楼主: jmg
USB to 2 serial ports-STC8H tests, and bugs
发表于 2023-5-9 10:05:57 | 显示全部楼层
jm*** 发表于 2023-5-9 08:24
As a comparison, here is a newish USB-UART, CH9102 sending at 6M 8N1 with average sustained speed of ...
What's the name of this software? I want to test it with this software.
发表于 2023-5-9 12:55:18 | 显示全部楼层
Seems that it is just an oscilloscope connecting to PC, so you may need their hardwares as well.
The logo on the top-left side is cleverscope.
 楼主| 发表于 2023-5-9 12:55:50 | 显示全部楼层
The capture software is a std storage scope, in this case cleverscope.
The COM sending software is any decent terminal pgm.
The simpler the better, as you want to just send raw bytes, and not have too many screen repaints or parsers in the way.
I've tested on YAT_terminal and Tera Term
To keep things really simple, I also checked the DOS command line as a batch file and even this works too, as a useful test platform, on STC8H and on CH9102
  1. mode COM78 BAUD=2000000 DATA=8 PARITY=n dtr=OFF
  2. copy Char_U_255.txt \\.\COM78
  3. PAUSE
  4. copy Char_U_256.txt \\.\COM78
  5. PAUSE
  6. copy Char_U_257.txt \\.\COM78
  7. PAUSE
  8. copy Char_U_384.txt \\.\COM78
  9. PAUSE
  10. copy Char_U_1024.txt \\.\COM78
  11. PAUSE
With the above, STC8H the 255 byte file looks always ok, the 257 byte file sometimes only sends one byte, and the 1024 file drops many bytes.
With Minimal COM78 BAUD=2000000 DATA=8 PARITY=n dtr=OFF this reports
Status for device COM78:
    Baud:            2000000
    Parity:          None
    Data Bits:       8
    Stop Bits:       1
    Timeout:         OFF
    XON/XOFF:        OFF
    CTS handshaking: OFF
    DSR handshaking: OFF
    DSR sensitivity: OFF
    DTR circuit:     OFF
    RTS circuit:     OFF
发表于 2023-5-9 13:13:06 | 显示全部楼层
Seems that the source file of this board is available at: stcai (dot) com (slash) hxgnsyb
Folder names, documents, and code comments are in Chinese, so be careful if your environment does not support it. You can check their approaches.
GMT+8, 2026-11-7 13:45 , Processed in 0.069284 second(s), 59 queries .
