楼主 |
发表于 2026-1-6 11:27:41
显示全部楼层
/* --- STC MCU International Limited -------------------------------*/
/* --- STC 1T Series MCU RC Demo -----------------------------------*/
/* --- Mobile: (86)13922805190 -------------------------------------*/
/* --- Fax: 86-0513-55012956,55012947,55012969 ---------------------*/
/* --- Tel: 86-0513-55012928,55012929,55012966 ---------------------*/
/* --- Web: www.GXWMCU.com -----------------------------------------*/
/* --- QQ: 800003751 ----------------------------------------------*/
/* If you want to use the program or the program referenced in the */
/* article, please specify in which data and procedures from STC */
串口1全双工中断方式收发通讯程序。本例程使用22.1184MHZ时钟,如要改变,请修改下面的"定义主时钟"的值并重新编译。
串口设置为:115200,8,n,1.
通过PC向MCU发送数据, MCU收到后通过串口把收到的数据原样返回.
#define MAIN_Fosc 22118400L //定义主时钟
#define RX1_Lenth 32 //串口接收缓冲长度
#define BaudRate1 115200UL //选择波特率
#define Timer1_Reload (65536UL -(MAIN_Fosc / 4 / BaudRate1)) //Timer 1 重装值, 对应300KHZ
#define Timer2_Reload (65536UL -(MAIN_Fosc / 4 / BaudRate1)) //Timer 2 重装值, 对应300KHZ
#include "STC15Fxxxx.H"
u8 idata RX1_Buffer[RX1_Lenth]; //接收缓冲
u8 TX1_Cnt; //发送计数
u8 RX1_Cnt; //接收计数
bit B_TX1_Busy; //发送忙标志
B_TX1_Busy = 0;
RX1_Cnt = 0;
TX1_Cnt = 0;
S1_8bit(); //8位数据
S1_USE_P30P31(); //UART1 使用P30 P31口 默认
// S1_USE_P36P37(); //UART1 使用P36 P37口
// S1_USE_P16P17(); //UART1 使用P16 P17口
TR1 = 0; //波特率使用Timer1产生
AUXR &= ~0x01; //S1 BRT Use Timer1;
AUXR |= (1<<6); //Timer1 set as 1T mode
TH1 = (u8)(Timer1_Reload >> 8);
TL1 = (u8)Timer1_Reload;
TR1 = 1;
AUXR &= ~(1<<4); //Timer stop 波特率使用Timer2产生
AUXR |= 0x01; //S1 BRT Use Timer2;
AUXR |= (1<<2); //Timer2 set as 1T mode
TH2 = (u8)(Timer2_Reload >> 8);
TL2 = (u8)Timer2_Reload;
AUXR |= (1<<4); //Timer run enable
REN = 1; //允许接收
ES = 1; //允许中断
EA = 1; //允许全局中断
if(TX1_Cnt != RX1_Cnt) //收到过数据
if(!B_TX1_Busy) //发送空闲
B_TX1_Busy = 1; //标志发送忙
SBUF = RX1_Buffer[TX1_Cnt]; //发一个字节
if(++TX1_Cnt >= RX1_Lenth) TX1_Cnt = 0; //避免溢出处理
/********************* UART1中断函数************************/
void UART1_int (void) interrupt UART1_VECTOR
if(RI)
RI = 0;
RX1_Buffer[RX1_Cnt] = SBUF; //保存一个字节
if(++RX1_Cnt >= RX1_Lenth) RX1_Cnt = 0; //避免溢出处理
if(TI)
TI = 0;
B_TX1_Busy = 0; //清除发送忙标志
