查看: 221|回复: 2
按键时钟
  • 打卡总天数:8
  • 最近打卡:2026-04-18 23:43:01
发表于 2025-12-26 16:06:13 | 显示全部楼层 |阅读模式
今天学习了时钟和按键的结合,利用按键可以调整时钟的时、分、秒,结果太棒了!
#include <AI8051U.H>
#include "ai_usb.h"
#include "seg.h"
#include "timer.h"
#include "key.h"
unsigned int xms = 0;                  // 毫秒计时变量
unsigned char Seg_String[10];          // 显示字符串缓存(预留小数点/结束符)
unsigned char Seg_Code[8] = {0,0,0,0,0,0,0,0}; // 数码管段码数组
unsigned char pos = 0;                 // 数码管扫描位置
unsigned int Seg_Dly = 0;              // 显示刷新延时
unsigned char Key_Value;               // 按键扫描值
unsigned char Key_Old,Key_Down;        // 按键状态(旧值/下降沿)
unsigned char Key_Dly = 0;             // 按键消抖延时
unsigned char Seg_Mode = 0;            // 显示模式:0-正常时钟 1-调时 2-调分 3-调秒
// RTC时间变量
unsigned char hour = 22;
unsigned char min = 42;
unsigned char sec = 00;
void Seg_Proc(void);
void Key_Proc(void);
void RTC_Proc(void);
    EAXFR = 1;
    WTST = 0;
    CKCON = 0;
    // 所有端口设为推挽输出(根据硬件调整)
    P0M0 = 0x00; P0M1 = 0x00;
    P1M0 = 0x00; P1M1 = 0x00;
    P2M0 = 0x00; P2M1 = 0x00;
    P3M0 = 0x00; P3M1 = 0x00;
    P4M0 = 0x00; P4M1 = 0x00;
    P5M0 = 0x00; P5M1 = 0x00;
    P6M0 = 0x00; P6M1 = 0x00;
    P7M0 = 0x00; P7M1 = 0x00;
    Timer0_Init();
    usb_init();
        RTC_Proc();
        Seg_Proc();
        Key_Proc();
void Seg_Proc(void)
    if(Seg_Dly < 500) return;
    Seg_Dly = 0;
    // 根据显示模式切换显示内容
    switch(Seg_Mode)
        case 0: // 正常运行:显示时分秒(格式:HH:MM:SS)
            sprintf(Seg_String,"%02d-%02d-%02d", (int)hour, (int)min, (int)sec);
            break;
        case 1: // 调时模式:仅显示小时(闪烁/高亮,此处简化)
            sprintf(Seg_String,"  %02d    ", (int)hour);
            break;
        case 2: // 调分模式:仅显示分钟
            sprintf(Seg_String,"    %02d  ", (int)min);
            break;
        case 3: // 调秒模式:仅显示秒
            sprintf(Seg_String,"      %02d", (int)sec);
            break;
    Seg_Trans(Seg_String, Seg_Code);
void Key_Proc(void)
    if(Key_Dly < 20) return; // 按键消抖(20ms)
    Key_Dly = 0;
    // 按键扫描:下降沿检测
    Key_Value = Key_Du_Read();
    Key_Down = Key_Value & (Key_Old ^ Key_Value); // 仅捕获按键按下的下降沿
    Key_Old = Key_Value;
    switch(Key_Down)
        case 2: // 模式切换键:0→1→2→3→0
            Seg_Mode++;
            if(Seg_Mode == 4) Seg_Mode = 0;
            break;
        case 3: // P33按键:调小时(仅在调时模式/正常模式下生效)
            if(Seg_Mode == 0 || Seg_Mode == 1)
                hour++;
                if(hour >= 24) hour = 0; // 24小时制循环
            break;
        case 4: // P34按键:调分钟(仅在调分模式/正常模式下生效)
            if(Seg_Mode == 0 || Seg_Mode == 2)
                min++;
                if(min >= 60) min = 0; // 分钟0-59循环
            break;
        case 5: // P35按键:调秒(仅在调秒模式/正常模式下生效)
            if(Seg_Mode == 0 || Seg_Mode == 3)
                sec++;
                if(sec >= 60) sec = 0; // 秒0-59循环
            break;
        default:
            break;
    xms++;
    Seg_Dly++;
    Key_Dly++;
    // 数码管动态扫描
    Seg_Disp(Seg_Code, pos);
    if(++pos == 8) pos = 0;
void RTC_Proc(void)
    if(xms == 1000) // 1秒计时
        xms = 0;
        if(++sec == 60) // 秒满60进1分
            sec = 0;
            if(++min == 60) // 分满60进1小时
                min = 0;
                if(++hour == 24) // 小时满24重置
                    hour = 0; // 修复原代码未重置hour的BUG
  • 打卡等级:常住居民II
  • 打卡总天数:87
  • 最近打卡:2026-05-23 08:34:25
发表于 2025-12-26 16:32:06 | 显示全部楼层
要 做到 USB不停电下载
要 尝试 AiCube 图形化自动配置生成程序工具
推荐优先看的:
USB不停电下载, 演示视频链接:
下载 最新的 AiCube-ISP-V6.96L 或以上版本软件 !
深圳国芯人工智能有限公司-工具软件
下载 最新的 USB库函数,永远用最新的 USB库函数 !
深圳国芯人工智能有限公司-库函数
下载 最新的 用户手册 !
下载 最新的 上机实践指导书 !
下载 最新的 Ai8051U 用户手册
下载 最新的 Ai8051U 实验指导书,
AiCube 图形化自动配置生成程序工具使用说明
  • 打卡总天数:418
  • 最近打卡:2026-05-29 11:30:12
851
发表于 2025-12-26 16:38:26 | 显示全部楼层
楼主,帮只在一个帖子中集中打卡,方便论坛维护
GMT+8, 2026-5-30 04:45 , Processed in 0.104402 second(s), 50 queries .
