stc的ISP软件给出的代码有bug,再数据定义上不严谨,是正负数,不是无符号的字节或整数,导致大于0x7f时出错。
原代码与修改的代码如下:
强烈建议stc尽快改掉,以免误导更多的使用者。
一个小小的错误可能会导致使用者花费大量的时间查找错误。
1、是源代码,2、是修改的代码
其实就是将范例中的数据类型前面加上unsigned 即可。
1、源代码:
#include "reg51.h"
sfr P0M1 = 0x93;
sfr P0M0 = 0x94;
sfr P1M1 = 0x91;
sfr P1M0 = 0x92;
sfr P2M1 = 0x95;
sfr P2M0 = 0x96;
sfr P3M1 = 0xb1;
sfr P3M0 = 0xb2;
sfr P4M1 = 0xb3;
sfr P4M0 = 0xb4;
sfr P5M1 = 0xc9;
sfr P5M0 = 0xca;
sfr IAP_DATA = 0xC2;
sfr IAP_ADDRH = 0xC3;
sfr IAP_ADDRL = 0xC4;
sfr IAP_CMD = 0xC5;
sfr IAP_TRIG = 0xC6;
sfr IAP_CONTR = 0xC7;
sfr IAP_TPS = 0xF5;
void IapIdle()
IAP_CONTR = 0; //关闭IAP功能
IAP_CMD = 0; //清除命令寄存器
IAP_TRIG = 0; //清除触发寄存器
IAP_ADDRH = 0x80; //将地址设置到非IAP区域
IAP_ADDRL = 0;
char IapRead(int addr)
char dat;
IAP_CONTR = 0x80; //使能IAP
IAP_TPS = 12; //设置等待参数12MHz
IAP_CMD = 1; //设置IAP读命令
IAP_ADDRL = addr; //设置IAP低地址
IAP_ADDRH = addr >> 8; //设置IAP高地址
IAP_TRIG = 0x5a; //写触发命令(0x5a)
IAP_TRIG = 0xa5; //写触发命令(0xa5)
dat = IAP_DATA; //读IAP数据
IapIdle(); //关闭IAP功能
return dat;
void IapProgram(int addr, char dat)
IAP_CMD = 2; //设置IAP写命令
IAP_DATA = dat; //写IAP数据
void IapErase(int addr)
IAP_CMD = 3; //设置IAP擦除命令
_nop_(); //
P0M0 = 0x00;
P0M1 = 0x00;
P1M0 = 0x00;
P1M1 = 0x00;
P2M0 = 0x00;
P2M1 = 0x00;
P3M0 = 0x00;
P3M1 = 0x00;
P4M0 = 0x00;
P4M1 = 0x00;
P5M0 = 0x00;
P5M1 = 0x00;
IapErase(0x0400);
P0 = IapRead(0x0400); //P0=0xff
IapProgram(0x0400, 0x12);
P1 = IapRead(0x0400); //P1=0x12
while (1);
2、修改后的代码:
#include "reg51.h"
sfr P0M1 = 0x93;
sfr P0M0 = 0x94;
sfr P1M1 = 0x91;
sfr P1M0 = 0x92;
sfr P2M1 = 0x95;
sfr P2M0 = 0x96;
sfr P3M1 = 0xb1;
sfr P3M0 = 0xb2;
sfr P4M1 = 0xb3;
sfr P4M0 = 0xb4;
sfr P5M1 = 0xc9;
sfr P5M0 = 0xca;
sfr IAP_CMD = 0xC5;
sfr IAP_TPS = 0xF5;
void IapIdle()
IAP_ADDRL = 0;
unsigned char IapRead(unsigned int addr)
unsigned char dat;
return dat;
void IapProgram(unsigned int addr, unsigned char dat)
void IapErase(unsigned int addr)
_nop_(); //
P0M0 = 0x00;
P0M1 = 0x00;
P1M0 = 0x00;
P1M1 = 0x00;
P2M0 = 0x00;
P2M1 = 0x00;
P3M0 = 0x00;
P3M1 = 0x00;
P4M0 = 0x00;
P4M1 = 0x00;
P5M0 = 0x00;
P5M1 = 0x00;
IapErase(0x0400);
while (1);
