查看: 378|回复: 4
STC8H3K64S4芯片IO中断处理问题
发表于 2026-2-25 14:44:12 | 显示全部楼层 |阅读模式
main.c文件
#include "stc8h.h"
// 定义E1~E8引脚
sbit E1 = P4^5;
sbit E2 = P2^7;
sbit E3 = P2^6;
sbit E4 = P2^5;
sbit E5 = P2^4;
sbit E6 = P0^2;
sbit E7 = P0^1;
sbit E8 = P4^6;
sbit RST_ALL = P0^3;
// 定义MOS_E1~MOS_E8引脚
sbit MOS_E1 = P5^1;
sbit MOS_E2 = P4^4;
sbit MOS_E3 = P2^1;
sbit MOS_E4 = P2^3;
sbit MOS_E5 = P5^2;
sbit MOS_E6 = P0^5;
sbit MOS_E7 = P0^7;
sbit MOS_E8 = P5^5;
// 定义E1~E8复位引脚
sbit RST_E1 = P5^0;
sbit RST_E2 = P4^3;
sbit RST_E3 = P2^0;
sbit RST_E4 = P2^2;
sbit RST_E5 = P0^4;
sbit RST_E6 = P5^3;
sbit RST_E7 = P0^6;
sbit RST_E8 = P5^4;
#define u8 unsigned char
#define u16 unsigned int
#define u32 unsigned long
#define Delay1ms 1
// #define Delay10ms 10
#define Delay10ms 20
u8 prev_ch;
// 延时函数
void DelayXms(int T) {
    while(T--) {
        int i = 2352; //@12.000MHz
        while(i--);
// 初始化所有IO为低电平
void InitIO() {
    // E1~E8初始化为输入模式(外部信号输入)
    E1 = E2 = E3 = E4 = E5 = E6 = E7 = E8 = 0;
    // MOS_E1~MOS_E8初始化为低电平
    MOS_E1 = MOS_E2 = MOS_E3 = MOS_E4 = MOS_E5 = MOS_E6 = MOS_E7 = MOS_E8 = 0;
    // 复位引脚初始化
    RST_E1 = RST_E2 = RST_E3 = RST_E4 = RST_E5 = RST_E6 = RST_E7 = RST_E8 = 0;
// 配置端口模式(E1~E8为输入,MOS为推挽输出)
void IOConfigMode() {
    // 配置E1~E8、RST_ALL为高阻输入模式(PxM1=1, PxM0=0)
    // P4.5(E1)、P4.6(E8) -> 高阻输入
    P4M0 = 0x18;
    P4M1 = 0x60;
    // P2.4(E5)、P2.5(E4)、P2.6(E3)、P2.7(E2) -> 高阻输入
    P2M0 = 0x0F;
    P2M1 = 0xF0;
    // P0.1(E7)、P0.2(E6)、P0.3(RST_ALL) -> 高阻输入
    P0M0 = 0xF0;
    P0M1 = 0x0E;
    // P5.0、P5.1、P5.2、P5.3、P5.4、P5.5 -> 推挽输出
    P5M0 = 0x3F;
    P5M1 = 0x00;
// 配置中断模式(上升沿触发)
void InterruptMode() {
    P0IM0 = 0x0E;  // IM0=1(上升沿触发)
    P0IM1 = 0x00;  // IM1=0
    P2IM0 = 0xF0;  // IM0=1(上升沿触发)
    P2IM1 = 0x00;  // IM1=0
    P4IM0 = 0x60;  // IM0=1(上升沿触发)
    P4IM1 = 0x00;  // IM1=0
// 使能中断
void EnableIoInterrupt() {
    // 使能P0.1(E7)、P0.2(E6)、P0.3(RST_ALL)中断
    //P0INTE = 0x06;
    P0INTE = 0x0E;
    // 使能P2.4~P2.7(E2~E5)中断
    P2INTE = 0xF0;
    // 使能P4.5(E1)、P4.6(E8)中断
    P4INTE = 0x60;
// 复位所有开关
void ResetAllSwitch() {
    RST_E1 = RST_E2 = RST_E3 = RST_E4 = RST_E5 = RST_E6 = RST_E7 = RST_E8 = 1;
    DelayXms(Delay10ms);
// 复位其他通道的RST引脚(当前通道除外)
void ResetOtherSwitches(u8 channel) {
    if(prev_ch != channel) {
        // 复位上一个通道
        if(prev_ch == 1) RST_E1 = 1;
        if(prev_ch == 2) RST_E2 = 1;
        if(prev_ch == 3) RST_E3 = 1;
        if(prev_ch == 4) RST_E4 = 1;
        if(prev_ch == 5) RST_E5 = 1;
        if(prev_ch == 6) RST_E6 = 1;
        if(prev_ch == 7) RST_E7 = 1;
        if(prev_ch == 8) RST_E8 = 1;
    if(channel == 1) MOS_E1 = 1;
    if(channel == 2) MOS_E2 = 1;
    if(channel == 3) MOS_E3 = 1;
    if(channel == 4) MOS_E4 = 1;
    if(channel == 5) MOS_E5 = 1;
    if(channel == 6) MOS_E6 = 1;
    if(channel == 7) MOS_E7 = 1;
    if(channel == 8) MOS_E8 = 1;
    DelayXms(Delay10ms);  // 保持10ms,实际大概20ms
        // 复位上一个通道
        if(prev_ch == 1) RST_E1 = 0;
        if(prev_ch == 2) RST_E2 = 0;
        if(prev_ch == 3) RST_E3 = 0;
        if(prev_ch == 4) RST_E4 = 0;
        if(prev_ch == 5) RST_E5 = 0;
        if(prev_ch == 6) RST_E6 = 0;
        if(prev_ch == 7) RST_E7 = 0;
        if(prev_ch == 8) RST_E8 = 0;
	if(channel == 1) MOS_E1 = 0;
    if(channel == 2) MOS_E2 = 0;
    if(channel == 3) MOS_E3 = 0;
    if(channel == 4) MOS_E4 = 0;
    if(channel == 5) MOS_E5 = 0;
    if(channel == 6) MOS_E6 = 0;
    if(channel == 7) MOS_E7 = 0;
    if(channel == 8) MOS_E8 = 0;
// 主函数
void main() {
    InitIO();
    P_SW2 |= 0x80;  // 允许访问扩展寄存器
    IOConfigMode();
    ResetAllSwitch();
    InterruptMode();
    EnableIoInterrupt();
    EA = 1;          // 全局中断使能
    while(1);
// 中断服务程序(中断号13对应P0/P1/P2/P3/P4/P5中断)
void io_isr() interrupt 13 {
    u8 intf0 = P0INTF;
    u8 intf2 = P2INTF;
    u8 intf4 = P4INTF;
    // 处理P0中断(E6, E7)
    if(intf0) {
        if(intf0 & 0x08) {           // P0.3(RST_ALL)中断
            DelayXms(Delay1ms);
            if(RST_ALL == 1) {
                ResetAllSwitch();
                P0INTF &= ~0x08;     // 清除标志
        if(intf0 & 0x04) {           // P0.2(E6)中断
            DelayXms(Delay1ms);
            if(E6 == 1) {
                ResetOtherSwitches(6);
				prev_ch = 6;
                P0INTF &= ~0x04;     // 清除标志
        if(intf0 & 0x02) {           // P0.1(E7)中断
            DelayXms(Delay1ms);
            if(E7 == 1) {
                ResetOtherSwitches(7);
				prev_ch = 7;
                P0INTF &= ~0x02;     // 清除标志
    // 处理P2中断(E2, E3, E4, E5)
    if(intf2) {
        if(intf2 & 0x10) {           // P2.4(E5)中断
            DelayXms(Delay1ms);
            if(E5 == 1) {
                ResetOtherSwitches(5);
				prev_ch = 5;
                P2INTF &= ~0x10;     // 清除标志
        if(intf2 & 0x20) {           // P2.5(E4)中断
            DelayXms(Delay1ms);
            if(E4 == 1) {
                ResetOtherSwitches(4);
				prev_ch = 4;
                P2INTF &= ~0x20;     // 清除标志
        if(intf2 & 0x40) {           // P2.6(E3)中断
            DelayXms(Delay1ms);
            if(E3 == 1) {
                ResetOtherSwitches(3);
				prev_ch = 3;
                P2INTF &= ~0x40;
        if(intf2 & 0x80) {           // P2.7(E2)中断
            DelayXms(Delay1ms);
            if(E2 == 1) {
                ResetOtherSwitches(2);
				prev_ch = 2;
                P2INTF &= ~0x80;     // 清除标志
    // 处理P4中断(E1, E8)
    if(intf4) {
        if(intf4 & 0x20) {           // P4.5(E1)中断
            DelayXms(Delay1ms);
            if(E1 == 1) {
                ResetOtherSwitches(1);
				prev_ch = 1;
                P4INTF &= ~0x20;     // 清除标志
        if(intf4 & 0x40) {           // P4.6(E8)中断
            DelayXms(Delay1ms);
            if(E8 == 1) {
                ResetOtherSwitches(8);
				prev_ch = 8;
                P4INTF &= ~0x40;     // 清除标志
ISR.ASM文件
CSEG       AT 012BH   ;P0口中断入口地址
JMP        P0INT_ISR
P0INT_ISR:
JMP        006BH      ;借用13号中断入口地址
;CSEG       AT 0133H   ;P1口中断入口地址
;JMP        P1INT_ISR
;P1INT_ISR:
;JMP        006BH      ;借用13号中断入口地址
CSEG       AT 013BH   ;P2口中断入口地址
JMP        P2INT_ISR
P2INT_ISR:
;CSEG       AT 0143H   ;P3口中断入口地址
;JMP        P3INT_ISR
;P3INT_ISR:
CSEG       AT 014BH   ;P4口中断入口地址
JMP        P4INT_ISR
P4INT_ISR:
END
;CSEG       AT 0153H   ;P5口中断入口地址
;JMP        P5INT_ISR
;P5INT_ISR:
;END
程序总是会复位其他引脚
发表于 2026-2-25 21:11:19 | 显示全部楼层
 楼主| 发表于 2026-2-26 09:11:17 | 显示全部楼层
可以帮忙看一下是哪里的问题吗
此型号不建议使用此功能,另外中断跳转一般用LJMP [attachimg]132384[/attachimg]  详情 回复 发表于 2026-2-26 11:06
发表于 2026-2-26 11:06:19 | 显示全部楼层
Nin*** 发表于 2026-2-26 09:11
可以帮忙看一下是哪里的问题吗
 楼主| 发表于 2026-2-26 11:12:13 | 显示全部楼层
好的,谢谢
GMT+8, 2026-11-7 12:08 , Processed in 0.073560 second(s), 66 queries .
