI_TXAL=kee;//地址是xdata的起始地址
    DMA_SPI_AMTH=1;//0x01,表示的传送总数据量是15*15*2/255
    DMA_SPI_AMT=255;//0xff
    Q=kkee;//缓冲区指针复位
        ;    //等待吧。这时可以做其它事,比如去读一个AD值,这个模式有可能丢掉数据,导致部分显示图像与原数据不同
    DMASPI_initial();//
//高级应用之字符显示程序--借助普通字模数组的显示程序,其中带有转换语句。方便显示不常用字符
void word16x32_bydma_spi(unsigned int x,unsigned int y,unsigned char segin,int font_color,int back_color,char *Q)
    unsigned long kee;
    char *point;
    char *kkee;
        temp=*point;//*point是原字模数据指针,取出原字模数值
                Q++;
                *Q=(font_color);
                Q++;
                *Q=(back_color>>8);
                Q++;
                *Q=(back_color);
                Q++;
            temp>>=1;
        point++;
    lcd_address(x,y,x+15,y+31);
    DMA_SPI_AMTH=3;//0x03,表示的传送总数据量是3ffh+1,也就是1024
    Q=kkee;//缓冲区指针复位
    DMASPI_initial();//
void word32x32_bydma_spi(unsigned int x,unsigned int y,unsigned char code *p,int font_color,int back_color,char xdata *Q)
    unsigned long kee;
//  char *point;
    char xdata *kkee;
    for(column=0; column<128; column++) //字节数循环,逐个字节进行转换
                Q++;
                *Q=(font_color);
                Q++;
                *Q=(back_color>>8);
                Q++;
                *Q=(back_color);
                Q++;
            temp>>=1;
        p++;
    lcd_address(x,y,x+31,y+31);
    DMA_SPI_AMTH=7;//0x01,表示的传送总数据量是15*15*2/255
    Q=kkee;//缓冲区指针复位
    DMASPI_initial();//
      函数说明:LCD初始化函数
      入口数据:无
      返回值:  无
void Lcd_Init(void)
//  SPI_SCK_1;          //特别注意!!
    RST=0;
    LCD_delay(100);//1000
    RST=1;
    //TFT_SEND_CMD(0x11);           //Sleep Out
    DC=0;
    transfer_data(0x11);
    DC=1;
    LCD_delay(120);               //DELAY120ms
    //-----------------------ST7789V Frame rate setting-----------------//
    //  TFT_SEND_CMD(0x3A);        //65k mode
    DC=0;
    transfer_data(0x3a);
    DC=1;
    transfer_data(0x05);
    //TFT_SEND_CMD(0xC5);       //VCOM
    DC=0;
    transfer_data(0xc5);
    DC=1;
    transfer_data(0x1A);
    // TFT_SEND_CMD(0x36);                 // 屏幕显示方向设置
    DC=0;
    transfer_data(0x36);
    DC=1;
    //transfer_data(0x00);//竖屏值
   // # if(UPSIDE_LCD==1)
                //transfer_data(0xA0);//试验一下,希望是横屏,成功了60,A0旋转180度
                //#endif
                //# if(UPSIDE_LCD==0)
                transfer_data(0x60);//试验一下,希望是横屏,成功了60,A0旋转180度
   // #endif
                //-------------ST7789V Frame rate setting-----------//
    //  TFT_SEND_CMD(0xb2);       //Porch Setting
    DC=0;
    transfer_data(0xb2);
    DC=1;
    transfer_data(0x33);
    // TFT_SEND_CMD(0xb7);           //Gate Control
    DC=0;
    transfer_data(0xb7);
    DC=1;
    transfer_data(0x05);           //12.2v   -10.43v
    //--------------ST7789V Power setting---------------//
    //   TFT_SEND_CMD(0xBB);//VCOM
    DC=0;
    transfer_data(0xbb);
    DC=1;
    transfer_data(0x3F);
    //   TFT_SEND_CMD(0xC0); //Power control
    DC=0;
    transfer_data(0xc0);
    DC=1;
    transfer_data(0x2c);
    //    TFT_SEND_CMD(0xC2);       //VDV and VRH Command Enable
    DC=0;
    transfer_data(0xc2);
    DC=1;
    transfer_data(0x01);
    //   TFT_SEND_CMD(0xC3);           //VRH Set
    DC=0;
    transfer_data(0xc3);
    DC=1;
    transfer_data(0x0F);        //4.3+( vcom+vcom offset+vdv)
    //   TFT_SEND_CMD(0xC4);           //VDV Set
    DC=0;
    transfer_data(0xc4);
    DC=1;
    transfer_data(0x20);                //0v
    //     TFT_SEND_CMD(0xC6);               //Frame Rate Control in Normal Mode
    DC=0;
    transfer_data(0xc6);
    DC=1;
    transfer_data(0X01);           //111Hz
    //    TFT_SEND_CMD(0xd0);               //Power Control 1
    DC=0;
    transfer_data(0xd0);
    DC=1;
    transfer_data(0xa4);
    transfer_data(0xa1);
    //   TFT_SEND_CMD(0xE8);               //Power Control 1
    DC=0;
    transfer_data(0xe8);
    DC=1;
    transfer_data(0x03);
    //    TFT_SEND_CMD(0xE9);               //Equalize time control
    DC=0;
    transfer_data(0xe9);
    DC=1;
    transfer_data(0x09);
    transfer_data(0x08);
    //---------------ST7789V gamma setting-------------//
    //  TFT_SEND_CMD(0xE0); //Set Gamma
    DC=0;
    transfer_data(0xe0);
    DC=1;
    transfer_data(0xD0);
    transfer_data(0x14);
    transfer_data(0x28);
    transfer_data(0x07);
    transfer_data(0x13);
    transfer_data(0x30);
    //   TFT_SEND_CMD(0XE1); //Set Gamma
    DC=0;
    transfer_data(0xe1);
    DC=1;
    transfer_data(0x24);
    transfer_data(0x32);
    transfer_data(0x3B);
    transfer_data(0x2F);
    //   TFT_SEND_CMD(0x20);       //反显
    DC=0;
    DC=1;
    //   TFT_SEND_CMD(0x29);         //开启显示
    DC=0;
    transfer_data(0x29);
    DC=1;
      函数说明:显示单个16x16汉字
      入口数据:x,y显示坐标
                *s 要显示的汉字
                fc 字的颜色
                bc 字的背景色
                sizey 字号
      返回值:  无
void LCD_ShowChinese16x16(u16 x,u16 y,u8 *s,u16 fc,u16 bc,u8 sizey)
          u8  i;
    u16 k;
    u16 HZnum;              //汉字数目
    u16 TypefaceNum;        //一个字符所占字节大小
    u16 x0=x;
    TypefaceNum=(sizey/8+((sizey%8)?1:0))*sizey;
    HZnum=sizeof(tfont16)/sizeof(typFNT_GB16);  //统计汉字数目
    for(k=0;k<HZnum;k++)
        if((tfont16[k].Index[0]==*(s))&&(tfont16[k].Index[1]==*(s+1)))
                                          for(i=0;i<TypefaceNum;i++)
                                                           word16x16_bydma_spi(x,y,&tfont16[k].Index[i],fc,bc,public_buf);//时间
                                                        break;
        continue;  //查找到对应点阵字库立即退出,防止多个汉字重复取模带来影响
      函数说明:显示单个32x32汉字
      入口数据:x,y显示坐标
                *s 要显示的汉字
                fc 字的颜色
                bc 字的背景色
                sizey 字号
                mode:  0非叠加模式  1叠加模式
      返回值:  无
void LCD_ShowChinese32x32(u16 x,u16 y,u8 *s,u16 fc,u16 bc,u8 sizey)
    u8 i,j,m=0;
    u16 k;
    u16 HZnum;//汉字数目
    u16 TypefaceNum;//一个字符所占字节大小
    u16 x0=x;
    HZnum=sizeof(tfont32)/sizeof(typFNT_GB32);  //统计汉字数目
    for(k=0; k<HZnum; k++)
        if ((tfont32[k].Index[0]==*(s))&&(tfont32[k].Index[1]==*(s+1)))
          for(i=0; i<TypefaceNum; i++)
                 word32x32_bydma_spi( x, y,&tfont32[k].Index[i],fc,bc,public_buf);
                 break;
      函数说明:显示汉字串
      入口数据:x,y显示坐标
                *s 要显示的汉字串
                fc 字的颜色
                bc 字的背景色
                sizey 字号 可选 16 24 32
                mode:  0非叠加模式  1叠加模式
      返回值:  无
void LCD_ShowChinese(u16 x,u16 y,u8 *s,int16 fc,int16 bc,u8 sizey)
    while(*s!=0)
        if(sizey==16)
                                        LCD_ShowChinese16x16(x,y,s,fc,bc,sizey);
                                else  if(sizey==32)
                                        LCD_ShowChinese32x32(x,y,s,fc,bc,sizey);
            return;
        s+=2;
        x+=sizey;
//=======显示===========================
LCD_ShowChinese(100,100,"康佳",LIGHTBLUE,MAGENTA,32);
麻烦帮忙看一下,网站的程序原来数组显示的,改成直接输入汉字显示的,现在汉字的最上面多了一条虚线。
  • 打卡总天数:228
发表于 2023-5-19 12:40:13 | 显示全部楼层
补发一张LCD显示图片
  • 打卡总天数:136
  • 最近打卡:2025-06-19 15:40:05
47
发表于 2023-5-19 14:34:34 | 显示全部楼层
有仿真的话建议在显示字符第一个数据的时候直接打个断点,没仿真的话先显示单个字符或者数字看看是不是正常,单个字符正常再看的单个汉字,以此类推
  • 打卡总天数:228
发表于 2023-5-19 15:01:28 | 显示全部楼层
电子DI*** 发表于 2023-5-19 14:34
有仿真的话建议在显示字符第一个数据的时候直接打个断点,没仿真的话先显示单个字符或者数字看看是不是正常 ...
谢谢! 单个字符正常,问题出在这里。
    u8 i,j,m=0;
    u16 k;
    u16 HZnum;//汉字数目
    u16 x0=x;
                 word32x32_bydma_spi( x, y,&tfont32[k].Index,fc,bc,public_buf);//单独用这个显示正常
                 break;
  • 打卡等级:常住居民II
  • 打卡总天数:85
  • 最近打卡:2025-06-16 17:34:54
发表于 2023-5-19 15:56:32 | 显示全部楼层
感谢冲哥答疑,欢迎楼主后续有疑难或者开发心得继续发帖!
  • 打卡总天数:42
  • 最近打卡:2025-10-23 17:23:52
发表于 2023-5-19 15:57:45 | 显示全部楼层
感谢冲哥答疑,冲哥辛苦了!
GMT+8, 2025-10-30 03:19 , Processed in 0.128154 second(s), 84 queries .
