楼主: 梁工
51开源,步进电机驱动 程序, 直接驱动, 或驱动步进电机驱动器 一共8个程序
 火.. [复制链接]
 楼主| 发表于 2026-7-17 10:04:03 | 显示全部楼层
Hell0*** 发表于 2026-7-17 08:45
程序可以移植到89c52上面吗
89C52只能使用定时器。
发表于 2026-7-19 00:33:56 | 显示全部楼层
Hell0*** 发表于 2026-7-17 10:02
你也做过这个吗,可以发例程吗谢谢
可以的,互相学习
发表于 2026-7-19 00:41:05 | 显示全部楼层
Wd*** 发表于 2026-7-19 00:33
可以的,互相学习
我这写的比较LOW,见笑了,
// 电机转动一步函数
void Step_Motor(Motor_Pins *motor_pins, unsigned int delay_time) {
    static unsigned char num = 0;
    switch (num) {
    case 0:
        motor_pins->A = 1;
        motor_pins->B = 0;
        motor_pins->C = 0;
        motor_pins->D = 0;
        break;
    case 1:
        motor_pins->A = 1;
        motor_pins->B = 1;
        motor_pins->C = 0;
        motor_pins->D = 0;
        break;
    case 2:
        motor_pins->A = 0;
        motor_pins->B = 1;
        motor_pins->C = 0;
        motor_pins->D = 0;
        break;
    case 3:
        motor_pins->A = 0;
        motor_pins->B = 1;
        motor_pins->C = 1;
        motor_pins->D = 0;
        break;
    case 4:
        motor_pins->A = 0;
        motor_pins->B = 0;
        motor_pins->C = 1;
        motor_pins->D = 0;
        break;
    case 5:
        motor_pins->A = 0;
        motor_pins->B = 0;
        motor_pins->C = 1;
        motor_pins->D = 1;
        break;
    case 6:
        motor_pins->A = 0;
        motor_pins->B = 0;
        motor_pins->C = 0;
        motor_pins->D = 1;
        break;
    case 7:
        motor_pins->A = 1;
        motor_pins->B = 0;
        motor_pins->C = 0;
        motor_pins->D = 1;
        break;
    num++;
    if (num == 8) {
        num = 0;
    Delay_ms(delay_time);
发表于 2026-7-19 08:27:29 | 显示全部楼层
可以的,互相学习
谢谢我试试
发表于 2026-8-13 09:13:43 | 显示全部楼层
晚点学习一下
GMT+8, 2026-11-7 12:10 , Processed in 0.070898 second(s), 64 queries .
